Question about Panasonic PV-C1320 13 in. TV/VCR Combo
Auto programing without remote
I rented a Panasonic vesa and I do not have the remote so I need to auto program the channels
Kimi
  • 277 Answers
SOURCE: auto channel programming
The desgin of this unit is such that only the channel being recorded can be viewed. Try to manualy program channel 3 - p.25 in the user guide.. Good luck.
Posted on Jan 15, 2006
MikeNJ1964
  • 398 Answers
SOURCE: program timer light blinking
The timer light blinks when the AC power has been disconnected and the clock is not set. This is how the set warns you that it can no longer do timer recordings. Setting the clock and doing an autoprogram will fix it, but both the remote and the remote receiver must be working. If the original remote is not damaged and has good batteries in it but does not work on that set and you cannot get any other universal remote to work, then the remote receiver (the IR "eye") inside the set has failed and needs to be replaced. I have seen many of those little receivers failing recently. If you do not have experience changing electronic parts on small PC boards then have a qualified tech change it for you.
Posted on Jul 26, 2007
SOURCE: Tv Combo will not work with replacement remote
my panasonic tv model no. PV-DF2704, program light is blinking and I don't know how to cut it off. It is causing my tv to cut off. My remote control will not work. I bought it second hand. I program a universal remote and it works for a little while, but I can not set my tv for cable. Please help me if you can.
deborah from Louisville
Posted on Feb 26, 2008
SOURCE: panasonic omnivision tv/vcr combo
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
Posted on Aug 22, 2009
SOURCE: I lost my remote control for my tv/vhs panasonic omnivision
how do you access the menu without the remote panasonic omnivision tv vcr combo
Posted on Oct 21, 2009
How long does a TV have to be unpluged before it clears the programed channels?
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 08, 2017 | Panasonic PV-DF2035 20 in. TV/VCR/DVD...
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I have a panasonic pv 9451- is there a way to reset the auto programming for the channels? can i reset the vcr programmed information entirelyu and start anew?i think i programmed out channel 3 which is...
Should be able to use the remote to access the VCR menu, and setup the auto programming. If not automatically, then you'll have to do each channel manually. Just check all your options in the menu.
Usually all vcr's have the option of channel 3 or 4.
Apr 14, 2010 | Panasonic PV-9451 VHS VCR
Auto channel program
Universal remotes don't like combo units.If your original reomte worked before you lost it you are going to have to buy the original remote to solve your problem.
Jun 11, 2009 | Panasonic PVQ-2510 25 in. Combo
Mar 31, 2009 | Panasonic PV-C2010 20 in. TV/VCR Combo
My daughter brought her tv home from college without the remote. I'm now trying to hook it up to digital cable. It needs to be on channel 3. When I try to manually change the channel to 3 using the...
The easiest will be to make sure that the cable box is on and sending out a signal to Channel 3 and auto-programming the set. Channel 3 is skipped because the last time it was auto-programmed, there was no signal on that channel.
Dan
Jul 10, 2008 | Televison & Video
Nov 12, 2007 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Lost the remote, manually need to access Menu button
VCRs since the early '90s have limited function with the machine located controls, and a remote is necessary to get into most setup options, probably including the channel add/delete. Many VCRs do have an auto program mode which searches for active channels, but I'd guess this also is activated via remote. A universal remote which specifically has the capability of performing the advanced functions is probably available. Look here for an exact http://www.electronicadventure.us/panasonic.htm Part number is VSQS1418 according to this site for PV4501.
Aug 27, 2007 | Panasonic PV-7661 VCR
Auto channel programming
Jan 14, 2006 | Panasonic PV-M2048 20 in. Combo
Panasonic PV-C1320 13 in. TV/VCR Combo Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
