Question about Westinghouse WST3501 Microwave Oven
Microwave has annoying beep
I want to know if there is anyway to program the microwave to turn off the sound. The beep is really annoying. The sound it emits can go through foam ear plugs rated for 33 decibels and wake up someone sleeping two rooms away.
GE JES1344SK01 microwave: turn off reminder beeps
I checked my GE micro information and nothing is said about disabling that annoying beep. Guess GE feels it is for your own good, like a noisome nanny.
Jan 02, 2014 | GE JES1344SK Microwave Oven
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
KitchenAid kemc308kss0 Micro/Oven Combo Microwave: At the end of any cycle there is a four-tone beep that will continue to beep until KINGDOM COME until you either a. open the door b. press cancel. That is...
From page 7 of your owner's manual:
All Tones (combination oven models only)
All of the above tones are preset on, but can be turned off.
To Turn Off/On: Touch and hold STOP TIME for 5 seconds. A
tone will sound and “Snd oFF” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd on.”
Tone Volume
The volume is preset at high, but can be changed to low.
To Change: Touch and hold the number pad “7” for 5 seconds. A
tone will sound and “Snd Lo” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd HI.”
REMINDER TONES
The Timer and Timed Cooking reminder tones are preset on, but
can be turned off. Reminder tones do not include end-of-cycle
tones. On combination oven models, if “All Tones” have been
turned off, the reminder tones cannot be independently turned
on.
Timer
To Turn Tones Off/On: Touch and hold TIMER SET • START until
a tone sounds. Repeat to turn back on.
Timed Cooking (combination oven models only)
To Turn Tones Off/On: Touch and hold COOK TIME until a tone
sounds and the lower oven display returns to inactive mode
(blank). Repeat to turn back on.
Apr 26, 2010 | KitchenAid Microwave Ovens
I would like to know if there was a way to when the microwave is done it has an annoying 5 beeps. I would like to be able to cut it down to 2. I have an Emerson MW8119SBM.
A small number of models have a feature that lets you turn off or otherwise alter the beep on the microwave.
If so, it will be covered in the owner's manual.
Otherwise, see this video:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/ITHDE-vFaiw&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ITHDE-vFaiw&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Jan 30, 2010 | Emerson Microwave Ovens
How do I stop the beeping on a Hinari Microwave?
Unfortunately, its programmed into the software. Ive never really seen a microwave thats given the operator the option to silence the alarm.
Oct 14, 2009 | Microwave Ovens
Galanz (french for ''****'') microwave is sporadically beeping
maybe, just maybe, there is an error code showing....and, most microwaves beep when a button is pushed too...LIVE WITH IT!
Jul 06, 2009 | Microwave Ovens
Emerson Microwave oven and grill MWG9111SL
teashas_tasty_treats@yahooo.com
i have the same problem too! please help if you can.
Oct 25, 2008 | Microwave Ovens
How to turn off annoying beep sounds of alert and programming
First of all, microwave ovens do not emit ionizing radiation.
The only risk from any leakage is a burn.
Generally, microwave leakage only occurs when the door / door seal is loose or damaged or there has been an improper repair attempt.
You can select a model which lets you turn the beeper on and off by looking for that feature as you shop manufacturer Web sites, or in the store ask the clerk to pull the manual for you to examine, or contact the manufacturer's help center, support center, or FAQ.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. LG / Goldstar owner's manuals can be downloaded here.
If you're interested in other brands, please reply back and let me know. I'll be happy to post contact info.
Sep 26, 2008 | LG LRMM1430 Microwave Oven
Disabling the beep on a Kenmore microwave
I have Kenmore microwave model 721.61820100.
It has an "Option" button. Press it. The display say "NUMBER"
Then press "1". The display should say "SOUND" and then "OFF".
Press "Start" and that beast turns silent, well not really, but the beeps are goooone.
If for some reason you don't like it this way repeat the sequence and the sound this time will turn "ON".
Jun 05, 2008 | Kenmore 80809 Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
