Question about Garden
I have a huskee 46" cut 20hp engine. I change all the drive belts, however I have to push the gas pedal all the down and still don't move fast. can you help me?
  • jr camien May 09, 2009
    woulld the lower belt on the drive make a difference in this problem
    Sergeant:
  • 201 Answers
Sounds like rubber on drive clutch is worn and probably needs replacement
Posted on May 09, 2009
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
Huskee 26 hourse power 54 inc deck/how do i change both drive belts on this tractor
The one on the deck you will have to remove the deck. Flip it upside down and replace. There will be an idler wheel with a spring on it that allows you to release tension as you put the new on. The drive belt comes from the front of the motor and loops underneath to the cutting deck. There will be a point on the deck that you can get a little wiggle room to move it forward to get the belt on.
May 01, 2016 | Garden
Air conditioner stops when i accelerate rapidly
The air cond compressor is supposed to stop, but only if the gas pedal is pushed to the floor.
If it is cutting off and the pedal is not all the way down, you could have a problem with the throttle position sensor.
Cutting off during hard acceleration gives you a few more horsepower.
Feb 08, 2013 | 1998 Dodge Ram
Mtd 42" riding mower rear drive belt keeps popping off pulley
Hi, check the idler pulley arm and return spring on that belt. Its most likely not pivoting freely allowing the belt to loosen when you operate the clutch, regards Phil.
Jun 10, 2012 | Mtd Garden
I have a Huskee riding mower- 18.5 hp with 46 inch cut. The mower has 3 blades. When I engage the blades the belt squeals but will go ahead and cut until it gets hot at which time it will stop pulling. The...
check the pullie blade bearing if it is going out it would make the belt squeak and when it gets hot it will make the motor lug down I have worked on mowers for 41 yrs.
Aug 14, 2011 | Garden
Huskee 42 inch drive belt
does anybody know what kind of drive belt a huskee 24 horse 42 deck takes?
Aug 15, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Jul 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Huskee drives weird
If the belt is fine and it isn't slipping at all then the problem would be inside the hydramatic trany. It isn't serviceable and would cost more then the tractor is worth.
May 24, 2009 | Garden
Garden Logo
489 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
