Question about Magic Bullet Nutribullet Blender
I have model NB101B #23F509291200585 and use it for juicing. it will not engage. it appears to be frozen. plastic notches will not engage.
Kitchenaid KSB655C5 blender locking collar doesn't go down on one side when assembled. Both sides of locking collar are away and symmetrical when off the jar.
I would say pull it apart again and fiddle about with it a bit paying some attention to that spring loaded ring that's causing you grief. I don't have one here to look at but I know I've seen that problem before and it's something to do with that ring underneath needing to be turned to a certain position so that it engages properly. There are some notches in it that need to be in a p[articular position. We never saw that version for too long, the following model had a plastic beaker without all that rubbish on the bottom.
Feb 11, 2017 | KitchenAid Blenders
Recepies for the cactus smoothie
Some of the names of cactus smoothies are:
a. Detox Cactus Smoothie
b. Pineapple Cactus Smoothie
c. Cactus Pear Green Smoothie
d. Nopal Cactus Smoothie, etc
Nov 29, 2016 | Blenders
Conatiner for mixing has two plastic notches broke off and machine will not spin what to do
Look for PARTS available for your unspecified brand of blender.
Do the google search for
Parts make and model of blender
Might result more expendive to get that container then a nwe bleder!
Nov 03, 2015 | Blenders
I need a replacement blender jar for my Toastess juice extractor and blender :400 watt blender, wher can I get a replacement jar
Try here:
http://theconsumerlink.com/Toastess/list/TOASNEW/17
This is the official Toastess site. If the offered blender jar does not fit your model you may have to search on the secondary market.
Trust this is helpful.
Mar 10, 2012 | Toastess Blenders
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Replacement needed for plastic container behind the machine
I was not able to find a parts list or 3rd party supplier for such a part, so I would reccomend contacting Margaritaville directly for the part:
http://www.margaritavillecargo.com/CustomerService.aspx
The have a form to fill out to get the information, and a customer service number to call.
Hope this helps!
-Tha Mp3 Doctor
Feb 20, 2009 | Margaritaville Frozen Concoction (DM1000)...
Replacing the part that connects the motor to the blades on an Oster blender
I don't know if this will help or if this is what you are looking for. But today I was searching the web for the bottom piece that fits on the jar and saw this website has a lot of replacement parts for Oster blenders. Hope this is what you're looking for.
Good Luck
http://www.goodmans.net/get_item_os-070_square-drive-pin-for-oster-osterizer-blenders-shor.htm
Sep 12, 2008 | Oster 6803 14 Speed Blender
Durabrand blender model number tsk-9368ap
You just bought a bad blender. Get a different model
Jul 10, 2008 | Blenders
Magic Bullet Nutribullet Blender Logo
110 people viewed this question
Top Magic Bullet Blenders Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
R.A. Ellis
R.A. Ellis
Are you a Magic Bullet Blender Expert? Answer questions, earn points and help others
