Question about RCA 9" Portable Dvd Player With 9" Lcd Screen And Travel Kit drc99392
Spinning rod not working properly drc99392 - RCA 9" Portable Dvd Player With 9" Lcd Screen And Travel Kit drc99392
My Simpson eziset 750 will keep pumping even after water is gone and wont go onto next stage which i think is spin etc, can any one help me with what might be wrong thank you
the program is empty , then spin in stages and rinse, at the same time pumping then stop rinse water then spin up to speed while pumping right to stop at end of cycle
If it doesn't get to full spin then there is a problem in the program board not progressing
call a technician for a proper diagnosis
oh and for your future information , if you have a balance problem , it will be the suspension rod ends broken off and not allowing the pneumatic motion absorbers to work correctly Replacement cost is $88.00 aud and you can do it yourself one rod at a time
there are 3 blue ones and one white one so make sure that you replace color for color then sure that the bowl is level by pulling out the agitator strainer unit and using a short level across the top of the agitator
just done the repair myself , took about 1/2 hour by myself
Apr 23, 2017 | Simpson Washing Machines
I have a top load samsung washer and for a while now it will give me a dc error code and won't spin all the water out of the clothes? Need help thank you
If your Samsung top loader is starting to spin, but stops after a minute or two, and starts to fill up with water again... and then after 3 times of doing this, it errors out with a DC error code, the problem could very well be with the support rods. The springs in these rods will get weak over time and allow the drum to become unbalanced during the spin cycle. Fortunately, the 4 support rods are very easy to take out and replace. And sometimes, they just need to be greased properly. I had a service technician replace my support rods, but he didn't grease the top and bottom bushings first, so my machine still wouldn't spin properly. After he left, I pull one of the support rods out, cleaned out the dried up grease where the support rods lock in, and applied a liberal amount of white lithium grease to the top and bottom bushings on the support rod. I then put it back in. I did the same for the 3 remaining support rods. Now the support rods were able to move very freely in their holders, which is necessary during the spin cycle. My machine now spins like it is supposed to and I don't get the re-fills and DC error code anymore. This webpage, http://www.appliancepartspros.com/samsung-assy-damper-owm-dc97-16350c-ap5623264.html , contains a video that shows you how to remove, inspect and grease your support rods properly. It is not hard to do, but can be a bit messy. Have gloves and/or cleaning rags handy. And if you do need new support rods, this place has them cheaper than you can get them from Samsung!!!!
Dec 14, 2015 | Samsung Washing Machines
How do you clean laser on rca portable dvd dcr99392
first of all never touch the laser. Second never use rubbing alcohol Electronics technicians use a special alcohol on some things but not on lasers anyways. The only thing you can use is canned air
Nov 27, 2013 | RCA 9" Portable Dvd Player With 9" Lcd...
How do i replace the outer tie rod on my van
Very simple. 1. Remove the front wheel 2. Take the proper size wrench and loosen the nut on the tie rod and rack and pinion 3. Remove the cotter pin from the castle nut where the tie rod goes through the spindle(hub assembly) 4. Remove the castle nut and hit the area where the joint goes through until the shaft comes loose with a hammer 5. spin the outer tie rod off counting the number of spins 6. Reverse this procedure to install. If you need the inner tie rod(inner socket), let me know and I should be able to find a diagram and instructions.
Mar 30, 2010 | 2000 Chevrolet Venture
Washing machine not spinning properly
indicates that the suspension rods ( top loader ) or bearing supports ( front loader ) need replacing as the bowl is not level
Jun 24, 2017 | Zanussi F1245W Front Load Washer
I have a lg mod no wd8074fhb the prolem is it is out of balance on the spin cycle
could be the main bearing.
I believe.... that there is a spider like clasp that goes around the rear of the drum. This has a rod which comes out the back of the spider and is inserted into the main bearing. This bearing is like a circle of metal so that the rod slides into it and can spin.
If the machine is not spinning balanced properly then this rod/spider or bearing may be broken/worn. My repair man told me it would cost 120$ and 2-3 hours work. I'm going to look at it myself and see how hard it is to replace the bearing (which he said needs to be very accurately in centre.).. .
Sep 25, 2009 | LG Washing Machines
Washer spins but out of balance
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 18, 2009 | Kenmore Washing Machines
Wash machine spinning off balance
Jan 01, 2009 | Washing Machines
Will not dispense water or solution
On the bottom of the tank is a valve, push it in and see if water comes out Where the tank sits, there is a black round seal, is it in the proper place? The rod in the handle hits just under that seal, with the tank off, you can see if the rod is movin up and down when you depress the trigger. The resevior asm. may be bad, that is what the tank sits on.
Mar 10, 2008 | Hoover SteamVac F5914-900 SpinScrub...
RCA 9" Portable Dvd Player With 9" Lcd Screen And Travel Kit drc99392 Logo
15 people viewed this question
Top RCA Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jeff Turcotte
Jeff Turcotte
L Pfaff
L Pfaff
Are you a RCA Car Audio and Video Expert? Answer questions, earn points and help others
