System is restoring by this error 0x800ffff - Computers & Internet
How to solved error code 6235
To fix windows error code 6235 you must have to follow our instruction. There are two way to solve this error first one is manual and second one is by using software means automatic solutions.
Manual Steps:
  • 1.Click on Start button go to all program, Accessories and click on system restore.
  • 2.After making system restore point, restore your computer at earlier point.
  • 3.Finish System restoration.
  • Hope system restoration will help you to fix windows error code 6235. If it is not work properly then there is only way to solve this issue by using Windows Repair Tool. Mainly this tool help you to fix all problem in your windows OS and easily repair to corrupt files and also registry file.
Feb 27, 2015 | Computers & Internet
File is missing
The Error Code 0Xc004e003 error may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
To fix Error Code 0Xc004e003 Windows 7 Error:
Advanced Computer User Solution:
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Jan 25, 2014 | Microsoft Windows 7 Ultimate, Full Version...
Everytime I start my pc up it reads files are compressed
Is it affecting your computer from running>???
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer pressENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
You might use the system restore to restore your system to an earlier time click start all programs
If it is a hardware issue the system restore might not work
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a serviceyou can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Nov 22, 2013 | Systemax Computers & Internet
Skype fatal error
What sort of error ? are you able to start your computer ?
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
If you want to know what this is the error code is related to
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
or click start type in event viewer press ENTER
or
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
If the problem is hardware related the system restore might not work .?
Sep 25, 2013 | Skype IM
What does 0x800ffff mean
KB1001.800
Problem: GWXMail error 0x800FFFF (or other) using REGSVR32
This article applies to GWXmail
Problem
    When you run regsvr32 with GWXMail to register it, you may get error 0x800FFFF or a generic message saying the registration failed.
Details
    Microsoft's REGSVR32.EXE program is used to register all Active X server components. If you don't have the most recent version of regsvr32.exe, or don't have all the correct support files to go with it, you may not be able to register your Active X component.
Solution
    Search your hard drive to make sure you only have one copy of regsvr32.exe. If you have more than one, delete all but the most recent. Check Microsoft's site for a newer regsvr32.exe, especially if you are not using IIS 4.x, or haven't applied the IIS 4.x service pack.
    Make sure you have version 05.00.4319(SP2) of MSVBVM50.DLL on your system. If you need this file, you may download it from here or from Microsoft.
Feb 13, 2011 | Computers & Internet
Error 0x8007045D - cannot transfer data - I/O device error
try deleting all restore points before attempting a system full backup. the system is protecting this area on the drive from being copied deleting the restorepoints will allow backup remember to re enable system restore after, do this by disabling system restore temporaraly while preforming backups.
Dec 22, 2009 | Televison & Video
Error: 0xC004D401 an unauthorized change was made to windows The security processor reported a system file mismatch error.
I suspect a program or driver for a hardware device was just installed prior to this error. Best thing to do is to use Windows Restore and use a restore point dated before the first occurance of the error. You may need to repeat this process choosing previous restore points until system is back to normal or you have run out of restore points.
Here's how:
Startup computer and go into safe mode (Press F5 key as computer is starting up but before you see the Windows logo screen).
Open your Windows Vista Start menu, select All Programs, select System Tools, and then choose System Restore.
Use the System Restore Wizard to choose a restore point/date that was created before the error started occurring on your Windows Vista computer.
Revert your system configuration to this same restore point.
If error still occurs and you had other restore points, you can repeat process with older restore points.
If you have gone back several points and still cannot, you may have not choice but to do a full Windows restore. This can result in a loss of data.
If you get to this point, re-post here for instructs on how to possibly save data before doing a full restore.
Bret
1-2-1ComputerServices
Oct 07, 2009 | Microsoft Windows Vista Home Premium with...
A Disk read error occured PressCtrl+Alt+Del to restart.
If you are getting a disk read error, you will need to use a program like spinrite to fix it or you will need to replace the hard drive.
This is one error you don't want to see. It means your hard drive is failing.
You will not be able to do a system restore as long as you get this error.
Sep 22, 2009 | Computers & Internet
Configuration error after trying to restore system
Go into system restore under windows system tools and rest your restore point to one prior to restoring your computer to original factory condition. Then wait until you can determine which configuration error is the problem and then restore to original settings. Good Luck
Nov 08, 2008 | HP Compaq Presario SR2150NX PC Desktop
Computers & Internet Logo
David Payne
David Payne
