Question about Dryers
Cant find it, cant even get in to it
How do i change a heating elment on a kenmore 80 series
  • 460 Answers
This web side will help U to fix ya
http://www.applianceaid.com/wp_element.html
"Did it solve your problem?"
Posted on May 09, 2009
No body seems to have a solution for me heating elment was fine fuse was bad replaced it along with thermal cut off switch since it was recommended, all was replace dryer was hot when first started now it...
I have experienced that not only when the thermal cut off fails it's quite often that the high limit switch is the cause and suggest replacing both at the same time. These switches are notorious for failing in series. Also a blocked vent can cause a build up in chamber causing a "detected fault" which can cause this sort of problem also. Be sure that your venting is sufficient and that there is not obstruction or kinking in vent stack.
Aug 20, 2013 | Kenmore Series 70 80 90 PN281798 Dryer...
No a kenmore 80 series dryer will not heat . if the heating elment is good & fuse is good what else could be the problem
The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Mar 09, 2011 | Kenmore Elite HE3 Steam 8676 Dryer
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
Kenmore series 80 dryer . Drum does not spin, even when empty.
Good day,
If runs and heats, then the most probable cause is a broken belt.
Not hard to change. Below is a tutorial on how.
The Kenmore line is manufactured by Whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Thank you for using FixYa
Dec 19, 2009 | Kenmore Dryers
Kenmore 80 series get very low heat
some of the 80 have two part element . one is burned out . or loke for a bad thermo. / hope this helps .
Nov 24, 2009 | Washing Machines
I have a kenmore 80 series electric clothes dryer that will not heat. i am needing to know which part is the heating element, and describe what it looks like
Hi, The element is located in the back right side on most models. It is in a housing and has two red wires going to it. Also check the thermo stats if the element is ok.
May 08, 2009 | Kenmore Dryers
Kenmore dryer does not heat
I have a kenmore series 80. Had the same problem...the fix was replacing the gas coils. The dryer would get hot for about 10-15min then nothing. The gas would stop firing but you could see the igniter glow over and over again. Hope this helps.
Apr 02, 2009 | Kenmore Dryers
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
