Question about Nextar Q3 GPS Receiver
Intellinav.exe application error
When I turn on my gps unit and I go to the navigation icon, I keep coming up with an error message re: fatal error with the intellinav. exe application. The unit will not bypass this screen, thus I have no access to the gps navigation section. All other functions re: mp3 player and settings functions work. Please advise on a solution. Thanks!
  • 21 more comments
  • Anonymous Dec 08, 2007
    i have the same problem
  • Anonymous Dec 09, 2007
    have the same problem but my gps say: intellinan is not a valid win ce application
  • Anonymous Dec 26, 2007
    on my screen on my navigation it says it will performed an illegal operation and will shut down. If the problem occurs contact the vendor.
    i have the same problem too.
  • bc_mc Dec 28, 2007
    When I turn on my Nextar Q3-A GPS, an error box is displayed called “IntelliNav.exe” with an error message that:
    “Cannot find ‘IntelliNav’ (or one of its components). Make sure the path and filename are correct and that all the required libraries are available.”
    In the past I was able to reset using power switch on rear unit but now nothing works.
    I have not found a solution on their website or by calling their tech support number. Nextar is a textbook example of how to appear to offer tech support while giving none. All avenues become dead-end alleys.
    Anybody want a cheap MP3 player?
  • oaktree Dec 31, 2007
    yes I have the nextar w3g-01 and it does the same thing, boots up the sits and looks at a blue map screen and the triangle pointer doesnt move the a box comes up with, application intellinav.exe has performed an illigal operation and will shut down, in box the info is,
    program: intellinav. exe
    exception: 0x80000002
    address: 000957b0
    Its only a month old wife bought it in November for a xmas present.
    Robert from Vancouver BC January 1st 2008. tried running battery down but no luck.
  • 2qwk Jan 06, 2008
    well same thing turn it on go to navagation and it says fatal application error illegal operation and will be shut down contact vendor,someone please help i need this for work.
  • abby007 Jan 07, 2008
    I have the same problem. Help please...
  • binderbasin Jan 14, 2008
    I have the same problem like the others i go to put the places i want to go i go through everthing and then it comes up FATAL ERROR!!!! intellinav.exe has performed an illegal operation and will be shut down if the problem exits contact program vendor. So here i am i have contacted u before and never heard anything EITHER FIX IT OR GIVE ME MY MONEY BACK!!!!!!!!!
  • turnipfish Feb 06, 2008
    when i turn on my gps it is not getting the gps signal. i tried to reset the system but still not working. it is stuck on one location and wont change help
  • Anonymous Feb 09, 2008
    All my functins work except the navigation option on my Intellinav 1 unit. Its like the unit will not load the map from the sd card. I use it for work all the time and its really a great inconvinience.
  • Anonymous Feb 17, 2008
    I have a Nextar W3 (peice of junk) that gives me the same error "application Intellinav.exe has performed an illegal operation and will be shut down
    Program: Intellinav.exe
    Exception: 0xC0000005
    Address: 000449B4"
    Please HELP!!
    Thanks in advance!
  • Anonymous Mar 10, 2008
    PPLICATION INTELLINAV.EXE Has performed an illegal operation and will
    be sgut down. ETC ETC.
  • Anonymous Apr 16, 2008
    i have the same problem with my NEXTAR HGPS35
  • Anonymous May 11, 2008
    I have the same problem. Does someone have a solutions?
    NEXTAR Q3: When I turned the unit on it went to the GPS TURN BY TURN NAVIGATION screen and is locked. I have tried everything to unlock it, can I go to a program online and connect it to the USB cable for a reset. I really like this unit and it has helped.
  • assie May 29, 2008
    my NGPS3 BY NEXTAR is showing me a box saying intellinav.exe, unable to find components, libraries not available. Try many times to reset it by turning the system off with the reset button.
  • martleb Jul 13, 2008
  • dollface919 Aug 25, 2008
    Everytime I load up my GPS, it comes up with the intellinav.exe error box. This message says....Cannot find intellinav (or one of it's components). Make sure the path and filename are correct and that all the required libraries are available.
  • giang0316 Aug 30, 2008
    I have the same problem. When I turn on my GPS which the Nextar Q3-13 GPS Receiver. After the Navativity screen load up, the error message box comes up with this message: Cannot find 'IntelliNav' (or one of its components). Make sure the path and filename are correct and that all the required libraries are available. I got this GPS unit for only a few months since I bought it from at the store.
    Thanks.
  • albanyams Jan 11, 2009
    Same thing here!!
  • Bus642 May 16, 2009
    Fatal A[[;ocatopm Error
    An illegal operation has been performed and will be shut down. If the problem persists, contact the program vendor.
    Nextar P3 GPS
  • bearhunter_c
    bearhunter_c Sep 16, 2012
    got same problem also,how do you fix this ?
HELP!! I keep getting Fatal Application Error. Application entellinav.exe has performed an illegal operation and will be shut down. If this problem persists, contact the program vendor. Program: Intellinav.exe
Exception: OxC0000005
Address: 00125D64
Posted on Sep 09, 2008
  • brenda selfe Oct 24, 2011
    mine is saying the same but my adress is 016F4B2c exception 0xc0000005 Program Intellinav.exe
I HAVE THE SAME PROBLEM. FROM WHAT I CAN TELL THE UNIT HAS TO BE SENT IN TO BE FIXED. FUTURE SOLUTION TO THIS PROBLEM IS NEVER EVER BUY SOMETHING WITH THE NAME NEXTAR ON IT............
Posted on Jan 13, 2008
Hi:
I got the same problem (one day I just got the message "intellinav.exe has performed an illegal operation and will be closed"... or something to that effect. Thereafter, I could do things like look at pictures stored on a flash card, etc ... but the minute I tried the "navigation" option... I got that message and could not use my gps facilities). Turns out that all I had to do was to reset the unit.
I took the "Settings " option on the main menu, then chose "restore all settings to factory default values"... it then posted a "finished" message. I went back to the main menu and selected the
"navigation" option ... and then everything worked again. My unit was an Intellinav-SE. In the Users Manual on page 41, they clearly document the procedure to reset the unit back to the factory default.
Hope this helps.
Jim
Posted on Nov 09, 2008
  • jc6204j Nov 09, 2008
    Hope this helps.
    Jim -
I have a nextar gps M3-03 and get the same your problem, then I hit the reset button in the back and turn on again. It worked.
Posted on Jun 29, 2009
When I start to navigate it gos back to the main menu!!
HGPS35 NEXTAR
Posted on Nov 15, 2008
Make sure the memory card is inserted correctly. If it's not, intellinav won't work!
Posted on Sep 22, 2008
WHEN UNIT TURNED ON IT LOADED ABOUT 25% THEN STOP
Posted on Oct 16, 2007
3 Suggested Answers
SOURCE: intellinav.exe application error
Did you try the switch on the back of the GPS? Turn off on the front, turn the switch on the back off, then on. This has worked for me numerous times.
Posted on Jul 02, 2008
rockitman187
  • 2559 Answers
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Posted on Jan 29, 2009
Fatal application error
methinks you are in firmware update territory...go to that site, and enter model number, and re download the firmware.
Mar 15, 2008 | Fine Digital FineDrive 400 GPS Receiver
Fatal Error Application comes on when turning on the GPS
The problem i,m having is All the routes i have taken have Now a Permanent Orange Heavy Line and i can not identify any Roads on my Navigation 4000
Feb 03, 2009 | GPS
Evesham is no longer in business but the following url is for a company that supports their products..
http://www.tewktech.com/
Good Luck and please rate this solution
Jan 26, 2009 | Evesham Nav-Cam 7700 GPS Receiver
Fatal error
This is a common issue, probably corrupt firmware in your unit and/or the sd card.
One solution is to visit C&C wireless and pay over $100 for a map update or even send them your unit for even more $. see http://www.finedrive-acc.com/shop.cart?action=ITEM&prod_id=F400-08CP
The other solution was to send it to Fine Digital but they closed their doors in the US so they no longer support us customers. Because of this I made a DVD with map data I purchased from them before they closed and I added much better instructions; this DVD updates the firmware in the unit and loads the last map data issued to the SD card. you would need a PC with a DVD drive and SD card reader to use it. you can find these DVDs on ebay for $18 which basically covers my costs only.
Jan 08, 2009 | Fine Digital FineDrive 400 GPS Receiver
/NOEXECUTE
CAUSE:
Aug 30, 2008 | Nextar Q3 GPS Receiver
Gps Stopped working (Uniden GNS 8431) and this message comes up on the screen- Fatal Application Error mobilenavigator.exe has performed an illegal operation and will be shut down. Program: Mobile...
You hopefully have the mobile navigator software CD that came with the GPS unit. Copy the entire folder and contents of the CD to your SD card (make sure you make a full backup copy of the exisiting software on the SD card first).
John MacLean
Brisbane, Australia
Aug 30, 2008 | Uniden GPS
Jan 06, 2008 | Nextar Q3 GPS Receiver
Initial GM-501
its a software issue....it turnes out initial is out of bussiness...they sold their technical support to a third party company real *** holes...its a manufacrurer error....they told me is i wanted to fix it they will have to charge me $150.00 to reset the software....thats rediculous i shoped around and the initial units are runing around $120.00....well good lood and never buy an Initial product
Oct 01, 2007 | Fine Digital FineDrive 400 GPS Receiver
Nextar Q3 GPS Receiver Logo
3,567 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
