Question about Magnum S6 Base CB Radio
My magnum when i key up it blows the fuse,what could it be?
When i key up to talk the magnum blows the fuse, took it to the cb shop and they said they couldnt find anything wrong with it. i took it to my truck and the problem came back, and im able to receive but cant talk back.
    Scholar:
  • 85 Answers
Check your aerial for open/short circuit/power wiring to cb in truck/upgrade the fuse by 1 amp/mike wiring (tx/rx) if the cb shop could'nt find anything wrong then the faults in the truck/aerial/power? or the cb shops not up to much! you could have a faulty output transistor in the cb if all else fails?
Posted on May 09, 2009
Just got and can't receive on the magnum 257hp
make sure antenna is functioning correctly, make sure if PA switch is off. if all is ok and its still not working carry it to your local cb shop or a truck-stop cb shop on the interstate !!!
Apr 04, 2014 | Magnum 257 CB Transceiver with Blue screen
Inline fuse blows when mic is keyed and talking
either wrong size fuse or wires are touching inside mike when keyed
Sep 09, 2013 | Radio Shack Radio Communications
Dont go or recieve more then half a mile
Check the SWR on the antenna system.
Aug 03, 2012 | Magnum S6 Base CB Radio
Where can I take my radio for repair in Wisconsin
I did a google search and the only CB shop I found was this one. Unfortunately there are not a lot of CB shops around any more. You may have to send it out to one for repair. Most do business over the internet now, and rely on shipping the radios. there are a bunch out there.
You can google any of these, or just CB repair.
Bells cb
Sparkys cb shack
radio active radios
There are a lot on the net that will do repairs via shipping.
Jul 27, 2011 | Magnum S9 Base CB Radio
No transmit audio on my magnum deltaforce
Do you have receive? Make sure the radio is on CB and not PA. It happens. Try a different mike and make sure that is not the issue. Make sure your SWR is 1-1:5 and no higher than 2. You can loose a lot of your signal from a high SWR but SWR will not make it so you have no audio. You may have to replace the final transistor. Try this too. Take an external speaker and hook it into the PA port in the back of your CB and switch your CB to PA. If you key down your mic and hear your voice out of the external speaker your voice chip is good. Let me know if any of this helps. If I had a CB in my shop, this is how I would start the checking. Good luck.
Mar 06, 2011 | Magnum DeltaForce CB Radio
My magnum delta force blows the higest amp fuse!!! (shorting out)
yes it sounds as if the diode has gone short curcuit. this is at the back or near the in put socket. the diode is black with a silver end. replace with same size this should sort it out.
May 14, 2009 | Magnum DeltaForce CB Radio
No power to radio in trk have 13.5 volts to radio 257 magnum
Ensure that the wiring is correct. Also make sure that the CB's AC is still functioning correctly. Charge your truck's batteries and test the CB on a fixed electrical output (indoor outlet). Also check to see if the power cord is the correct wattage output for the radio.
Hope this helps!
Gavin93
Aug 02, 2008 | Magnum 257 CB Radio
Galaxy 2527 all works except no dead key wattage.
if you are talking on SSB then their is never a dead key wattage.
SSB uses all modulation, no dead key.
Apr 25, 2008 | Magnum OmegaForce S45 CB Radio
Blowing fuses
Sound like: 1. Are you using the correct fuse rating?? 2. Are you supplying the correct voltage?? 3. You probably have final amp problems.. get an expert.
Feb 10, 2008 | Radio Communications
Magnum S6 Base CB Radio Logo
210 people viewed this question
Top Magnum Radio Communications Experts
John Porter
Mike Charette
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
