Question about Microsoft Xbox 360 Console
Xbox 360 Will NOT turn On?
Ok hears my prob. I repaired my xbox 360 2 red ring E74... now in the process of doing so I changed out the X-clamps for screws put it back together.. and turned it on and it then went off and will not turn back on??? WTF do I do now???
  • 3 more comments
  • Joshluda May 19, 2009
    Ok this is joshluda with the xbox 360 (that will not power on)... Now by processors do you mean GPU & CPU DWDpcRepair? If so then I do got a 25watt Soldering gun... now do I just put it on-to the processor directley and after that then what? Thanks bro
    consloe king to your answer yes I did apply silver thermal paste and re connected the heat sinks.... but it just will not power on... and the power supply is working perfectly.... thanks keep the answers coming guys thanks!
  • thomas hinks May 11, 2010
    right so the problem, maybe with the power conecter at the back of the xbox 360
    did you apply thermal paste on the chips if so there may not be enough paste on them
  • DWDpcRepair May 11, 2010
    your processors might need to be reflowed. this can be done with a heat gun but you risk frying your board if overheated.
    Novelist:
  • 174 Answers
Your processor needs a reflow. A BGA reflow station is the best to use, heatguns can blast heat everywhere, but a professional station will concentrate it onto the required area.
FixMyConsole
Posted on May 19, 2009
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
How to fix xbox 360 "red rings of death"??
How to Fix Red Ring of Death - A Step by Step Action Plan
Remember to rate me a 4 out of 4 thumbs up thanks
1) Disassemble Xbox 360 Case
Obtain your case separately. By a fine tip screwdriver, poke the grayed out holes and back of poke the small rectangle holes. Get the Faceplate Off and move the latch up on the DVD drive up as you remove it. Unscrew metal case which is under the plastic case.
Following is the image of video (How to disassemble xbox 360 case) which comes with James Dean's Professional Xbox 360 repair guide. If you are not comfortable with instruction you can use this video to disassemble your Xbox 360 case.
Click On Above Video Image To Watch Video On How To Your Repair Xbox 360
2) How To Remove Motherboard Safely
Unplug all cables connected to motherboard and associated small devices and take DVD drive out. After DVD, get the fan and motherboard out of the xbox 360 case. Make sure you do this gently.
Following is a quality video which can show how you can remove motherboard safely.
3) Crucial Motherboard Disassembles.
Turn the mother another side, using the screwdriver snoop off the X-clamp which you can find under heat sink. Check out following an image of a video which came with Xbox 360 repair guide which will make your process easy of "snoop off the X-clamp".
I will suggest you to do this step very gently if you are not comfortable doing this refer following video which comes with James Dean's 360 repair guide.
4) Heat Sink Unscrewing.
After snoop of X-clamp you have to unscrew heat sink to obtain CPU and GPU.I will advice you don't hurry to finish this work, please follow all steps else it will damage your xbox 360. If you are not confident do use Professional Xbox 360 repair guide.
5) GPU And CPU Cleaning.
Next step is to clean GPU (graphic processing unit) and CPU (central processing unit) If you do this step right it will help to stop xbox 360 freezing. This is very important and critical step so just make sure you do it right.
6) Appling Arctic Silver
Now you have to apply arctic silver thermal compound gently over GPU.
You will get this arctic silver thermal compound in any computer hardware shop for $1-$2.
Set it for 15 to 20 minutes then place 2 nylon washers on each screw on the heat sink then place the screws back in motherboard then add two more nylon washers to screws.
Then,
Place the heat sink on the peak of screws then push them down slight, finally screw them up. Try to make it reasonably tight.
Get everything back together and see everything is fitted properly. Now, Turn your Xbox 360 on.
I always like to educate people so I tried to describe a whole process in my words, Videos can make this whole process lot easier. I will suggest you to check out James Dean's Xbox 360 repair guide(Click Here To Visit) which will surely help you out to fix your XBOX 360. Also I have done a detail review of James Dean guide below, so don't forget to check it out if you need a pro help. please rate me high thanks
Jan 04, 2011 | Microsoft Xbox 360 Console
I have the E 74 error how do i fix it?
Basically, this problem is caused by overheating, which is often an issue with most high-powered electronic devices.
As heat levels rise inside your Xbox 360 the connection between the motherboard and the video scaler (HANA/ANA) chip is damaged due to the expansion and contraction of the metal connectors.
Once you have experienced the red ring of death e74 once on your Xbox 360, it will continue to happen over and over again until you fix the problem permanently.
The process of repairing the Xbox 360 red light e74 involves opening up your console, removing the hard drive and disk drive (as these get in the way when you are navigating around the narrow confines of the case) and then locating the video scaler chip.
You then remove it from its seating point and clean the connections; an eraser works well for this. It then has to be seated correctly back in its slot. Once this is done and the hard drive and disk drive are re-installed you can put the case back together.
When you turn your console on again it should be free of the e74 error.
Good Luck and have a nice day.
Jun 07, 2010 | Microsoft Xbox 360 Console
Red ring on my xbox360
I recently had the E74 system error (1 red light) which started with as ‘black snow’ on the screen. There is an extended 3 year warranty that covers E74 and 3 Red Lights/RROD errors only. It seems to have been put down as a graphics chip and/or over heating problem.
I looked in to fixing it myself but thought might as well let someone else graze their hands getting the case off!
Despite the horror stories of it taking forever MS seemed to have pulled their finger out and made this a very efficient process, I got mine back within a week (I live in the UK and repairs get shipped to Germany).
Here's a quick breakdown of the process:
1. Go to www.xbox.com/support and click on the relevant link relating to your problem.
2. Go through the walkthrough. THIS IS VERY IMPORTANT AS IT COULD JUST BE A LOOSE CONNECTION. If you've still no joy you can click a link to pick whether you are a US resident or not.
3. Type in serial number of the console (you don't need any receipts, I bought mine off eBay).
4. They send you a shipping label and a link to arrange UPS to come and pick up your console.
5. Bite your nails and rock manically in a corner until your console comes back (you can track the whole process at xbox.com).
I've sent back a first generation 360 and an Elite. Certainly worth considering as they will repair or replace your console!
http://support.microsoft.com/kb/907534 3 Red Light (Red Ring Of Death/RROD)
http://support.microsoft.com/kb/941377 E74 Error
If you want to attempt to fix the error yourself (and have no guarantee of sorting it and invalidate your warranty) search YouTube for ‘E74’ fix or ‘xbox towel trick’. This is supposed to overheated the console and re-solder dry solder joints. Only try if your warranty has run out and/or you own a bricked console!
Please rate me if any of this helped J
Dec 07, 2009 | Sega Video Game Consoles & Games
Xbox 360 Elite - Ring is flashing red (1/4) of the circle- E74 error coming up
I recently had the E74 system error which started with as ‘black snow’ on the screen. There is an extended 3 year warranty that covers E74 and 3 Red Lights errors only.
2. Go through the walkthrough. If you've still no joy you can click a link to pick whether you are a US resident or not.
Nov 26, 2009 | Microsoft Xbox 360 Elite Console
I have a e74 system error on my xbox 360. what can i do about this .
If you want to attempt to fix the error yourself (and have no guarantee of sorting it and invalidate your warranty) search YouTube for ‘E74 fix' or ‘xbox towel trick’. This is supposed to overheated the console and re-solder dry solder joints. Only try if your warranty has run out and/or you own a bricked console!
Nov 05, 2009 | Microsoft Xbox 360 Console
E74 system error message accompanied by single red flashing light
E74 indicates general system failure. A modification to the GPU chip and heat sink needs to be made. What's happened here is that the X-clamps that hold ther GPU heat sink in place were too rigid not allowing for flex in the motherboard when it heats up. The X-clamps need to be removed, replace the heat sink studs with metric screws and neoprene washers, and new thermal compound needs to be applied to the GPU chip. You can find many tutorials on Youtube for this procedure. Although you need to be somewhat "Tech-sav vy". Or, you can send it to Microsoft or a trusted service tech to make the appropriate repairs. Good luck!
Nov 04, 2009 | Microsoft Xbox 360 Console
How do i fix the x box 360 3 red rings of death
The Xbox 360 e74 error is a rather common problem on Xbox consoles, with similar roots to the now infamous red ring of death problem.
The e74 issue is actually caused by a problem with the scaler (ANA or HANA) chips located next to the graphics processor inside your Xbox 360.
It is believed that the error with the scaler video chip which causes the e74 error on your Xbox 360 is caused by overheating. This is also the cause of other errors such as the no video problem, as well as red lights in the power ring of an Xbox console.
To fix the Xbox 360 e74 code, there are a few steps you need to take-
1. Firstly, leave this article open, go to your Xbox 360 console and then remove the AV cable. Blow any dust out of it, then re-insert it snugly back into the console until a clicking is heard. Power on your console again and see if the problem has been fixed.
2. If that does not work, borrow another AV cable (get one off a friend or family member, or from your local video game rental shop) Try using this one in your Xbox 360.
3. If replacing the AV cable does not work, then you will have to repair the scaler chip and graphics processor inside your Xbox in order to fix the e74 problem. To do this, you will need an Xbox 360 repair guide, which will contain the video instruction files you need to be able to fix your console properly. You cannot fix the e74 yourself without one.
It is important to note that most Xbox repair guides focus on fixing the "red ring of death". However, the process for repairing the e74 will also be covered in the same guide as well, as it is extremely similar.
Aug 30, 2009 | Video Game Consoles & Games
Screen reads,system error and has a trouble code of E 74 What could be the problem?
Aug 28, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
230 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
