Question about Kenmore Kitchen Ranges
Kenmore 790.7231 range igniter does not work
My Kenmore range/oven (model 790.7231) range igniter has stopped working. Both the oven's bake and broil igniters work.
  • 3 Answers
SOURCE: hotpoint 30" self cleaning gas range with sealed burners - no bake
It may be the ignitor, they can crack and you wouldn't even see. Good news is they are cheap ($5-20) and they are usually easy to replace. But before you replace it...
When set to bake, does the "oven cycle" light come on? If not, that means no power is being sent to the ignitor. Reason? There is a switch in the oven latch, to make sure a) latch must be closed for cleaning cycle and b) latch must be unlocked for baking. On mine, the switch button gets stuck, so even when the latch is unlocked, it thinks it is locked and will not allow the bake cycle to proceed. Cycling the latch a few times may free it, otherwise you'll need to replace the switch (not that hard but a bit of a pain to get to).
Posted on Nov 22, 2007
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
aborcass
  • 2651 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
bad oven ignitor is the most common cause of bake failure, located onthe side of hte burner bar itself, if youd like with a multi-meter, you can check the wires leading to the ignitor for 110v. if you have power and nothing was glowing from ignitor theres your problem
Posted on Nov 23, 2008
vijaydangwal
  • 137 Answers
SOURCE: My gas range's oven piezo-electric igniter is not working.
it must be a problem of spark distribution try to remove the spark plug from your piezo electric igniter and clean it throughly it must work otherwise it will have to be replaced
Posted on Feb 25, 2010
SOURCE: Kenmore Oven
Burners work fine, but broil and bake do not work. Broil igniter glows, but no gas comes on. Bake igniter will not glow at all!
Kenmore 911.36669891
Posted on Aug 02, 2010
My Kenmore model 950 range will not broil or bake. The control board seems to work and allows me to set the temp, etc., the clock works, the control board makes noise which sounds like it always did
Most of the time, when BOTH the oven bake and broil elements don't work, it is usually caused by an open thermal circuit breaker or fuse. When did your oven stop working? After a self-clean? This is the most common cause of one of these thermal fuses opening. Usually this device is located on the back of the oven. A few of them are manually-resettable; but most of them are one-shot thermal cut-out devices (thermal fuses) which have to be replaced once they have been triggered.
Dec 28, 2014 | Kenmore Kitchen Ranges
My Kenmore model 790 range will not broil or bake. The control board seems to work and allows me to set the temp, etc., the clock works, the control board makes noise which sounds like it always did w
Need manual for Kenmore oven model#C970-648141
I am looking for a manual to a Kenmore Self-cleaning Convection Oven. I bought it used it has selection for conv bake, conv roast, bake or broil. According to the website, my model number doesn't exist -- really? Everything works perfectly - I just want to understand the difference between "bake" - "Conv bake" and "Conv Roast"
Mar 29, 2013 | Kenmore Kitchen Ranges
Kenmore Elite slide in range model # C790-440732 keeps displaying error code F23 and oven will not work except on broil
I have the same problem with my Kenmore F23 code will not bake but the broil works?? What the heck?
Feb 07, 2010 | Kenmore Ovens
Hi i have a kemore gas range that the bake ingiter or broil won`t
The igniter in the oven does not spark. It heats up and glows red hot until enough current opens the safety gas valve to the burner. It is not associated with the stovetop burners. Replace the oven igniter itself.
Aug 11, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
Kenmore Oven
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
PS go to searspartsdirect.com, type in your model number for the exact replacement part number.
Oct 27, 2008 | Stoves 500SIDL Gas Kitchen Range
Burners & Broil work but Oven burner does not!
HI thanks for your question. the problem is with the bake igniter. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
46 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
