Question about Craftsman Air Tools & Compressors
I have a 3hp 15gal air compressor that i bought used, when i plug it in it seems to run just fine but it don't seem to build air pressure, it stops building around 15lbs but the compressor keeps running anyone have any ideas. I even opened up the regulator and it still don't build up pressure.
    President:
  • Craftsman Master
  • 1,383 Answers
I am assuming that your compressor is oilfree type. Lets go over some basics to determine where fault is located. You will need to do some simple tests. If there are leaks the compressor may not reach set pressure. I use soapy water on all connections and on the head/headvalve (remove plastic covers to get to all parts that may leak) while compressor is running. Make repairs as necessary. If still low pressure, while compressor is running and has reached max obtainable pressure (in your case 15 lbs), carefully place finger over intake port hole (remove filter). If the compressor is pumping normally but leaking there will be ample suction at intake and cause the compressor to speed-up when intake is obstructed with finger. If you feel plenty of suction and no visible (soapy water) leaks, then the problem is probably the cylinder /ring is not correctly seating /scratched and air is leaking past cylinder. Make sure that the cylinder /piston ring is properly aligned and that the lip on the vinyl ring is up toward the head. On oilfree compressors you can examine the cylinder by pushing the piston all the way up, then look for scratches neer top of cylinder. If scratched install cylinder kit. If you do not feel suction but rather air blowing out of the intake, then the problem is the headvalve plate/reed valves are leaking. The reeds must seal perfectly on their seats and not be bent or have obstruction. Replace as necessary. Only one other thing to check and that is the intank check valve. Easy to check. Run compressor till you have about 15 + lbs in the tank then unplug compressor. Carefully loosen the inlet hose at checkvalve and listen for air leaking out of tank. If leaking replace checkvalve. Use caution when removing head to try and save the gaskets. If you see any model numbers on your compressor beginning with WL, you probably have a unit built by Campbell Hausfeld and can find parts at www.chpower.com
Good luck on your repair and email if you have other question.
Posted on May 09, 2009
Runs all the time. Why?
The pressure switch should cut off the compressor when cut-out pressure is reached. If however, there is a leak, or the reed valves /gaskets in the head/piston are faulty, the pressure will not build up enough to shut off. With the compressor running, spray soapy water on all fittings including around the head and drain valve. If no leak is found and pressure only builds to less than 50psi suspect reed valves. Parts are low in price and available from various on line stores including www.toolpartsdirect.com Good luck
Oct 15, 2011 | Stanley Bostitch CWC200ST 3HP Oil Lube...
Porter cable 3hp air compressor 130 psi no model number visible compressor runs builds up pressure and kicks off when the pressure is builded up in the tank// the compressor will not kick kick back on when...
Check to see if the switch will kick in if the pressure is released from the hose going to activate it...if so then the problem is the air being trapped between a check valve and the switch in the hose...
I think that is your problem...
There should be a way for the air pressure to change and represent the tank air pressure accurately....
The different compressors all have different ways of checking the air and then allowing it to release as the the tank pressure decreases..
There is a small hole there somewhere that is clogged with dirt and or oil...find that and clean it and you are in business again...
heatman101
Jul 27, 2011 | Porter Cable Air Tools & Compressors
My Craftsman air compressor has wored fine till now. It does not want to build up pressure beyond 50 psi.yes I did check the drain valve and no leaks. Motor seems to be putting out the rpm's and the oil...
Check for a leak between you compressor head (pump) and your tank. Your pump output may be good but as your tank pressure gets higher the leak will not allow the tank to build up.
Feb 04, 2011 | Craftsman 1 hp Air Compressor, 4 gal. -...
Air leaks from pressure switch after compressor builds full pressure
if its leaking steady from the unloading valve on the pressure switch after the compressor stops you have a bad check valve!replace it and youl be fine,dont forget to depressurize your tank before!!!!! and use teflon tape on the treads to avoid air leaks when you replace it!
Jan 20, 2011 | Ingersoll Rand Single Stage Electric...
PRESSURE WILL NOT BUILD, SEEMS TO RUN FINE (ABOUT 10YRS OLD). COULD IT BE THE INTAKE VALVE?
you're probably right, do you bleed the tank pressure after every use? This helps with the longevity. Could be leak in system, crack in head (these would be audible after cycle or turn off). Piston rings/seals- looks like an oilless unit- normal wear...
Oct 01, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor runs fast but air pressure stays low
hi your problem seems to bee that your valves are either broken or not seating properly
visit your local dealer and purchase a new valve set once fitted your machine will work fine
hope this helps ian
Mar 24, 2009 | Campbell Hausfeld Single Stage Air...
Wont build pressure over 25 psi after rebuild
sounds like the belt is slipping have you checked the inlet and discharge valves also could be bad and leaking or stuck or installed wrong
Feb 19, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
237 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
