Question about Samsung UN55D7000 55 in. 3D LCD TV
Reset samsung tv un55d7000 55 in 3d lcd tv
Reset tv to factory settings
4 Suggested Answers
moto34
  • 155 Answers
SOURCE: Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Posted on May 03, 2008
  • 210 Answers
SOURCE: how do i reset factory sttings on samsung lcd tv
go into analogue tv press menu move down to settings you should be able to enter plug and play in menu press ok( if you can not enter it you are not in analogue )
if not solve problem try this !! warning !!
you will enter the service menu DONT ENTER OR CHANGE ANY OTHER ITEMS THAT ARE DISPLAYED AS TV WILL NOT WORK IF YOU DO
With tv in standby press INFO / MENU / MUTE / STANDBY on remote
then use ONLY DOWN nav-key move to number 12 FACTORY RESET
press RIGHT nav-key will reset all tv settings to factory ones
PRESS STANDBY TO EXIT on remote
you will have to RETUNE after tv after
Posted on Oct 26, 2009
SOURCE: Factory Settings LE32A557
Ready was set to yes in the service menu. It should have been no.
Posted on Dec 13, 2009
Is a new main board the likely solution? Samsung LCD TV bricked after misguided firmware update attempt. TV's LCD lights work. Red 'On' light lights. Have sound no picture. TCOM board OK?
Don't know much about TV,s but I would look for a reset. Either electronic option in the settings or perhaps a manual one on the TV to return the TV to its original factory software.
Mar 21, 2017 | Samsung Televison & Video
Samsung LCD TV LE40R8 - Hard Reset
How do I reset the picture on my LCD TV to the factory settings?
The P.Mode button on the remote of your LCD TV lets you cycle through four factory preset picture modes: Dynamic, Standard, Movie, and Custom. To return the picture on your TV to the original factory preset, press the P.Mode button on your remote until the TV displays the Standard mode.
Nov 14, 2007 | Televison & Video
There is a Video problem with my Samsung LCD. The sound is clear but Colour Balance Setting is disturb. The Colour is mixing with each other. Can You tell me the procedure for My TV Setting?
Before you set up try a reset
Resetting The Picture And Sound To The Factory Settings
as far as advanced settings are concerned, set the contrast backlight and brightness so you can see the best blacks without it looking too milky, the best whites so you can discern the whites and they aren't clipped, then look at colour balance if it looks wrong when you turn the colour off.
it shouldn't be very far out in factory settings. Operation How To Change The Picture Settings On Your LCD TV LCD TV...
May 12, 2014 | Samsung LN-S2651D 26 in. LCD Television
I have no picture, and get an error code HDMI port locked out
A factory reset may be available to clear that issue--contact Samsung? to see if possible how to reset it to factory----Also be aware a box feeding signal that was connected to the set with it ON may have locked that out.
Apr 02, 2012 | Samsung LN37A550P LCD TV
How do I reset my tv to factory settings. samsung 32 inch LA32R81WDx/xSA
On a different Samsung TV, there is a Picture Reset in the Picture Menu on the OSD. (It's at the bottom of the list.) Similarly the sound reset is in the Sound menu. There is no global reset. (If your Samsung TV's OSD menus are different try under the Support menu.)
I hope this helps.
Aug 05, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung Le40a556 factory reset
with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on in factory menu settings look for reset use DOWN NAV KEY until highlighted and press RIGHT NAV KEY
to exit settings press standby the tv will come on and follow on screen instructions
DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK IF CHANGED
Dec 13, 2009 | Televison & Video
Factory reset Menu
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
I want to restart my samsung LCD TV LE32R71B, how can i do it?
You can reset 2 ways Put tv into analog mode by pressing TV/DTV on remote then press Menu move down to the satellite pic press enter you will see plug & play in the list press enter and follow on screen instructions
The other way
WARNING TV WILL NOT WORK IF YOU CHANGE ANY OTHER SETTINGS
With tv in STANDBY Press INFO / MENU / MUTE / STANDBY on remote the tv will come on with the factory settings displayed
FACTORY RESET ( 12 ) will be in there USE DOWN KEY ONLY until Factory reset is Highlighted then press the RIGHT KEY the set will reset all settings PRESS POWER ON TV TO EXIT
Turn ON TV AND RETUNE
Nov 05, 2009 | Samsung LE32R71B 32 in. HD-Ready LCD...
Settings
Have to reset or it is reset to factory settings?
Has anyone been playing with this TV, i.e. repairing it, replacing boards etc?
I believe - do not know it for a fact - that Samsung has this protection in palce which identifies the boards in a TV and once you switch a board the TV needs to go through a service re-administration to remember its current configuration.
There's no explanation of why would a TV need to do that other than to restrict users to Samsung service centers only.
Again I do not know this for a fact, but I have seen other Samsung TVs that do exactly the same and they start doing it upon replacing boards on them. It's a simple logic.
Nov 04, 2009 | Samsung LN32A330 32 in. LCD TV
How do i reset factory sttings on samsung lcd tv
Oct 25, 2009 | Samsung LN46B530 LCD TV
Samsung UN55D7000 55 in. 3D LCD TV Logo
326 people viewed this question
Henry  Thomas
Henry Thomas
