Question about KitchenAid Food Mixers
Remove beate bar
Pin on beater bar is stuck and will not move
4 Suggested Answers
SOURCE: beaters will not move
Kitchen Aid Mixer KSM150 motor runs but beater will not turn.
Posted on May 15, 2011
SOURCE: K-beater is stuck on our Kenwood Chef and we can't remove it
I couldn't remove the K-Beater as when I tried to turn it the whole mechanism turned with it. I couldn't even remove the splashguard! I was going to take it to the Kenwood factory (a few miles from home) but then I thought I'd give it one more go and this is what I did...
  1. Next to where the K-Beater attaches in the middle of the circular plate is a lug with a pointed-shape bolt on the end. Remove this with a spanner and the beater plus gear cog can be removed.
  2. Place some mole grips or wide pliers on a worktop and sit the cogged gear in to it and grip so that it won't turn.
  3. Now you should be able to remove the K-Beater!
Perhaps someone can suggest how to stop it happening again. I haven't attached anything since but will update this post if I have any other helpful tips.
Posted on Oct 31, 2011
SOURCE: can't remove beater kmix from machine. it's stuck!kenwood
Here's how to fix the stuck implement problem:
The implements each have adjustable heights. to adjust the height you need to loosen the bolt at the top with a 14mm spanner. If the bolt was loose when it was being used then it can get too short and not leave enough clearance between the bolt and the machine in order to push up and turn to release the implement. If this happens take the open ended spanner, grasp the implement and rotate the spanner clockwise (when looking up at the machine from below. Once the nut is loose rotate the implement until there is enough clearance to remove it normally.
Posted on Nov 18, 2011
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
Beaters will not move
You have probably stripped a gear in the gear housing. Here is the breakdown of the gearbox:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
The newer "more improved" mixers use plastic gears and they can't take the beating, no pun intended, and fail.
The good news is that the most likely gear to fail is cheap. Here it is on amazon.com:
http://www.amazon.com/KitchenAid-W10112253-Worm-Gear/dp/B0006HLAVA
http://www.misterfixit.com
Mar 25, 2010 | KitchenAid KSM150PS Artisan Series Stand...
I cannot get the beater to lock in place. The
Hi VBPROSANDY, When you say beater, I assume you mean your flat beater. Are you having the same problem with your Wire Whip beater and dough hook? If you are not, then the first thing I’d do is look inside the flat beater’s attachment well, to see that there is nothing; i.e. hardened food, dough or batter, in the bottom of it that would prevent the agitator shaft and groove pin from seating properly. The flat beater has two drain holes at the bottom for drainage, but if these get plugged it may prevent accumulated ‘gunk’ at the bottom from escaping, and over time the buildup may prevent the beater from seating properly.
If you find the beater attachment well is clean, then from the KA Instruction manual, to attach the flat beater...
1. Slide speed control to OFF and unplug.
2. Slip flat beater on beater shaft.
3. Turn beater to left, hooking beater over the pin on shaft.
Finally, check the groove pin on the agitator shaft to make sure it hasn’t become bent so that it doesn’t fit the beater properly. Pins shouldn’t bend, but sometimes they do.
The beater attachment process should not require any effort as the agitator shaft should easily fit into the beater’s attachment well and easily turn to the left. Your planetary should not move during this process and if it does move it will take some effort on your part to turn it. The fact that you’re turning the planetary means you’ve turned the beater as far to the left as it should go to ‘lock’ it. When you get this far, let go and the beater should fall into place on the groove pin.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 06, 2009 | KitchenAid KP2671 Professional 6 Series...
Old Kenmore mixer beaters broken
Fixya does not sell replacement beaters and does not recommend sources.
Jul 24, 2017 | Kenmore Food Mixers
Kitchen aid--heavy duty mixer
The beater is held in place by a pin and spring arrangement. Lift and twist the beater. If that doesn't work, the pin is trying to come out...and is wedging against the beater. Tap the pin back in a bit, and the beater should release.
Regards, --W/D--
Jul 25, 2009 | KitchenAid K45SS Classic Stand Mixer
I cant remove the hook mixer from the shaft it was not taken off after the last time it was used and now is stuck on any ideas
Renato20,Either the hook is worn or the beater shaft pin is worn or dough has built up around the pin/shaft and is stuck.I'm a hobart tech and if i came to your place,first i would use a rubber mallet and hit the outer edge of the hook upwards and see if i could free it.If that does'nt work i would heat tghe hook up with a torch and beat on it up,If that does'nt work i would cut the shaft and replace the shaft and hook.I bet if you beat on it (takes time) you will get it off.
Mar 09, 2009 | Hobart D300 Stand Mixer
Can't remove beater from mixer...
I took the advice from: http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=6356
I put a wash cloth in a pot of boiling water and used tongs to wrap it around the beater shaft while the mixer was resting on its side. When the wash cloth was not too hot to touch, I put it back in the boiling water and did it again. I was then able to easily remove the beater.
Nov 28, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Food Mixers Logo
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
