Question about Magix Movie Edit Pro 12 for PC (639191707612)
Magix Movie Edit Pro 12 won't load!
I have an HP Pavilion Elite m9400f PC. I just installed Magix Movie Edit Pro 12. Upon launch, the program freezes and the computer screen goes blank. I have to manually shutdown/restart. Any tips? Thanks!
    Sniper:
  • 68 Answers
This usually occours when the screen resolution is lower than that required by the program......
try the software at higher resolution or check the system requirements if the video and sound cards meet the requirements of the program.....
Posted on May 09, 2009
Why can't I install download of Magix Movie Edit Pro 14 in Windows 7
You try try the compatibility wizard in Windows 7 to see if you can install Magix Move Edit Pro 14 in compatibility mode for Windows Vista.
To run the Program Compatibility troubleshooter
  1. Open the Program Compatibility troubleshooter by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Tip
  • You can also open the Program Compatibility troubleshooter by right-clicking a program's icon or shortcut and then clicking Troubleshoot compatibility.
Feb 27, 2014 | Computers & Internet
Magix movie edit pro 15 plus... got problem with edit mode...its will close the program when i click on it...pls help.
update drivers and check dll issues. update the drivers like .net frame work adobe flash player etc.
Jun 05, 2012 | Magix Movie Edit Pro 15 for PC
I have problem reinstalling magix edit pro 17 because after removing and now reinstalling the problem of...... ENU(USA) 10.0.0.0 "the installation is not possible because the following related...
Maybe a file in the usual program or configuration directory was locked by another program (e.g. antivirus scans) when you were removing the old edition of Magix Edit Pro; that would leave directories like /Programs/Magix and /Data/Programs/Magix and possibly registry entries (call up RegEdit and delete (or export and then delete) the old items pertaining to Magix or EditPro) around blocking 17 from coming in. Just rename those vestigial directories so they won't be in the install's way. Then retry and report...success?
Oct 02, 2011 | Magix MOVIE EDIT PRO 17 HD PLUS
How do I get a electronic version of the Magix Move Edit Pro manual?
If you installed from the CD there should be a directory in the installed files called manual
It should be located in C--> Program Files
Otherwise here is a download to the manual for Movie edit pro 16
http://www.archive.org/download/MovieEditPro16Manual/MagixMovieEditPro16Manual.pdf
May 15, 2011 | Magix MOVIE EDIT PRO 17 HD PLUS
I bought the program Magix Movie Edit 12 . I just changed to a computer with windows 7. How can I download and run Magix. When I tried it told me to change windows! Thank you
Glad to HELP YOU!
This Magix Movie Edit series were made to run on Windows 7 systems too. So probably your license key was released for your previous computer ONLY. On the list of compatible MAGIX products (for Windows 7) are mentioned just:
  • Movies on DVD 8
  • Movie Edit Pro 16 / 17
  • Movie Edit Pro 16 / 17 Plus
  • Rescue Your Videotapes! 3
  • Video easy HD
  • Video Sound Cleaning Lab
So your MAGIX Movie Edit 12 is not included.
Anyway the same manufacturer says that:
"If you have difficulties with the installation of our products or you have trouble with the system environment email us here: http://support.magix.net/".
... I'd suggest you to do so.
GOOD LUCK!
Mar 28, 2011 | Magix Movie Edit Pro 12 Full Version for...
Can we put magix movie edit pro 15 plus on multiple computers?
The Magix licence agreement specifies that the software is licensed for use on one computer. With the serial number provided you can activate the software up to three times before a new key must be generated. This is for installation on one PC. To install it on a different PC it must be uninstalled from the first one. If the key has been used three times and no longer works to activate the software a new key can be requested upon request.
Jan 28, 2010 | Magix Movie Edit Pro 15 Plus for PC
Manual
can try the following links copy and paste in address bar.
en.kioskea.net/.../21454563-magix-entertainment-magix-movie-edit-pro-14-plus-crazy-talk-4-pc
www.taringa.net/.../MAGIX-Movie-Edit-Pro-15-Plus-8_6_1_0.html -
Dec 01, 2009 | Magix Movie Edit Pro 14 for PC
I have magix movie edit pro 10 and am unable to load any video .mpg or .avi. what do i need to do to get it to load?
Normally there is some feature thats leads you to the software homepage, and from there you could maybe find the support team.
Try to install it again, amny times it is solves the most problems. Has the software had the capacity to load the the videos ??
Aug 17, 2009 | Magix Movie Edit Pro 10 Full Version for...
Magix Movie Edit Pro 12 for PC (639191707612) Logo
229 people viewed this question
Top Magix Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Magix Computer and Internet Expert? Answer questions, earn points and help others
