Question about Gateway Computers & Internet
Gateway nv57h73u...wireless is gone...I even repalced the chip...still nothing!
Lost the wireless feature a while back. I don't use it much, so I didn't even know it wasn't working- until I needed it. I have gone through every process to find it. Followed untold tutorials from online forums...nothing. A few weeks back, I researched the chip by removing the cover on my machine to see where it was, and if I could replace it. I carefully removed one of the quick-connects to make sure I could do it myself. After turning the laptop back on, the wireless signal was there! It uploaded a driver and was working...and I could turn it on and off! It was listed in the device manager again! Simple but weird fix I thought. I shut the computer off that night like I always do, and it was gone again the next day, like nothing even happened. Bought a brand new Intel wireless chip. Installed it. Nothing. Mobility center doesn't show anything wireless. Tried a complete reboot, nada, still gone. Countless downloads, nope. I have a network controller in the device manager that has an exclamation point next to it- if you try to load/search for a new driver, it can't find it. Windows troubleshooter can't identify the problem. I've owned this laptop for just over a year, love it, but hate this problem! Next?
SOURCE: XTV2.0 software says "Please install the XTV2.0 Hardware Device"
Windows is installing the wrong driver. If the driver is loaded in the Device manager list ( /Sound, Video and Game Controllers ) as USB2821 then the wrong driver is loaded. It should be loaded under Imaging devices as XTV2.0. If this is the case right click on the USB2821 device and reload the driver again from the CD under "XTV20\Driver\Manual and select "EMVIDEO.INF" or from from a different location`until the correct driver is loaded. It won't work until the driver XTV20 is loaded under (Imaging Devices).
Posted on Jan 30, 2008
Pyrhyc
  • 2028 Answers
SOURCE: gateway computer
You're best bet is putting it on Ebay with a reserve or starting bid, or you can finding a local shop that sells used computers and see if they will put it on consignment. They probably won't give near what it's worth, just for the simple fact of turning a profit. At my shop we offer about a third of the asking price, which is negoticable.
Posted on Jun 12, 2008
SOURCE: Wireless network adapter - Vista
I know this is over a year, but have you tried checking the bios setting? It may be that the bios has an option to disable the integrated wlan.
Posted on Nov 29, 2008
SOURCE: Intel Pro Wireless 2200BG problem or Linksys BEFW11S4 problem?
You dont have WPA2 security in your windows install...
you may wanna check this link
It has instructions in how to enable it without using the ProSET utility from Intel
Posted on Dec 20, 2008
SOURCE: Ethernet Controller Compaq Evo D310m Intel Pro 100 VE
try using Microsoft update to scan for driver and software updates.
Posted on Feb 14, 2009
How to replace charging port
Gateway Nv57h73u notebook jack issue check:
1) more common issue is changer ( ac adapter) DC core broken inside, please change a adapter to fix. also you can repair adapter DC core wire. if still no charging that could be DC jack issue inside notebook.
2) disassembly keyboard and top cover of your laptop looking for a wire it connect to the DC jack, check is the wire broken close to the jack soldering pot. you can soldering it to fix, or other issue is jack damaged, you can order and change the DC jack with wire easily, the parts see picture
Oct 20, 2014 | Gateway Nv57h73u With Autodesk Maya...
Won't Power On
Try connecting the power cable. I think this is because the battery is out.
Jul 05, 2014 | Gateway Nv57h73u 2.3ghz Core I3 4gb Ram...
My touchpad scroll bar on my Gateway NV57H73u Laptop is not working. The touchpad itself is working though. Can anyone help?
Some laptops/notebooks [weight is the difference between the two], sometimes if you've tapped on the touchpad, it can activate or deactivate features. However, if you're running windows 8, be careful with window updates since they have been known to screw up your PC.....
Feb 05, 2014 | Gateway NV57H73u Laptop Computer With...
Touch pad driver for NV57H73u
Have you checked out the Gateway support page below:http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=3518
For the Gateway Model NV57h it appears that there are two touchpad suppliers ELANTECH and Synaptics, The page has most of the drivers for your laptop including the last 2 or 3 ver. of each Manfacturer Touchpad driver. Just click the download arrow next to the driver you need then open the file once downloaded, re-boot(not always nessasary but usually it is required), If the driver was your issue and you downloaded the correct one, that should have you up and running.
Jan 29, 2013 | Gateway Nv57h73u 15.6" A4-3305m 8gb Ram...
Sir i lost my wireless network name and my wireless network password
to get back you wireless information,first you have to connect you laptop hard wired to the router using the ethernet cable, then open a browser and access the firmware of the router,usually for dlink routers,the default gateway to access the router is(10.0.0.1),but if you don't know the default gateway, you can go to the network connection by typing (ncpa.cpl) in the run box or the start search from the start menu. look for "LAN or Highspeed Internet or Local Area connection" then right click on it and select status. Note:make sure that the laptop is propperly connected via network cable.
you will have the "status" page.
for winXP: click on support tab and look for the "default gateway"
for win vista and win7: click on "details" button and look for "ipv4 default gateway"
The "default gateway" number including "dot" needs to be typed in the address bar of your browser.
The router then will ask you to enter the username and password,which is located in the back on side of the router. After you got to the router page, on the left pannel,click on "wireless settings" there you will see you wireless information.
Sep 22, 2011 | D-Link DIR-615 Wireless Router
About 3 yrs ago,the wireless feature quit working on my gateway t-6815 notebook pc with windows vista. i turn the wireless swith on and press the function button with f2 to turn it on and nothing happens....
they do fail,
the card (wi-fi) is small inside the pc watch out for the co-ax connections because they are micro and can only stand being unplugged a few times before they break.
good luck
Davey Snake!!
Aug 03, 2011 | Gateway T-6815 RTL Notebook
My Dell Laptop won't connect wirelessly anymore. Have checked wireless feature and it is switched on, have reset router and gone through all channels
CAN U SEE WIRELESS DEVICE IN DEVICE MANAGER , I DOUBT ITS WIFI CHIP IS NOT WORKING , IF SO CAN ONLY BE FIXED BY A REPAIR GUY .
Jan 05, 2011 | Dell Computers & Internet
The gateway light lights up on the front but nothing will come up on the screen
If the computer turns on then it's usually the video thats gone bad. If it's onbaord video then the you need to install a video card.
If that doesn't work then try swapping out the RAM. One of the chips may have gone bad.
Do you hear any beeps when the machine turns on?
Jun 16, 2010 | Gateway ONE GZ7108 All-in-One Desktop PC
I have lost the security password/key to set up wireless router
if you don`t have anything like wep or wpa on the back then you have to get into your router settings. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway open Internet explorer and type default gateway in the address bar.hit enter type the username and password for the router.goto wireless settings and you can check the security if not then you can make one.take care.
Jul 01, 2009 | D-Link Wireless
I lost my CD for my Netopia USB wireless router
go to windows update after you have installed netopia usb adapter and do custom scan and it will bring up ralink 2500 usb driver install that and it will work netopia usb adapter i think it has ralink chip but it works with mine
Mar 28, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
Computers & Internet Logo
66 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
