Question about Humidifiers
What are the setting recommendations for idylis humidifier #1 HUM 10 140 whole house system?
I plugged my Idylis whole house humidifier Model #1 HUM 10 140 in and all it shows is two lines. Will not work? What is wrong?
Posted on Dec 06, 2013
2 Suggested Answers
SOURCE: I have an Aprilaire humidifier that's 8 years old.
Please have the selonid valve replaced.The coil is shot.
Posted on Mar 15, 2010
Idylis S55C-AE1 humidifier leaks water on floor
My idylis humidifer is lealng where you put the water canister, after about 15 minutes from starting unit
Feb 26, 2014 | Idylis 2.5-Gallon Ultrasonic Humidifier...
White dust in the house
Use mini RO system or good filter to feed humidifier with water that contains less minerals.
Jan 24, 2013 | Honeywell HE360A1027 Whole House...
Have an HE225A, B By-pass Flow thru humidifier about 9 yrs old. Just change the antimicrobial pad with recommended Aprilair 110/220 and when the furnace comes on, there is a loud, hum-like, vibrating noise...
Make sure the new pad you installed is in the right position. The pad is marked with a black dot about the size of a quarter. This end should be up for proper water flow through the pad.I fwater flow is being restricted at the pad the vibrating nosie that you are hearing is the dry portion of the pad vibrating agaist the platic housing of the humidifier. This noise stops once the pad has absorb enough water in this area of the pad.
Jan 23, 2011 | Honeywell HE220A1019 Whole House...
He265a,b to much water flowing through and not getting the humidity . why is there so much flow
Don't know why so much water. May be able to adjust by turning down valve tap. Turn unit on and you should be able to hear water pressure decrease. Make sure damper in 6" pipe is open so humidified air will get through system. When very cold humidities are lower. Also must hum. mfgs. suggest connecting with hot water instead of cold (vaporizes faster) don't know which you have
Jan 22, 2011 | Honeywell HE220A1019 Whole House...
Do I need a transformer if my furnace has HUM port
Yes you still need a transformer the hum. port on the furnace goes to the 24 volt transformer. one leg of the primary side goes to the transformer and the other leg of the primary goes to the neutral on the board. Then you have your 24 volt terminals one goes directly to the humidifier and the other goes to the humidistat the other wire from the humidifier goes to the humidistat.
Jan 25, 2010 | Honeywell HE260A1010 Whole House...
My air king humidifier won't shut off
This might have a bad valve,or It could be mis-wired.It should be wired to common and hum on the control board.You can test By checking the voltage when the unit is off,and valve should be closed. Good Luck --Nate
Oct 29, 2009 | Honeywell HE360A1027 Whole House...
Honeywell he220a waterflow
Sounds like you Connected the humid trans fromer directly to a main power source. It should be either on the EAC or HUM term on the board of the furnace.
Dec 11, 2008 | Honeywell HE220A1019 Whole House...
Honeywell HE 260A1010
control board has eac terminal . will provide 110v to hum transformer anytime fan running.
also can pick up current sensing relay to sense blower power up and will then power the Hum. transformer.
Oct 25, 2008 | Honeywell HE260A1010 Whole House...
Wiring problem
Sounds like you may have put 120v through a 24v solenoid and humidistat.
Is the HUM terminal on the furnace 120v or 24v?
If it is a 120v terminal you will need a 120x24v transformer and a new solenoid and maybe a new humidistat.
Dec 19, 2007 | Honeywell HE360A1027 Whole House...
Humidifiers Logo
349 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
