Broken thermostat for the Charmglow HBL-15SDLP/M20
My thermostat is broken and the unit won't work at all. Where can I get the new part?
    New Friend:
  • 25 Answers
You can get your parts at this web site.................www.grillstuff.com......scroll down to CHARMGLOW parts..enter your model # ...they will ship the part to you...I was just at that web site to verify.....GOOD LUCK..!!!
Posted on May 09, 2009
Charmglow electric heater blown fuse
Fuses blow for a reason. Almost every time there is a high amp draw due to many possible reasons, power is to unforgiving to gamble.
Oct 25, 2012 | Leisure HOMEPRIDE Electric Fireplace...
Tip
Common heating faults with Bosch HBL 442 / HBL 446 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 442 / HBL 446 Electric Single...
Tip
Common heating faults with Bosch HBL 742 / HBL 746 single oven
on Jan 19, 2010 | Bosch HBL 742 / HBL 746 Electric Single...
I have a new ptac that won't cool, why?
The condeser fan blade is broken. I work at a place where 75% of these units have cond. fan broken in same place.
Mar 22, 2012 | Amana PTH123B25AJ Heat Pump Air...
I have a Goodman gmp100-3 furnace and a/c unit. The outside fan and compressor are working but the inside blower won't come on Any Help ?
try putting thermostat on fan only see if it runs,if not check for any broken or loose wire on the thermostat wire take cover off and check.
Jul 17, 2011 | Heating & Cooling
A power spike broke Dell Precision M20 motherboard
Hi there!
Yes it really does damage the motherboard when that kind of things happen.
You'd rather replace the motherboard than repairing it.
Hope this helps!
Feb 13, 2010 | Dell Precision M20 Notebook
I have a Charmglow model HBL-15SDLP/M20 electric heater. The rocker switch went bad on it and I can't find a replacement part anywhere. The manufacturer said they can't get replacement parts. The part...
The switch itself is a (double pole single throw ) 15 amp 250 volt /20 amp 125 volt.You can buy any switch like that.The hard part is trying to find the same size to fit the hole in the heater.
Apr 04, 2009 | Heating & Cooling
Broken thermostat on Danby DCF1019W chest freezer
Take your model number of the unit to your appliance parts house and they can cross reference the t-stat. you could try this web site to see if you can find one
http://www.wsconet.com/
Feb 01, 2009 | Danby (DAR604BLS) Refrigerator
Tip over switch
I have a free standing electric fireplace model HBL-155DLP/M20 serial number 20060731282 manufacturer number 16496. The lights still come on, however the heating element does not, and the blower has stop working, it there a fuse on this or does the circuit board have to be replaced?
Dec 02, 2007 | Coleman (5040B750) Patio Heater
Heating & Cooling Logo
1,001 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
