Tv switches off after 5 mins - Televison & Video
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
There might be three or more reasons for this:
1) The sleep timer may be on causing the TV to turn off after a preset time.
2) If sleep timer is on and no signal from the remote is received for a preset time (Samsung: 15 minutes) the tv will turn itself off.
3) The TV may have been turned on automaticaly with "On Timer". If so, and no signal is received for a preset time (Samsung: 3 hours) the tv will turn itself off.
4) A fan is not working or a vent is blocked causing the TV to overheat and turn off.
For 1) thru 3), go to the "setup" menu and make sure "sleep timer" and "On Timer" are turned off.
Posted on May 09, 2009
Nec tv will not switch back on when hot
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too will be necessary.
Aug 30, 2014 | Televison & Video
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
Cello tv 12v
lenses are old change it or replace whole unit.
Apr 29, 2014 | Televison & Video
MY TV DOES NOT SWITCH ON TILL AFTER ABOUT 5 MINS AFTER SEVERAL ATTEMPS ON OFF
Kindly do not keep trying like this, as you might damage other components/boards inside. First of all, ensure there are no loose contacts in power outlet, RC jack, cable and connectors. If problem persists, I suggest it is better to refer it to a qualified service
technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | Televison & Video
My sharpe aqous runs for so long then a message appears saying the tv will automatically switch of in 5 mins, this appears every minute until the 5 mins are up. I have checked and the sleeper timer is set...
Tries unplug,replug tv an hour later.Let the tv reset itself.Than goto tv Menu go to PICTURE,go down to reset.This will reset everything on the tv Tuner board back to factory setting.This should solved ur problems.Not,than the tv Tuner board have intermitten isuse problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Sep 13, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
There are 5 blinks to my RCA big screen TV. The lamp is new, and the picture plays for about 3 min. then goes dark with sound for 3 min.
Hi
Thanks for using FixYa. Assuming that they are blinking green 5 times you need to open the lamp door, make sure switch is in tied down position, take the lamp out and put it back in, close the door and see if the problem still exists then please revert with the model no# of the TV and also let me know which light is it that blinks 5 times so that I can further assist you. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 06, 2010 | Televison & Video
RCA R301F1 remote problems
If you have tried 5 remotes I would have to say that the set has a problem in the remote circuit. You will need a tech to look at it and repair it. Let me know how this works out for you.'
hardrocko
Feb 01, 2010 | RCA L46WD22 Television
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
No colors
sounds like a leaky cap or bad solder connection
Dec 04, 2006 | Panasonic CT-27G23 27" TV
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
Electro Med Services...
