Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
Marathon wiring - Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
    Top Expert:
  • Hayward Master
  • 7,884 Answers
Look on side of motor schematic on side
Posted on Mar 05, 2016
How do i find a manual for my timex marathon wr50m digital white watch t5k805?
I'm guessing that your watch is described here
http://www.walmart.com/ip/Marathon-by-Timex-Digital-Mid-Size-Black-and-Silver-Tone-Watch/38229915
(at the bottom it says model = T5K805, name is marathon)
[also on Amazon - http://www.amazon.com/Timex-Womens-Marathon-Sports-Digital/dp/B00R4XTAJ8/ref=sr_1_3?s=apparel&ie=UTF8&qid=1421449802&sr=1-3&keywords=t5k805&pebp=1421449828860&peasin=B00R4XTAJ8)
Then.look down the list for marathon in this http://www.timex.co.uk/info/product-manuals-downloads
and choose the one of the three you want. The non GPS one is very short and not really what I'd call a manual. I hope this is what you need. Otherwise contact Timex
16.January.2015
Jan 16, 2015 | Timex Watches
Rieju wiring diagram
Hi, Samuel for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Rieju, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Rieju marathon pro 125 wiring diagram Google Search
Rieju Marathon Pro 125 4T LC Parts Accessories Scooter Parts Racing Planet...
http://www.pieces-rieju.com/documentation/Manuel%20R%C3%A9paration%20Marathon%20125%20(chassis).PDF
https://www.rieju.es/uploads/_modelos/id9/Owners-Manual_Marathon_125_UK_V3.pdf
Apr 21, 2014 | 2011 Rieju Marathon Pro 125
I cant get the water temp below 125 and I need to for our day care. I have the lower thermostat set to 110 and it still is 125 to 130 degrees. Is there something else I need to do. There is a upper...
You have marathon water heater?
Thermostat is probably bad. Has gone out of calibration.
Replace both upper and lower thermostats for $25 from local hardware store, takes about 20 minutes, turn off power, take photo of wires before starting. These thermostats can be adjusted all the way down to 90 degrees, and then dial up a bit to reach 110.
Copy following link for instructions how to replace thermostat yourself.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problem continues, then replace both elements.
Elements are special order made specifically for marathon.
Requires 1-7/8" socket to remove elements.
Upper 3800 watt, order part SP610130
Lower 3800 watt, order part SP210197
http://hometips.me/Mar/Rheem-Marathon-parts-2.pdf
http://waterheatertimer.org/How-to-replace-water-heater-element.html
More information about Marathon:
http://waterheatertimer.org/Review-Rheem-Marathon-water-heater.html
Gene
h
Aug 26, 2013 | Rheem MR105245 Marathon Electric Water...
Rheem marathon vacuum valve
Copy following link for Rheem marathon parts and resources:
Add a comment March 2013 and describe problem in detail.
Mar 22, 2013 | Rheem MR50245 Marathon Electric Water...
Can I install 4500 wt elements in a marathon MR50238? The tank specs are the same as MR 50245.
1) Product warranty will be voided if you install 4500 watt elements in year-2008 model MR50238 3800 watt marathon tank.
Older 3800 watt element models have been discontinued.
2) Copy following links for Marathon resources:
3) Product warranty is voided if element wattage exceeds label on side of unit.
4) Marathon has a problem with elements burning out frequently.
To solve this problem, they suggest installing element with lower wattage, such as the 3800 watt.
Upper 3800 SP610130
Lower 3800 SP210197
Feb 20, 2013 | Water Heaters
WIRING A COMPATIBLE POOL PUMP[MARATHON 1 H.P.230V
check for 230v not 110 (on line to ground). SO checking L1 and L2 should show 230 v if not you have a fault in the timer or the breaker is toast. depending on the timer you can clean the points
Jun 30, 2017 | Pool & Spa
How do I wire around upper heating element until I can get an other one to replace it?
Question posted under marathon electric water heater.
Marathon is 240Volt dual element non-simultaneous water heater.
Non-simultaneous means that upper part of tank has to reach temperature before power is sent to lower thermostat and element. So if upper element is bad, then water heater has no hot water.
http://waterheatertimer.org/Replace-anode-rod.html#audibleBW
1) You need to by-pass upper element without by-passing upper thermostat.
2) You should never by-pass upper thermostat because it has ECO-reset protection.
http://waterheatertimer.org/How-water-heater-thermostats-work.html
3) Open following link for image of wiring:
http://waterheatertimer.org/images/Marathon-wiring-700.jpg
4) Take photo of your wiring in case color code is different on your specific model
5) Look at upper thermostat.
Remove yellow wire from terminal 2 on upper thermostat, and cap off temporarily.
Remove red wire from terminal 4 on upper thermostat, and move it to terminal 2 on upper thermostat.
6) For more effective operation, look at lower thermostat.
Remove black wire from lower thermostat terminal 1 and move wire to terminal 2 on lower thermostat.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Rheem MR105245 Marathon Electric Water...
What does parallel mean on my marathon 3050 power amp?
parallel mean that you connect speakers wire together to amp(positive side with positive side and negative side with negative side)in this situation you got less resistance from speakers and more current.
i mean more sound level.
Apr 11, 2009 | Marathon DJ-2000 Amplifier
How do I set up and use the adanac 4000 stopwatch by marathon?
www.marathonwatch.com "Contact Us" They will email you the instructions.
Feb 09, 2009 | Timex T5G811 Marathon Stopwatch
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
