Question about Technics SL-1200MK2 Turntable
Ion turntable My belt on my turntable came off of its track, and im trying to figure out how to open up the player so i can put the belt back in its place.
    Guru:
  • 256 Answers
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Posted on Aug 18, 2010
  • 515 Answers
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Posted on Aug 31, 2009
Im trying to sinc my 4th gen ipod touch through an ion iprofile record player, is there a way i can do this?
No, unfortunately the device was only meant for LP to iPod or LP to computer type connections, and doesn't support normal itunes syncing.
Mar 01, 2011 | ION Audio iPROFILE LP to iPod DJ...
CD tray will not come out when the in/out button is pushed.
open up machine you will have to slightely slide screws out of side of cd player so that way you have room enough to put it back on track.
Feb 14, 2011 | Crosley CR248 Turntable
I have the sony record player above, and when I was moving I put it on its side and the belt came off. Now I cant figure out how to put it back on. Help ?
The Operating Instructions link on this page:
http://esupport.sony.com/US/perl/model-documents.pl?region_id=1&mdl=PS-LX250H
appears to give guidance on connecting the belt. Any use?
Oct 13, 2010 | Sony PS-LX250H Turntable
I need to remove platter on ttusb ion turntable to fix belt... it has slipped off... thanks in advance for your help
I do not know the particulars of your turntable, but in most units, you take off the rubber pad on the platter, and that will give you access to the metal dish, which has holes to gain access to the belt pulley. Slip off the belt, and then you will be able to pull up the metal dish. After you replace the belt, reverse the procedure. Just make sure that the belt is close to the pulley before you insert back the metal dish.
Mar 14, 2010 | ION Audio TTUSB10 Turntable
Turntable plays fine, but when I play the converted tracks in itunes, they are very low
Try turning up the GAIN (a knob at the back of the turntable). This should increase the recording level.
Feb 16, 2010 | ION Audio TTUSB10 Turntable
Turntable drive assignment
Windows?
Open control panel
Administrative tools
Computer management
Disk management
See if you see your turntable, If you do you can right click your mouse and select change drive letter, Change it to one you are not using and you should be back on track.
If this is not it then post more about what you are seeing.
Jan 14, 2010 | ION Audio iTTUSB Turntable
Turntable won't turn
There is usually a cotter pin at the center of the platter around the spindle base. This can be removed with a screw driver using a twisting motion. There is a blades worth of space between the clip and the spindle base. Screw driver should be in vertical position. Sometimes the vinyl slip mat must be removed first. Watch that clip, cause it can go flyin. Once the clip is removed, the turntable should let go easily.
May 03, 2009 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Ion turntable speed problems
Turn the tturntable over, there is a speed control pot on the bottom
Nov 07, 2008 | ION Audio iTTUSB Turntable
Record player belt
Scott, the belt wraps around the bottom of the turntable platter, then put the platter back on your turntable, and you'll have to pinch back a section of the belt and wrap around the brass motor spindle. That's pretty much it!
Good luck.
- OPTiC
TWEAK A/V LAB
Apr 13, 2008 | Technics SL-1200MK2 Turntable
Ion ittusb turntable drive belt
If the belt is stuck, it will be hard to take off without damaging the belt. Send it back.
- OPTiC
Turntable Repair Expert
Jan 28, 2008 | ION Audio iTTUSB Turntable
Technics SL-1200MK2 Turntable Logo
149 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
