Question about Kenmore 54501 Dehumidifier
Unit will run but will not kick in to remove moisture
It will continue to run the fan all the time but does not get any moisture from the air
  • 148 Answers
The compressor sounds like is not coming on check the refrigerant or check the power to the compressor it could be something as small as a humidistat which will not tell it that we still have humidity like a thermostat
Posted on May 10, 2009
Unit comes on briefly then kicks out bucket without getting any water out of the air. Basement is very wet
Hello friend, I appreciate your post!
From my understanding your Frigidaire dehumidifier is shutting off and on without removing any moisture from the air. I would recommend trying a different outlet within your basement and adjusting the setting to see if that would help. Additionally, try to turn the unit on continuous drain to see if it pulls any moisture out of the air. If your appliance continues to shut on and off I would reach out to the manufacturer to see if they could assist with any additional resolution. Hope this information proves helpful. -Matt
Aug 24, 2014 | Dehumidifiers
Fan runs and the compressor tries to kick on and there is a low grinding sound and then it goes off and the fan continues to run. The cycle repeats itself and the compressor never engages. It is not...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 03, 2011 | Goldstar DH504EL Dehumidifier
Model BHD 651-C Serial 611TA000375 Problem: Unit comes on, fan operates but compressor is not kicking in. While the fan operates it is not pulling any moisture out of the air. Controls indicate that...
heatman101
Jun 09, 2011 | Comfort-Aire BHD-651 Dehumidifier
My dehumidifer is not drawing any water, but the fan continues to run.
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture. humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Haier 45-Pint Dehumidifier
My Kenmore dehumidifier has stopped drawing water from the air to the collection receptical. Fan still runs at high and low speeds.
A couple of things may be happening: The humidity extraction level may be set to high and it can't extract any humidity at that level. Reset/Lower it to 35%. The fans on most dehumidifiers run almost constantly (designed that way) so that it keeps moving the air around. If the sensor picks up a higher humidity level than what it's set to maintain, the compressor will turn ON. This is particularly true, if you operate the unit in continual mode, rather than a timed mode. Also, a dirty or clogged air intake filter, hinders the units ability to remove humidity/moisture.
In addition, operating the unit is ambient air temperature of between 40 & 60 degrees F, causes the unit to struggle to dehumidify the air and the fan to run continuously. Obstructing the air flow around the unit, will also cause it to not function as it should. Maintain a minimum of 12" of free air space around all 4 sides of the unit.
Hope this helps you troubleshoot and solve the problem. Please let me know.
May 28, 2011 | Kenmore Dehumidifiers
Compressor and fan both kick on when starting. Frosts up (normal for this time of year) but then compressor stops but fan continues to run but compressor does not start up again....
From what you have described, it sounds like the defrost sensor may be bad. However, if you're operating the unit in a temperature of 40 degrees or lower. That's the problem. If in a basement application, keep in mind the floor temperature is lower than the air temperature.
Also, cleaning the air intake filter on a regular basis will help.
Hope this helped you. Please let me know.
May 16, 2011 | Edison 40 Pint Dehumidifier
106.57 fan runs does not work
It is dry this time of year. There may not be any water to pull out of the air.
Chris, as you may know, a dehumidifier is nothing more than a 'de-tuned' AC unit in a small package. If you are sure you have excess moisture in the air, (ideal humidity is 50%) and you have tried running a fan to circulate the air where the unit is located, your unit may require professional service.
Thanks for your interest in FixYa.com
Dec 26, 2009 | Dehumidifiers
(New Unit) Motor Runs, Does Not Extract Moisture
Try setting you temperature or fan speed lower this may help.
In order for the unit to remove moisture the coil has to be below the dewpoint.
Aug 02, 2009 | Haier HD451E Dehumidifier
Dehumidifier not removing moisture
could have overheated the compressor if the filter was really dirty and blown it
Jun 20, 2009 | Maytag M3DH30B2A Dehumidifier
Will run but won't take moisture out of the air
It sounds as if the fan motor is running, but the compressor is not.
Apr 05, 2009 | Maytag M3DH30B2A Dehumidifier
Kenmore 54501 Dehumidifier Logo
425 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
