Question about Miele S514 Solaris Turbo Plus Vacuum
I have a 30ft power cord reel. The cord does not wind back up on it correctly. How can I replace the spring or whatever is winding it back up?
Made by hdx sold at home depot
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Cord winder not working
Most times you will have to replace the cord rewind. Sometimes just the cord, but usually there is a problem with thr reel contacts. But now that the spring has unwound, you will have to replace it. You will need model number rather then Red Star.
Posted on Feb 22, 2008
SOURCE: Intermittent a/c voltage
The contacts are fine, they just need to be bent up a little to ensure proper pressure with contact plate. I had exactly the same problem, and it solved it.
Do not remove black graphite lubricant from contacts!!!
Posted on Feb 12, 2009
  • 500 Answers
SOURCE: Miele Artico type HS05, Mod
Hi ryone,
A typical problem with these vacuum cleaners. Your problem is more likely the motor overheating. Try testing it while open, sometimes fluff accumulates on the Motor fan, and overheats the motor. Once it overheats, it shuts off to protect itself, and will be able to start again within 2 minutes.
The cord however could also be the problem, the best way to test this (because visual confirmation is isn't always possible) is with a multimeter set to continuity, attach a point on each end, on the same color, play with the cord and see if the continuity ever changes. This may seem like a long procedure but it will at least let you confirm that it is the cord.
Kind Regards
JEDEMEYER1
* If this solution solved your problem, please accept it
Posted on Aug 20, 2011
I have a kenmore 7120. The cord will not wind up.. I have taken it apart and I can get it to wind half way up. Is there anything else that I can be done.
First, make sure the mechanism isn't so loaded with dust that friction is dragging it to a halt before it should. If the spring mechanism appears to be working properly, manually wind the power cord on the spool just enough so you'll have a small amount of tension on the cord when you put everything back together. It's possible the spring has become weak with use, but a rewind may let you get some more life out of it before have to replace it.
Aug 28, 2017 | Vacuums
My vacuum has cord real problems. It quit working but as I real the cord in and out it will start and stop. So do I need to replace the cord real unit or can I repair it somehow? And If I can repair it,...
If you can get into the reel unit check and see if you have a broken wire . I had one like this and I repaired the wire and the reel was ok after that. I fixed another where the wire and reel were both broken and instead of spending the money for a new reel I pulled the cord out of the reel and hooked the wire back up to the machine and then the cord just would not wind up any more but it worked that way for a long time.
Jan 05, 2015 | Vacuums
Repair retractable cord
Depending on which model of Electrolux you have and how far out you have pulled out the cord (most of the Electrolux canisters have a yellow tape around the machine end of the cord to alert you not to pull it out any further), you might have to take it apart to fix it. However, the first thing that I would try would be to stand it on the end (the hose end at the top), and pull short jerks on the cord to see if it will correct itself and retract. If that does not fix it, I would stick a screwdriver in the hole where the cord comes out of the machine and attempt to wind the cord reel back up which will slowly wind the cord back up on the cordwinder. This usually cause the cord to wind back up. If that does not work, then the only option is to take the machine apart to fix it.
Dec 11, 2013 | Electrolux Vacuums
How to get to wiring plug
If you're talking about the cord that you pull out from the reel located at the rear of the machine, you'll have to take the top cover off first. Usually two philips head screws located under rear exhaust cover and one maybe two near the front end. Once that is removed, there will be two more philips screws, one on each side of the top rear of the machine and one on the bottom. Remove all three of them, pull about a foot of cord off of the reel and get it to catch, the using the heel of your right hand, hit the very back of the machine, (the rubber bumper part) on the top with a motion pulling toward the back. This may take a couple of tries if you're not used to removing this part, but one or two swipes should eventually loosen the rear cover. Once it is loosened you may carefully pull it out of the back end of the machine and take off the two wire connections. This will free up the cordwinder assy. so you can take it to a spot where you have some room to work. Now lay the assembly on it's back and take the four screws, one from each corner of the rear cover, out and lay them aside. Thread the cord plug through the opening and wind the free cord back onto the reel, allowing the spring to pull it slowly out of your hand and then wrap the plug end around and around the reel till the spring is unwound, then you can remove the "C" clip from the center post, sometimes hidden under a cardboard washer. With the clip removed you can gently pull the cord reel up and off the post, carefully bringing the rewind spring up and off it's post as well. If you've tested the cord and are sure that it's your problem then you can cut the remainder of the cord from the reel and throw it away. The reel is easier to deal with without the cord on it. Turn the reel over so the back cover is exposed, there should be three screws that can be removed so you can take the connections loose from the posts inside and make ready for the new cord. Once you've attached the new cord and tied your strain relief knot, like the one you removed, you're ready to wrap the cord onto the reel and just reverse the procedure. When you get ready to put the loaded reel back into the cordwinder body, just before you put the cover on, wrap the plug end around the reel three times. This loads the spring so that it will pull the cord completely back into the unit. And it doesn't hurt to drop a spot of oil onto the top of the post for the spring.
Nov 11, 2013 | Electrolux C101 Bagged Canister Vacuum
I have a Miele silver moon that kept shutting off while using it. I replaced the hose with the new 125-s model but problem came back. It does appear to be a problem with the hose. Any suggestions?
My S558 Red Velvet had the same problem. I disassembled the handle and cleaned the rings and electrical contacts. The problem has not come back.
Sep 28, 2010 | Miele s558 Silver Moon Vacuum
Cable does not wind in. Hoover Helios 2000. Found the 4 font fixing screws - there must be more at the back. How do you get at them?
The flex is fitted to a spring loaded cord reel.
in side the Telios, chances are the reel is faulty and too expensive to change, either get use to it or buy a new one. sorry
Sep 19, 2009 | Vacuums
Bosch Formula vacuum cord stuck
You need to take apart the reel. The cord is wound over itself and kinked. Be careful taking apart because if it gets away from you, you will have to wind the spring by hand and it is difficult to do and frustrating.Good luck
Jul 26, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
Yanked the cord out of the vacuum
Wasn't able to find any diagrams either, but there should be some screws to take out, and the top and bottom should separate. Don't let the cord reel spring unwind if it hasn't already done so. If it hasn't, one half of the reel should come aprt so you can re-attach the cord. then put the reel back together and let it wind the cord on the reel. If the spring is unwound and/or the reel wasn't made to come apart, then you will have to replace the cord reel asm.
Feb 28, 2008 | Bosch BSG71360UC Bagged Canister Vacuum
Won't Turn On
Mine was a simple fix. Hope yours is too.
You need to take the unit apart to get to the cord reel. If you don't know how to take your unit apart, here are some instructions on how to take apart most of the Miele canister units.
http://www.sannerud.com/house/miele.html
Once it is apart, you will need to take out the cord reel. There is a small rubber hose which needs to be removed on the outermost part of the reel. Then there is one small silver screw that you must remove as well. One these two items have been removed, carefully lift the entire cord reel assembly upwards. When you are doing this, ensure that you are also lifting the black and white wiring along with the reel - just make sure that you're not yanking it and possibly breaking the connectors off. As you lift the entire reel assembly out, you can also remove the white wiring harness which connects to the main switches on the vacuum.
Now, here is the trickiest part - not really that tricky if you are good with your hands.
First, make sure that the cord is retracted fully. Then, start pulling the white plastic cord reel away from the black plastic assembly about 1 inch or so. Between the black assembly and the white reel, you'll notice a copper-like metal spring which is attached to the white reel. Make sure that as you are removing the white reel further, that you are maintaining visibility with the copper-like spring. DO NOT LET THE SPRING OUT OF ITS OWN WHITE REEL (the spring has its own reel which is difficult to wind up again, so be very careful!).
Make sure that the spring is fully retracted at this time. If it is not, wind the reel so that the spring is not wound up anymore around the white reel. Carefully slip the spring out of the white reel and leave the spring as-is ensuring that it does not unwind itself out of its own reel.
Now that you have the white reel off the black assembly, inspect the inside of the inner part of the white reel. You'll see two copper rings with 'wings' on them. These wings transfer power to the vacuum. There may be some grease (black) which you should wipe off with a paper towel. Also wipe the metal rings on the black assembly which touch these 'wings'. (the wings touch the metal rings to send constant power to the motor. The wings are there so that as you wind and unwind the power cord from the vacuum, there is always constant contact with the metal rings on the black assembly.
Now, carefully pull the wings up and out. If you can picture it in your head, what you're doing is ensuring that there is a good contact between the copper wings and the metal rings on the black assembly. Do this for all 4 wings on both the inner and outer copper rings within the white reel. Make sure that the 4 pads are clean and grease/dirt free.
Once you've done this, it's time to put the white reel back on the black assembly. Do everything you did earlier, but in reverse.
Carefully take the copper spring and align it to the white reel - you'll see a specific slot where the spring slides and grabs onto on the white reel. You'll probably have to place the white reel slightly onto the black assembly rod in order to achieve this - again, you must be good with your hands to do this without breaking anything.
Once the copper spring is attached to the white reel, press the rest of the white reel onto the black assembly. HINT: turn the white reel slightly so that you're applying some tension on the spring - this will make sure that the spring doesn't fall out of the white reel.
Reassemble the cord reel assembly (black and white parts) back into the vacuum. Make sure that the black and white power cables are out of the way. Once seated, wrap the black and white cables around the assembly and reseat the white wiring harness. Reapply the black rubber tube to the cord reel assembly and replace the silver screw to hold the entire harness down.
Close the vacuum casing, replace the control panel (power and cord buttons). Close the unit, plug it in, and power it on!
If it worked for you, congrats! If it didn't, sorry, you've got a much bigger problem with your unit.
Dec 23, 2007 | Miele S514 Solaris Turbo Plus Vacuum
Aug 07, 2007 | Miele Red Star Bagged Canister Vacuum
Miele S514 Solaris Turbo Plus Vacuum Logo
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
