Question about Ovens
Kitchenaid superba oven kebs207
How do I clean between the double glass panels on the door of this this model?
the dr
  • 447 Answers
SOURCE: KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Posted on Jan 02, 2008
SOURCE: Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Posted on Aug 13, 2008
  • 17 Answers
SOURCE: Whirlpool double oven - model RBD305PD82
Please take a look at the diagram if you think you want to do that.
if you still want to do it and need more details to disassemble feel free to email me. nguyen@ite.net
Posted on Jun 09, 2009
bozcro
  • 867 Answers
SOURCE: the inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Posted on Jun 27, 2009
heatman101
  • 43501 Answers
SOURCE: my kitchenaid superba double oven
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Sep 30, 2010
Jan 02, 2008 | KitchenAid KEBC277 Electric Double Oven
I used the self-cleaning feature and now my oven will not turn back on.
Their is a high limit thermostat that has tripped,on older model and on some newer models it has a red button on it that can be pushed in to reset it.Other times once it goes out it must be replaced.
For the upper oven its behind the control panel,for the lower its behind the grill between upper and lower oven
I hope this helps you to understand why your oven wont heat,
Gene
Aug 05, 2011 | KitchenAid Architect KEBS207S Electric...
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Grease between glass in door after self cleaning mode
As you can see on the diagram below, for the model in title, the door glass is sealed.
Gaskets and sealings are often not covered by regular warranty.
Call the manufacturer at the number listed on your owners manual to check if they can cover the door glass and sealing replacement.
You find all parts and diagrams for model listed in title here.
Mar 02, 2009 | KitchenAid Architect Series KEMC308KSS...
Superba oven removal
im not familiar with this particular model but on most ovens you shoud only have to open the doors and the screws that hold it in should be visible. generaly 2 on each side
Feb 20, 2008 | KitchenAid Architect Series KEMC308KSS...
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid Oven
I believe the entire door must be removed first. then remove every screw that you can find and draw a picture where they came from. then split the door open like opening a clam. then you may find additional screws to remove the glass
Jun 02, 2007 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
