Question about Dishwashers
Replace Control panel cover on dishlex dishwasher 500E
Have bought new control panel cover for Dishlex dishwasher 500E. Can I remove & install this panel myself? I've removed the screws but the actual electronic panel is attached in someway-can you help me? Thanks. Stan
  • Anonymous Mar 20, 2014
    control panel replacement
If your 500E is the same as my 500E then the controls are electronic touch buttons. The are part of a self adhesive strip and stuck to the front of the door. No screws involved. Only the LED lights are mounted on a circuit board with screws on the back of the plastic front panel. ?????
Posted on Jun 07, 2009
Dishlex dx 203 buzzer
solenoids that control water flow (taps) buzz when failing Check out the water in solenoid.
May 26, 2013 | Dishwashers
The control panel has a large crack on it & needs to be replaced. Does the replacement part come with all the electrics & connections, please? Item description: Vulcan Dishlex 500E Electronic...
Hi just read your posting,I know these machines well.When you purchase the new panel you get the membrane or touch buttons and the rest of the components eg---control board,door handle--etc--- you must take off your old panel and refit them to the new panel.Before you attempt this job unplug the power point first.If you require additional help please reply and I can guide you throe the refitting of the panel.Looking forward to your reply.
Aug 29, 2010 | Dishwashers
My dishlex dishwasher 160 series has stopped
Have you disconnected the drain, fresh water, power and the 2 to 3 mounting bolts to the counter?
Mar 07, 2010 | Dishwashers
How do you acces the power switch for replavement
turn of power undo control panel screws remove panel you should see the switch replace and re assemble hope this helps
Nov 13, 2009 | Coffee Makers & Espresso Machines
The dishlex 302SB is not producing hot water for the washing
I have a Dishlex 302 which had this fault. Initially I thought it was the inline heater element and replaced it. It seemed to work but later no hot water again. Someone here put me on to the problem. There is a dry joint in the control board in the top of the door. This controls the relay which powers up the heater. Unplug it from the mains (very important) and undo the screws around the top of the door (don't take the door right off!) you will be able to wiggle off the front panel containing the electronics. The control board is ealiy disconnected an removed from the machine in its protective plastic cover. Have a look around the PCB and you will see the dry joint. Resolder with rosin core (electronic) solder, reassemble and you should have hot water.
May 23, 2009 | Electrolux 504199 Dishwasher
Looking for manual for Vulcan Dishlex 500e dishwasher
Probably fatigued wiring from the chassis to the door where it bends every time you open and close the door. On my 500E, I took the sheet metal door skin off and found a couple of burned spots on the wires inside a clear plastic strain relief.
Apr 11, 2009 | Dishwashers
Hello. Can i put an front panel on the door of my dishlex DX 103 to integrate it with the rest of my kitchen?
Yes but it must be a material that is made to withstand the heat dont cover any vents or spaces around the dishlex
Nov 09, 2008 | Dishwashers
Dishlex 500E dishwasher won't drain. keeps washing. New motor and membrane.
keeps washing ????? is it stuck on the wash cycle? is this what you meant?? any way simple things first. suction blocked....Discharge blocked? sometimes hoses keep junk in them that blocks the goesinta and the goesouta.
if stuck in the wash mode unplug the thing for 3 minutes or more to reset...try again.... reset again....
bad new parts----- that always sucks!!!!!
Aug 14, 2008 | Dishwashers
Electrolux dishlex dishwasher
www.nzherald.co.nz said it affects Electrolux dishlex machines with serial numbers 70700000 to 72400000
Jul 25, 2008 | Electrolux 23 in. ESL624 Built-in...
Dishwashers Logo
395 people viewed this question
Top Dishwashers Experts
