Question about Denon AVR-485 Receiver
Show me a diagram on hooking up a surround sound receiver to a tv with no hdmi inputs denon avr-485 receiver sony kdl 46z5100 tv
webdevil
  • 43 Answers
SOURCE: HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Posted on Jan 06, 2009
SOURCE: hooking up an external audio source (IPOD) to the Denon AVR 3803
sure
just get a cable with phono plugs to mini phone connector Radio shack has them
Connect teh mini phone to teh earphone jack adn teh phono plugs to the aux inputs
select aux and enjoy
Posted on Jan 07, 2009
Gurudristi
  • 98 Answers
SOURCE: How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Posted on Feb 27, 2009
  • 3 Answers
SOURCE: connection problem with HDMI cables on Denon AVR-589
Hi dmsgolfer22,
If your Time Warner Cable box is old enough that it has a DVI output it may have HDCP (copy protection issues) with the receiver. If you are having to use a DVI to HDMI adapter to connect to your receiver (output from Cable Box to input on Receiver) then it's very likely your cable box may have may not output the signal because it detects the HDMI repeater in the receiver.
The two best options to correct this are:
1. Connect the DVI to HDMI cable directly to the input on the TV, you lose the convenience of the video switching in the TV, but it will solve the problem. Then connect the digital audio output from your cable box to the receiver, although you've probably already done this.
2. Contact your cable provider and check into the possibility of them swapping out your cable box for a newer model that would have an HDMI output. This would be the best option since the HDMI output on the cable box would give you both the Digital Audio and Video through a single HDMI cable.
Let me know how it works out for your, or if you have any questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Posted on Feb 28, 2009
SOURCE: No audio running TV through Denon AVR 1910
I had the same problem. You're not doing anything wrong. the thing is you can't (I don't know why but the owner manual says it) have sound going to your tv AND your HT speakers when you're using HDMI. You should try going to input setup, choose hdmi audio out to your TV instead of the speakers, and then run an optical cable from your satellite to your receiver, assigning it to the TV/Cable input.
Posted on Jan 20, 2010
How do I get HDMI cables to sync or talk to each other. We had this problem when we hooked up an Apple TV box to a Denon AVR-E400 and our Sony HD TV. We were told to disconnect all HDMI cables unplug
Personally I would use an RCA cable and hook up the AVR.
((RCA out of TV to AVR audio in))
((cable box HDMI cable output to TV HDMI Input1))
(As far as the AppleTv I would use a separate HDMI Input2)
If your AVR has a dvd or blue ray player Hook up a
HDMI cable out to another Input HDMI3 of the TV
using separate inputs on the tv will allow your surround system to be
used on all modes(CABLE,DVD/BLUERAY,APPLETV)
Sep 27, 2014 | Denon AVR-E400
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
Just bought a 46" Samsung
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
This is a site where you can download a manual. I'm not familiar with Denen however, you should be able to go out of satellite receiver(HDMI) to your receiver input(tv/sat) then to your HDMI input on tv. Your receiver might show video and sound through another port of receivers options, ie; video 1, video 2, etc. Check all putput options for your picture and sound. Hope this helps.
Mar 04, 2011 | Denon AVR588 Receiver
Denon AVR-2807 HDMI out signal
i seem to have a similar problem with my Denon AVR 4310CI . The output to my LCD TV just went green . On checking with some people , they suggested resetting . it didnt work . Any probable reasons
Feb 06, 2010 | Denon AVR-2805 Receiver
I have my PS3 and TV hooked up to the HDMI ports. I have programmed the unit to show them under TV and DVD respectivly. When I change the source to TV or DVD, nothing shows up on my TV as expected
Sounds like you hooked them both up to HDMI input ports. Make sure that the PS3 is connected to an HDMI input port on the AVR-1508, and that the TV is connected to an HDMI output port (not an input).
Oct 21, 2009 | Denon AVR-1508 Receiver
HDMI on PC but not on Denon AVR 3805 -
For this situation you will have to take audio output from the TV to an input on the Denon
Jan 11, 2009 | Denon AVR-3805 Receiver
Lots of components , need proper hook-up
I reccomend a Denon AVR-2809. It had 4 HDMI inputs, all 1.3a and higher, and one HDMI out for your TV!
Jan 07, 2009 | Audio Players & Recorders
Audio troubleshooting with an AVR Denon 900
ok i have the same reciver do you use hdmi to go to your tv or componet what ever you use there will be an audio out for rca on the cable box if you dont use a cable box keep reading but use hdmi to tcv then the rca audio out to the denon avr 900 obviously out it in the vdp/tv unput. and if you dont use a cable box your tv shoiuld have an audio output in the back of it for rca connect rca to audio output then other end to the denon avr 900s vdp/tv input
Dec 27, 2008 | Denon AVR-900 Receiver
Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Jan 06, 2008 | Denon AVR-2807 Receiver
Home theater set up
I want to download instructions to record tv shows while I am gone for a day or two,on my sony model#kdl-46xbr2. e-mail bmllrctg@yahoo.com
Dec 27, 2007 | Televison & Video
Denon AVR-485 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
