Cooling fan running constantly.
Prosine 3.0 Inverter/Charger Cooling fan runs all the time. Room temp is constant. Unit not under load. Always cool to the touch.Never did this before. What's up?
    New Friend:
  • 160 Answers
The cooling fins are clogged, u need to get a small vacum and clean the area
Posted on May 09, 2009
2001 montana cooling fans not coming on
A pontiac montana ? There are three relay's that control your cooling fans ! unplug what sensor ? The engine coolant temp. sensor is an input to the PCM - engine computer . When temp. reaches 213 degrees the PCM energizes the relays , depending on low or high speed . Using a scan tool to see if the PCM will turn on the fans an checking engine coolant temp.data is the right way to diagnose this . Relay Driven Dual Cooling Fan Diagnostics
Jan 21, 2017 | Cars & Trucks
My A/C unit will not switch on - the timer light flashes 13 times and then repeats this constantly
Check your indoor room and coil temp, may be defective. your ac requires wet service with some gas top up. First service your unit and run. If it runs smoothly, your problem solved. If less cooling short of gas. Tap up gas.
Jan 01, 2011 | Heating & Cooling
The fan is constantly running, is this normal?
the fan on the trailblazer is attached to the water pump which is always spinning so yes the radiator fan always is running,,its mechanical,not electrical fan
Oct 19, 2009 | 2002 Chevrolet TrailBlazer
Laptop shuts OFF on it's own
Laptop fans DO NOT run constantly. They only turn on when booted up and once the laptop has reached a certain temperature. You should probably time how long for a shutdown, record your results. Let laptop cool for 10-15 between attempts. If it takes approximately same amount of time to shutdown between attempts it is very possible its overheating.
Other things like Viruses, software conflicts, and Harddrive problems can also be the culprit. take a look at the administrator event logs for any clue there. Event logs are in control panel under Administrator Tools.
I don't recommend trying to fix any overheating issue you may have, as that would entaiil disassembling your laptop. Unless you have a bit of experience in this, I would take it to a good repair shop.
Hope this helps you some. If so please rate my solution.
May 10, 2009 | Dell (6F858) Cooling Fan
Fan in cooling compartment
The fan inside the unit should run all the time, this insures a more constant temp throughout the compartment by keeping the air moving.
May 28, 2008 | Carrier Beverage-Air UR30GEFD Beverage...
Fan runs constantly on cool mode
Simple Question: Did you check to see if the fan switch on the
t-stat is in ON or AUTO? If ON the fan runs nonstop. If in auto the fan cycles with the outdoor unit.
next does the fan shut off if you turn the t-stat to off?
A stuck relay should keep the fan running all the time.
Sometimes if the relay is stuck you can whack the side of the Air Handler and the connection will break.
Sometimes instead of a relay there is a stack switch.
It's a little black stack of 3 disks this is a bi-metal switch.
they do get stuck more often than relays.
The fan relay may be on a electronic board. I don't know for sure without seeing your unit.
Good Luck Phil
May 18, 2008 | AmcorAire UCHW-H12AF2 Split System Air...
Computers & Internet Logo
222 people viewed this question
David Payne
David Payne
