Question about Sony KLV-S23A10 23 in. LCD HDTV
Standby light blinks 5 times
Green for a few seconds then blinks red 5 times.
SOURCE: Does not turn on.
i had my power supply blow on mine within the first year took it in because i had extended warranty and they fixed it, only problem was finding a dealer in my area to fix it, then took over a week, because of customer support issues
Posted on Nov 04, 2007
  • 84 Answers
SOURCE: standby light blinks for 6 times
Did you get this solved yet? Six blinks usuall meand thermal fuse. I can look it up if you still need help.
Posted on Jun 22, 2008
redhead7377
  • 51 Answers
SOURCE: Four blinking red lights.
you can have the inverter board replaced...instead of the entire panel.
KDL 40S2010: inverter part # 178950032, you will also need 2 spacers..part # 289765511
you're looking @ 200-300$ for the inverter and 5-10$ a piece for the spacers.
KDL-46V2500: inverter part # A1251295B
you're looking @ around 500-600 $ for the part
Posted on Sep 09, 2008
  • 23 Answers
SOURCE: 4 blinking red lights in power/standby
I would recommend replacing the fan, cleaning it doesn't solve the problem...If it does, it's only a temporary fix. Replacement fan is around $30 and easy enough to do yourself...
Posted on Oct 01, 2008
mistersony
  • 320 Answers
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Posted on Oct 20, 2008
Sony KDF-42WE655 Won't power on. Red Power/Standby light blinks 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 21, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
I'm assuming that it is an error code. The red
colour wheel issues and defective lamp replacing lamp and light engine color wheel cos its worn out
Jul 07, 2013 | Televison & Video
W KDS-R50XBR1 50 in. HDTV Television standby light blinks red 3 times
Something you might want to look at:http://sites.google.com/site/sonylcdrptvproblems/lamp-overheating-issue
Apr 06, 2012 | Sony KDS-R50XBR1 50" HDTV
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Green Picture with 5 times blink on standby red light
RESPECTED SIR ITS APROB WITH THE BOARD AND PLZ DONY TRY TO MAUPULATE IT PLZ BRING IT TO A GENINUE SERVICE CENTRE
Aug 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KLV-S23A10 23 in. LCD HDTV Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
