Question about Dishwashers
Plasric dish has fused to the element
A plastic container ( fairly strong) has fused to the element and I cannot remove it. Have tried more heat, ice, et al. What can I do?
  • 423 Answers
Use strong kitchen shears to cut away as much of the bulk as you can. Without gouging the round element, scrape it with the kitchen shear blade and run a short cycle. When the drying cycle has run for several minutes (you will smell that the element is heating)
open the DW and again use the shears blade edge to scrape the residual plastic from the element. You may need to repeat to get it all removed.
After you have cleaned it up, do some checking during some loads to make sure the heating element is not being turned on continuously during all cycles. You have not provided the the make/model number, so it is hard to get more specific.
Posted on May 09, 2009
Coffee maker
This model of coffee maker has an adjustable heating element beneath the carafe - ensure the temperature setting for the carafe is high enough to keep the coffee hot.
If the coffee is not brewing hot, the initial heating element/coil may have failed. Removal of the heating element is somewhat problematic and will require disassembly of the water container and base of the coffeemaker, and will likely need to replace the heating coil contained in a plastic sheath. Ensure you take a look at: http://home.howstuffworks.com/coffee-maker2.htm
for further detail.
Apr 07, 2014 | Cuisinart Dcc-2600 14-Cup Coffee Maker
OPTIMUS H-4438 ELECTRIC HEATER ALARM LIGHT UP NO HEAT STILL ROTATE
I took it apart found nothing. Put back together took the plastic screw driver with the unit on,gentlly tapped the plastic houding opposite of the heat senser at the top of dish and it works!
Nov 04, 2011 | Optimus H-4436 Electric Heater
There is food left on the dishes; the air tube is clear, think it must be the drain is blocked with food;; so removed bottom basket took off the middle plastic 'nut' and removed the 4 metal screws ,but...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 17, 2011 | Dishwashers
Westinghouse silhouette frost free 522 fridge is not cooling properly top and bottom.freezer fan is still working,and the motor at the bottom in the back of fridge stay's constantly running and has done...
The heating element, located behind the back plate of the freezer, is probably not working. A failed heating element leads to a build up of ice around the evaporator coils in the rear of the freezer. If the back plate of the freezer is removed (ONLY DO THIS WITH THE APPLIANCE UNPLUGGED FROM THE POWER SUPPLY) and there is a large build up of ice around the evaporator coils then it's a fairly good indication that the heating element is not working. The heating element comes on periodically to defrost/de-ice the evaporator coils. Heating element is often activated by a small timer switch which turns the heater on for a set time every 24 hrs or so. Heating element may be open circuit or timer switch may not be operating. Most likely to be open circuit heating element.
Jan 01, 2010 | Westinghouse Refrigerators
Plastic fused to hearing element
There are many ways to approach this. I assume it has melted and wrapped around the heating element.
One thought is to use a pair of wire-cutters ( called "diagonals"), and cut it off piece by piece.
Another thought is to run the dishwasher with heat option on, let the dish get soft again and pull it off (wear gloves).
May 09, 2009 | Whirlpool 24 in. DU810CWD Built-in...
A small plastic dish has fused to the heating element in the bottom of my Whirlpool dishwasher. How can I best remove it without damaging the element?
I would take a soldering iron and melt as much as you cant away from the element. There may be some residual but it will burn itself off after a few uses
Melted utensil on heating element
Hi amsaunders5,
I'm Harvey the Master Plumber.
Your problem is: Children tried to surprise you by doing dishes. The plastic spatula melted and stuck on the heating coil on the bottom
This is a common problem. First, thank the children, it really wasn't their fault.
It's going to take some effort but you'll have to scrape/remove the plstic from the element. Replaceing the element is not a repair I recomend for the average homeowner.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwasher does not dry the dishes thoroughly
I have a GE dishwasher with poor drying. One service call said to make your water hotter and us a jet dry rinse. Not any better. Another call went to GE, this time they have a vent kit to help push out the steam and the computer will be reprogrammed to allow a longer dry time. Will have this done when the parts arrive at my home. Then the repair man will install and make computer adjustments. Looks like GE knows they have a problem but won't fix it until you complain more than once and demand a fix. For all GE dishwasher owners with this problem start calling the customer service.
Feb 05, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
