Question about Kenmore Ovens
I have a kenmore electric wall oven model 9114088816 with an f3 error at self-clean - is the sensor the problem, and if so how can I order part or remove back panel of wall
SOURCE: self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Posted on Dec 09, 2008
SOURCE: Older Kenmore oven- door locked by itself
We had a quick power outage and when the power came back on it locked our older (1991) Kenmore electric oven model # 40889 / 40881. Went throought the manuel and nothing pertains to this problem. We have turned off the circuit breaker and turned back on, but nothing seems to unlock the door. Any suggestions would be GREAT!!!!!!!
Posted on Mar 16, 2009
  • 19 Answers
SOURCE: F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
Posted on May 09, 2009
  • 30 Answers
SOURCE: error code f7 on Kenmore wall oven 911.41165791
There is a probelm with the control panel. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
Posted on Nov 08, 2009
blueextc3221
  • 15935 Answers
SOURCE: trying to self clean my kenmore electric oven get
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Did the self cleaning. Now it has a F 3 code & door will not unlock.
  • Check warranty to make sure it has expired.
  • Disconnect power for 30 seconds and see if oven will reset the electrical lock.
The following link describe for Kenmore several procedures to disengage the electrical lock securing the door.
It is unfortunate that during the self cleaning cycle the stress levels at the elevated temperature premature failure appears to occur.
How to Clear the Oven Lock Mechanism on Kenmore Stove
The F3 error is most likely the temperature sensor that protrudes into the oven near the top usually on the left. Don't be confused there can be two probes that enter the oven. One is the over temp like not to exceed type of switching device and the other is the actual sensor that maintains the temperature at the set point.
There is a procedure to replace this sensor from inside the oven. I have had only limited success doing this repair in ovens from the front. Newer ovens are equipped with a plug that is easier. In all cases ensure that the plug is pushed through away from the oven wall. In older ovens I have had to pull the built in ovens to accomplish the work from the back to ensure a good connection using wire nuts... The sensor in the second photo does not have a plug so small wire nuts that will fit through the back of the oven are used.
26060093-3hiy01xauopzuspf4owyz2yd-3-2.jpg This second link is a suggestion that the use of the self clean feature is a concern, On two occasions I have had oven problems right after using the self clean cycle.
http://www.thekitchn.com/why-you-should-almost-never-use-the-self-cleaning-function-of-your-oven-175110
Jan 19, 2016 | Ovens
Shows E3 & F3
may be a stuck relay on board or bad oven sensor.
Aug 17, 2014 | Kenmore 30 in. Electric Self-Clean Single...
Error code F3 after self cleaning
F3 means that the oven temperature sensor has a open circuit. Check connection from sensor to the control board. If connection is good, replace oven temperature sensor. Hopefully the wires are long enough, then you can unscrew oven sensor and pull the connector thru hole to check connection and to replace. If its not long enough, you will have to remove oven from wall to check
Feb 13, 2011 | Whirlpool RBD305PD Electric Double Oven
Have a Kenmore electric drop-in range less than 2 years old. Turned on self-clean cycle but after an hour or so started beeping and F3 was displayed. Have lost manual.. What does f3 mean?
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Aug 04, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
F3 message displayed
HI, you oven temp sensor if malfunctioning. the circuit is open. its basically dead. Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
May 22, 2009 | Frigidaire 24" Built-in Single Electric...
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Range Cleaning Cycle not Working
Feb 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
50 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
