Question about GE Dryers
I have a ge dryer model no dde7110vmlwh won't turn on startor nothing
Won't turn on ?its dead
  • 5 Answers
SOURCE: Dryer won t heat 100 74732400 model
dryer element. Common problem easy repair.
Posted on Jun 07, 2009
heatman101
  • 43501 Answers
SOURCE: KNOBS WON T STOP TURNING, THEY WON T START DRYER
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Whirlpool dryer model LE5800XSW3
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Apr 14, 2011
Testimonial: "Hunters insturctions to my dryer problem was very prompt and helpful thank you"
TheMobilian
  • 8220 Answers
SOURCE: My Estate dryer won't turn on. I push the on
See if the lever on the door switch clicks. You cannot hear a click or the lever is missing that could be the problem. On the backsides of the dryer is a dust cover. Remove it and look for reasons why the duct fuse might melt and kill power to the door switch.
See the lever there? That must be in for the door circuit to activate the motor.
Manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 08, 2011
heatman101
  • 43501 Answers
SOURCE: Kenmore 70 Series Dryer won't
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Posted on Sep 19, 2011
Ge repair manuals
The fuse is a we4x800. It is mounted on the heater housing on the back wall of the dryer.
Apr 30, 2013 | GE DCSR483EA Electric Dryer
GE gas dryer won't start
you need a new motor
Apr 11, 2012 | Dryers
My ge dryer model DRS483ED1WW won't turn on all it does is buzz when I try. I have changed starter switch that didn't work
does the drum and motor turn by hand freely. but i think its possibly the bushes in the motor. just have a look at motor and see if theres black carbon dust on it, you will get this on a motor anyway but not in excess
Jan 06, 2012 | GE DBSR453EBWW Electric Dryer
Dryer model DBSR453EB1WW won't start. It has power and the light comes on when the door is opened, but when you try to start it there is nothing.
8_29_2011_7_53_41_pm.jpgYou might have a tripped high limit. Looks like this.
Mounts on rear wall atop the heater element. If the dryer needs cleaning it someimes will overheat and trip this limit. I recently repaired one of these and made some PHOTOS
Aug 29, 2011 | GE DBSR453EBWW Electric Dryer
Have a GE Dryer model DCL333EAOWW that will not turn on. Circuit breaker to wall outlet fine. Thought it might be switch behind 1/4 turn knob you use to turn it on. Replaced switch. Still won't start....
heatman101
Jul 29, 2011 | GE DCL333EA Dryer
My GE DHDSR46 gas dryer won't start, what should I
505 is the thermal limit.
Looks like this:themobilian_2319.jpg
Hunt for junk and clean that out, then replace this fuse if it is bad.
See the white button to the right of the driver?
Thats the door switch, if open, that dryer won't run.
More Here
May 07, 2011 | General Electric DHDSR46GGWW Gas Dryer
heatman101
Dec 30, 2010 | GE DRSR483GD Gas Dryer
Change belt
do you have the belt route right, on them models they have a safety switch the idler hits and if it is not activated it wont turn
Jun 24, 2009 | GE DWSR463EGWW Electric Dryer
Dryers Logo
23 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
