Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
Hayward pool pump for S-200 filter only hums and then blows the circuit?
    President:
  • 1,489 Answers
The motor winding is probably shorted -- needs rebuilding/replacing.
Posted on May 31, 2009
Why is my pool pump not pumping, only humming
had the pump running at 1 point without being primed and burnt the pump motor up.
Jul 18, 2014 | Hayward EC-40 DE Pool Filter with pump
How much sand do you add to a Hayward Sand filter S-21OT
200 pounds of sand make sure you use pool filter sand make sure not to get sand in pipe
Jun 27, 2014 | Hayward SAND FILTER, PRO SERIES
Hayward Pro Series Model # s2445
either broken lateral or crack in pipes inside try vacuuming up if same bad filter
Jan 30, 2013 | Hayward SAND FILTER, PRO SERIES
My hayward 1hp super pump hums when i turn it on but doesn't turn or pump it eventually trips the circuit breaker inside
Inside pump is a difram , it most likely is stuck, some times if you shut off pump, turn back on a few times it might release itself, but most likely needs to be replaced. Let me know, mike from fixya.com
Jun 08, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
My Hayward Super II Pool Pump isn't priming. The
I think your impeller may be stuck OR your start capacitor has failed. Your pump is going off on over load because it cannot turn or cannot start.
Thanks for your interest in FixYa.com
May 14, 2010 | Hayward Pool Products Hayward Super II...
How do I chabge the sand in my s-200 Hayward sand
take top off open bottom drain use a small wet vac hose to get as much out through top out be careful not to damage filter bars wash the rest out through bottom drain with a garden hose
Jul 02, 2009 | Hayward SAND FILTER, PRO SERIES
New 1.5 hp super pump hayward, blows circuit when turned on...
Recheck your wire connection on the motor. You likely put both your line wires on the same terminal. If not, try finding a local warranty center for a repair or replacement... http://www.haywardnet.com/locator/
Jun 11, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Hayward above ground pool pump will not start.
sounds like the windings in the motor are shot! but does it have a capacitor? if it does you could simply have a bad starting capacitor so don't let it hum for that will surely scar the windings
May 31, 2009 | Hayward Pool Products Economy 1 Hp Above...
How to change sand in Hayward S-200 Sand filter
hayward S-180 filter takes 150lbs, S-210 takes 200lbs not familur with the S-200. To change sand you have to remove the vari flow valve on top. You can either unplumb the filter and roll it over on its side and try washing the sand out or try scooping it out upright. Whatever you do dont damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. I always fill the filter half full of water to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand!
Apr 27, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
306 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
