Question about Groco PJR-A 12V Paragon Junior Water Pressure System
Water tank dry. filled it. Now pump motor runs but no water
  • 3,368 Answers
It sounds like a plugged filter. The manual is at: http://www.groco.net/SVC-MAN-07/Sec2/pdfs/PJR-PJRA.pdf
It explains exactly how it has to be set up.
Posted on Jun 17, 2014
Water not pumping from the tank
If the pump is primed, water will come out of the tank when the pump is running. It make take a little time for the tank to fill, but you should hear the pump making some noise. An un-primed pump just makes a motor noise, not very loud.
Aug 12, 2015 | Plumbing
Big rainwater tank ran dry and so electric Onga pump that normally pumps water from big tank to little overhead tank kept failing. Have since refilled big rainwater tank, but pump keeps failing. Have
Release AIR lock. Air has got trapped in the pump hence it cannot create necessary level of suction. The way normally you do this by filling the water path of the pump with water and get the air released.
Oct 12, 2014 | Plumbing
Why does Grundfus bell pump dry runs won't turn off?
If you have a switch of some sort to tell the pump the house needs water, look there first.
Aug 29, 2014 | Plumbing
Fresh water and pump is on but no water is coming from taps
Does unit use water ONLY from pump? If so, make sure pump is actually running by feeling the pump. Is it emitting a small vibration? That is normal and probably means pump motor is running normally. If pump housing is excessively hot, pump may be locked up. If all appears normal and still no water, most likely culprit is broken impeller inside pump "Wet End" housing. Try disconnecting INLET hose to pump and check for presence of water. If none, pump is not your issue, your tank is dry. Also check pump OUTLET (pump off) for water. Disconnect hose, switch pump on momentarily. If pump discharges water here, you have a crimped or stopped up line or possibly a stopped up filter, if so equipped.
May 03, 2014 | Crossroads 2014 Rushmore Franklin
Not spraying water and solution
Tanks may be empty or not properly seated.
-Fill up the bladder with hot water and the solution tank with proper cleaning liquid.
-Remove and reseat both tanks
Pump may dry, needed to prime.
-Turn "off" power wait for about minute turn "on" power and depress spray trigger.
Check and clean filter on the deck (under the clean water tank, a red slotted plastic screw)
If nothing works you have to open the deck cover and go into details: check the pump, its a 12V DC motor, the solenoid, its a valve which operates with 120V, the hoses for broken or pinched part, the diode bridge (creates about 12V DC for the pump if the vacuum motor is turned "on" and the secret fuse (3,15A under the heat-shrink series to the diode bridge, if this one goes, no power to the pump!)
Mar 09, 2014 | Bissell ProHeat Pet Upright Deep Cleaner,...
How do i reprime ?
Close the supply valve to the tank. Open the priming port of the pump, (plug on the upper most part of the casing) pour in water until the pump is filled -up. Close the plug just finger tight. Run the pump. slightly open the plug just to bleed the air with little water. If all water is coming out, the pump motor should cut-off indicating the pump is already primed. Gradually open the supply valve. Pump motor will restart again.
Nov 12, 2012 | Fresh Water Systems WellMate Tank Fittings...
Onga water pump not pumping water thru to house
either water lock or motor burnt out ,
Mar 17, 2012 | Plumbing
The clean light keeps blinking and won't run new cycle
Whirlpool & Kitchen-Aid
Tall Tub Dishwashers
PROBLEM: STOPPED RUNNING, WILL NOT START AND CLEAN LED BLINKS 7 TIMES, THEN REPEATS (WATER HEATING FAULT)
Control is programmed to stop running and not allow any further
cycles if it detects a water heating problem (no temperature
increase detected in heated Main Wash cycle or in 3 consecutive
cycles on the latest software version). Control blinks the Clean
LED 7 times repeatedly and disables the Start/Resume key until
cleared.
Running Diagnostics clears the control and allows it
to operate again. The water heating condition
must be corrected or the control will stop
running again. See potential causes below.
Check If…
Heater circuit problem:
♦ Open heater.
♦ Wire disconnected, open connection or component
in heater circuit.
♦ Faulty heater drive circuit on control.
Then…
1. Check operation of heater in Diagnostics cycle.
2. Unplug dishwasher or disconnect power.
3. Check resistance of heater and all components
and connections in the water heating circuit or heat
dry circuit.
Door switch not making contact consistently:
♦ Misaligned door latch assembly (which can be
aggravated by high door closure force keeping
strike plate from fully seating).
♦ Faulty door switch (high resistance).
♦ Loose or missing installation anchor screws,
causing tank to shift in cut-out.
NOTE: Neutral switch on plastic tub models is only in series with
the heater; other loads are not affected.
1. Unplug dishwasher or disconnect power.
2. Measure resistance of door switch contacts while
checking mechanical operation of latch assembly.
Confirm switches not loose from assembly. Check
strike plate and door closure.
Wash pump not pumping water past the heater efficiently.
• Foreign object in pump
• Excessive foaming
• Clogged pump screen or broken chopper screen
• Loose electrical connection in motor circuit
See Tech Sheet “WASH PUMP WILL NOT PUMP”.
Lack of water to heat. (Unit not filling properly)
• Insufficient water supply pressure
• Fill valve screen blocked or valve not opening fully
• Loose electrical connection on Fill Valve.
• Float switch obstructed or functioning abnormally
See Tech Sheet “WILL NOT FILL OR LOW
WATER”.
Diagnostic Key Dance:
Heat Dry - Normal - Heat Dry - Normal or
High Temp - Air Dry - High Temp - Air Dry
HOPE THIS HELP
Jan 24, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Dishwasher problems
The washer may be attempting to run dry. Many times on these washers, a person may open the washer and then go to another load. The washer gets stuck with a dry pump until the timer tells water fill valve to open. Easy test. Start on regular cycle ,slowly advance the timer. it will click until you here the fill start and water will fill until.....
Jul 06, 2008 | GE Dishwashers
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Groco PJR-A 12V Paragon Junior Water Pressure System Logo
50 people viewed this question
Top Groco Plumbing Experts
Donni Steen
Tom Chichester
Are you a Groco Plumbing Expert? Answer questions, earn points and help others
