Question about Exercise & Fitness
My treadmill belt has formed a crease in the middle how can i fix it
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: I have an Image 15.0Q UMTL31504 and the belt has
Go To Iconservice.com Click on manual input Image then M# IMTL31504.
Check the end caps to see if one of them is cracked before adjusting the belt. The crease cannot be straighten and 9 of 10 times it can be a hazard when walking so if you proceed using it in this condition BE CAREFUL!!!
Posted on Jul 31, 2010
SOURCE: looking for instructions to remove belt from J8 pro-form treadmil
I have a proform j8li treadmill. What size allen wrench to I need to adjust the belts?
Danielg@jcnj.org
Thanks
Posted on Apr 28, 2011
ercupa190
  • 12223 Answers
SOURCE: The belt on my NB 1400 treadmill has folded over
1) try to adjust see the videos and proceed according at your common sense NOT feared:God bless you
Posted on Jul 26, 2012
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
Tread belt is creasing. Have tried to adjust but continues to crease
belt is not aligned properly, have to be exact or belt will crease. If new seek warranty support. good luck.
Apr 10, 2015 | Exercise & Fitness
I have a pro form treadmill and it seems like the belt is sticking, its about 14 yrs old. I think I might need to replace the belt
kilgore511,
The most common cause of belt sticking or "slippage" is lack of lubrication. Most treadmill belts use lubrication on the underside of the belt to reduce friction between the belt and the platform. This helps the treadmill glide along smoothly under the weight of a person. If your belt is lacking in lubrication, it can catch on the treadmill platform. Apply lubrication every few months to the underside of the belt to prevent this from occurring.
A petroleum or silicone based lubricant is recommended, and most easily applied in a spray can. Simply lift up the belt about midway along the platform and spray a small amount of lubricant underneath from about the middle of the platform width to the closest edge. Repeat from the other side. Apply lubricant sparingly...it can be messy.
Next, turn on the treadmill and let it run for a minute, then check if the belt still sticks. A little more lubricant may be necessary.
If you have found this helpful, please take a moment to give me four thumbs up.
Regards,
DIYpro
Apr 29, 2011 | Proform Exercise & Fitness
The belt on my New Balance 1400 has become kinked up. I tried adjusting it by loosening it up, straightening it out, then tightening it back up, but it kinks up again. Before it kinked up for the first...
Unfortunately once the belt has a crease that all she wrote. Belt replacement is the next step.Call Fitness Quest they are the makers of your treadmill @ 1-800-321-9236
Jul 31, 2010 | New Balance 1400 Treadmill
Jul 30, 2010 | Exercise & Fitness
Running belt has creased badly, will I need new belt ?
Wow, this is weird, I've just come back from the gym and the guys there were 'fixing' a crease on one side of the belt.
They had the belt off the treadmill, and put a wooden board on the inside, with some weight plates on them, a few wooden blocks on the inside, so the belt looked like it was the same height as when it is fitted and then a wooden board and weights on the top.
By the time I'd finished my session, they were refitting it and it looked good, you could still see a slight dent, but not a full crease.
Hope this helps you and good luck.
Jul 18, 2010 | Tunturi T30 Programmable Treadmill
Walking belt folds
It sounds like one of the adjusted bolts or endcaps that adjusts the walk belt is broken,look at the bolts where you adjust and see if the side the belt is shifting to is broken.It may have ruined the belt also but you wont be able to tell till you correct the tracking problem.
Jul 18, 2009 | Proform Sport 1000 Folding Treadmill...
Looking for instructions to remove belt from J8 pro-form treadmil
Danielg@jcnj.org
Thanks
May 03, 2009 | Exercise & Fitness
Exercise & Fitness Logo
77 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
