Question about Kitchen Ranges
Whirlpool gold accubake duo signature stove EO -FO- mean
catriver
  • 878 Answers
SOURCE: Clean cycle in oven doesn't work: FO EO
Oliversmom, Im not coming up with any information on the model number posted. However on the kitchenaid the F0 E0 is default for no error. Press the cancel button to put the range in idle state. Then in this order press cancel-cancel-start. See if an error code comes up different from the F0 E0. The F0 is what is throwing this whole deal off. If it was F1, F2, F3 etc...it would make more sense. See if you have a complete model number you can post along with the error code after doing the above key dance. We'll see if we can solve the issue....Catriver..post back.
Posted on Apr 03, 2007
  • 31 Answers
SOURCE: stove top works, display unit and oven does not
I would have to say that u need to remove the back painl and look for a ground wirer that is broken or burnt in half. make sur that u unplug the oven first.when u find the problem just replace the wirers
Posted on Feb 08, 2009
Macmarkus
  • 2605 Answers
SOURCE: The bottom element on my Whirlpool GOld
Hi, Are you equipped to check the bake element to determine if it's the problem ? You may be able to see if it has a burnt section on the element via a visual inspection. If so it is the problem, if not you'll need a multimeter or a pro technician to come and inspect it. With a meter you want to check the element for continuity (unplug the range and remove one of the wires at the element first) I will add the price of a bake element is cheaper than phoning for service "IF" you can change it yourself. Hope that help's you at least reach a place to make an informed descision on whether to attempt a repair on your own or call a pro. Thank's for visiting fixya. Please take a second to rate the info I provided for you today. Good luck in whichever way you choose. Macmarkus :)
Posted on Dec 11, 2009
Testimonial: "Haven't try the fix yet, but your response was very quick. Thank you."
localwonder
  • 6784 Answers
SOURCE: Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Posted on Dec 28, 2009
Testimonial: "Thank you so much. This is a job that my husband can do to fix it."
SOURCE: Whirlpool Gold Accubake System smooth top stove
I have had teh same issue. Not sure if its a design issue or that is just how it works. I have replaced the element, the thermostat and the control board and it still does the repeated cycling.
Posted on Sep 20, 2010
My whirlpool gold accubake displays an eo f2 light, what does that mean?
Disconnecting the power to an appliance resets the control module.
Feb 17, 2015 | Whirlpool Kitchen Ranges
My whirlpool gold accubake system display has eo f 2 ,my book is packed away for remodeling, so what do I do? Thanks
Hello & Welcome to FixYa
F2-E0 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Whirlpool Ovens
Whirlpool Gold Range Error code EO F2
On this website: http://www.repairclinic.com/0078.asp#Whirlpool , it shows all of the codes for the Whirlpool errors. Based on the remarks, if it shows a "4 digit failure code" it is "Shorted keypad"
"Replace Electronic Range Control/Clock (ERC)"
But verify this as I am not an appliance repair specialist. I am a computer nerd who just knows how to find information. I am actually trying to figure out an answer to my own problem with my Whirlpool Gold Accubake.
Dec 11, 2008 | Whirlpool GR773LXSS - Stainless Steel...
Oven not working on wirlpool accubake system
I have a Whirlpool Accubake System stove / oven. About 50 p% of the time I go to push the "Bake" and "Start" button, it goes to "Cal" or "EO -F2-" what ever that is. It won't let me clear it . Needless to say I am not happy with the fact that when I go to bake something, the oven doesn't work!!! Please help!
Oct 15, 2008 | Whirlpool Kitchen Ranges
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 | Ovens
Apr 03, 2007 | KitchenAid KERI201P Electric Kitchen Range
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
