Nokia 6600 Cellular Phone
Problem for Nokia 6600
Not able to send message
By geeks on Oct 11, 2007
I am not able to send message from my nokia 6600.  I get the report as message sending failed & unable to send text message.
Same Problem
Nov 20, 2008
-   I have a Nokia 6110 Navigator
I try and send a msg, it just keeps trying to resend then comes up with
"Unable to send message, general memory full close some applications and try again"
I have enough memory and have restored back to factory settings.
please hepl-   jazzydzioba
Mar 08, 2008
-   I cant also send messages, everytime i send messages, the message sending failed will come our or resend at XXXX..i dont know whats the problem..:(-   arielbacol
Feb 29, 2008
-   I can't able to send message!@!!!
THE message is just the memory if full close some application
-   Guest
Jan 20, 2008
-   nokia 3250
"General:memory full. Close some application and try again"
wat should i do........-   Guest
Jan 10, 2008
-   I cant send sms thru my N6600. I get a msg of General: Message Memory Full try to close some application and try again. But there are no application opened. My msg center # is correct and also the other message settings are correct, i also tried removing the memry card but it doesnt work also. What will i do.
thanks
Irene
-   dyords
Best Solution
posted on Mar 08, 2008
Very Helpful)
dobhan
Rank: Guru
Rating: 90%, 166 votes
First you haved to format your unit and your memory card,by formatting your unit pls follow this simple step,press # *7370# you have to enter your 5 digit security code the default code is 12345. by following this procedure will solve all your problem,especially is WD2 series .hope it will help........
Comments:
Mar 08, 2008
- sorry the code it should be * # 7370 #....thanks.....
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #2
posted on Oct 23, 2007
Very Helpful)
gizmo11
Rank: Wiz  Nokia Expert
Rating: 80%, 584 votes
if you are unable to send the sms from your hanset you need to check some of the settings on your handset like.messgae center no..,and you will get this no form your service provider ...after refreshing the no you would be able to use your msg service
Was this helpful?
Yes
No
Solution #3
posted on Jan 28, 2008
Helpful)
the little j
Rank: Guru  Nokia Expert
Rating: 87%, 217 votes
you can try gormatting your phone to clear off all the data...to do this you must press the star button, call button, three,and the power button all at the same time while powering up your phone, a formatting should appear and then wait until it finishes then try sending again
Comments:
Jan 28, 2008
- you can try formatting your phone to clear off all the data...to do this you must press the star button, call button, three,and the power button all at the same time while powering up your phone, a formatting should appear and then wait until it finishes then try sending again
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Oct 11, 2007
Somewhat Helpful)
PungaA
Rating: 84%, 125 votes
Check you phones settings according to the settings given to you by your provider. Give them a call to verify everything is in order.
Can be found on your handset under : Messages - Options - Settings
Was this helpful?
Yes
No
Solution #5
posted on Apr 29, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Cool site! The cheapest price for adipex - adipex, [url=http://adipex.wetpaint.com]adipex[/url]. chemodanopilok url:http://www.fixya.com/support/t218179-not_able_send_message(442503502):)
url:http://adipex.wetpaint.com
email:adipash@msn.com
message:Cool site! The cheapest price for adipex - adipex, [url=http://adipex.wetpaint.com]adipex[/url]. chemodanopilok
Solution #6
posted on Apr 10, 2009
Very Helpful)
fawadkhan786
Rank: Apprentice
Rating: 100%, 3 votes
Thanks to Dobhan, Solution 1, which states
First you haved to format your unit and your memory card,by formatting your unit pls follow this simple step,press *#7370# you have to enter your 5 digit security code the default code is 12345. by following this procedure will solve all your problem,especially is WD2 series .hope it will help........
So i did the same thing with my nokia6630, and it solved the problem, but i lost my sms and contacts, so before doing this just safe ur data in memory card, but it worked, now i can send sms. thanks
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #7
posted on Jan 30, 2008
Very Helpful)
kimidake
Rank: Apprentice
Rating: 100%, 1 votes
went to a cellphone repair shop. they reformatted my cellphone and install antivirus called kabirfix and anti commwarrior. now my cellphone is fix and works properly again.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #8
posted on May 03, 2009
Not Rated)
teroc
Rank: Master
Rating: 91%, 14 votes
Having problem with Nokia 6600? Don't Worry. There is a site where you can easily fix your problem.
Mainly Nokia 6600 problem is for Unlock CodePuk Code and other Lock Codes. If you are searching for such codes you Must Click Here.
There are also some problem with Nokia 6600. Such as software problemhardware problem etc. If you having these problem you can Click Here. May you find your solution.
Was this helpful?
Yes
No
Solution #9
posted on Nov 14, 2008
Not Rated)
bhaveshchavd
Rank: Apprentice
Rating: 0%, 0 votes
nokia 6600 mobile full format for sof pc
Was this helpful?
Yes
No
Solution #10
posted on Oct 02, 2008
Not Rated)
noch_johnson
Rank: Apprentice
Rating: 0%, 0 votes
ok after reading all these blogs and talking to several att customer service reps none of them could tell me what was wrong with my phone.
i have the nokia N75 and all of a sudden i was getting the "unable to send message" error
no matter what the customer service had me do and how many times i had to restart my phone with different variations....... nothing worked. i kept getting the "memory full close some applications" ********. so i bit the bullet and tried the *+3+send at the same time while powering the phone and it worked. it formats the phone and you loose everything including your contacts but it works. back to sending text again!
i have a previous backup of the phone on my computer so i just restored my phone to before i was getting the "unable to send message" error and it worked. i didn't loose any of my info and am able send text again.
Was this helpful?
Yes
No
Solution #11
posted on Jul 06, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Format ur fone. how? press and hold the green button for calling and * and 3 and the power button together and wait for the formatting word to appear on the screen of your phone.
Solution #12
posted on May 24, 2008
Not Rated)
junia
Rank: Apprentice
Rating: 0%, 0 votes
hi I have a nokia 1110i, I know it's archaic but I am unable to send any text messages. Could you kindly help me. my email is dzunya@yahoo.com thank you in advance.
Was this helpful?
Yes
No
Solution #13
posted on Mar 31, 2008
Not Rated)
lukeywelch
Rank: Apprentice
Rating: 0%, 0 votes
Update to the latest firmware (v21.0.016) seems to have sorted it out. this firmware addresses the RAM issue which i was told is causing this error.
Was this helpful?
Yes
No
Popular Solutions for Nokia 6600 Cellular Phone
Questions and Unsolved Problems for Nokia 6600 Cellular Phone
Do you recommend Nokia 6600?
Answer
Answer
i have a htc smart phone and i put a password on it and forgot it
Answer
ATT Nokia 6085. Power up seems ok, sounds etc. Except screen is washed out white/blue. Close ****... (More)
Answer
my IMEI code is 357952009223323. What is the code for 3d motoracing for me?
8 Other Users Have The Same Problem - Continued
Comment by tinvictoria, posted on Jan 08, 2008
Comment by kimidake, posted on Nov 09, 2007
my nokia 6600 phone suddenly stop sending sms and it also displayed 'general memory full, close some application and try again' even if theres no application to be close. i've also checked the msg center No. and is correct but still i cannot send sms.. can anybody help?
Comment by antoyni, posted on Nov 08, 2007
my nokia 6600 cant send messages, message displayed 'general memory full, close some application and try again' even if theres no application to be closed. . .
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nokia 6600 Cellular Phone:
Top Cellular Phone Experts
Rank: Guru Guru
Solutions: 567
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Cellular Phone Experts
Top Cell Phone Repair
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
