Question about Frigidaire Affinity ATF7000E Front Load Washer
E91 error says check wiring. What wiring are they refering too?
E91 error says check wiring. What wiring?
  • 668 Answers
SOURCE: aeg electrolux lavamat 74820 e91 fault
  • It indicates that there is no communication between circuit boards.
  • Power off, drag machine out onto the floor, remove covers, disconnect circuit board connectors and clean with a toothbrush.
  • Clean off any corrosion or crud, refit and test. Closely inspect the entire wiring loom and circuit boards, looking particularly closely at areas where the wiring touches the machine frame. Your'e looking for any signs of wear or fraying, which would allow the bare wire to contact the frame.
  • Check all wires and connectors generally for internal breakages caused by movement of the wiring loom attached to the drum.
  • If you could not find any torn wires call service technician to repair the washing machine .
Hope this helps .
Shane
Posted on Dec 06, 2009
Testimonial: "thanks we need a repairman to do this thanks anyway"
SOURCE: can anyone help ive got a zanussi FJDR 1466 W. e91
I had the E90 problem about a year or so ago. Havng had a problem with my Zanussi dishwasher a common fault with zanussi white goods is that they don't solder major joints on the control boards very well. (Probably tryng to economise of the amount of solder they use)
Check all the connections on the control board are tight and haven't burnt off the solder. This worked for me and we haven't had this code since.
Posted on Dec 11, 2009
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: atf6000es error code E91
    Hi Angelia,
    E91 means that there is a communication problem with the user interface to main control board. You will need a certified professional to check the wiring between the main control board and the user interface board to determine which part has to be replace.
    Posted on Sep 17, 2012
    chrispolkele
    • 4342 Answers
      Verified Fixya Pro
      SOURCE: e91
      Hello - Typically error code E91 on Frigidaire washer indicates a communication error with the user interface to main control board. A certified technician will need to check the wiring between both parts. Either part could be defective or unit may possibly have faulty wiring. Depending on the diagnostic either or will need replacing.
      Posted on Nov 05, 2012
      richroth
      • 9472 Answers
      SOURCE: Error Code E91
      E91 is for the control board failure and needs to be replaced. Here is the part to order. To replace the board remove the top of the unit.
      Posted on Dec 06, 2012
      The machine won't start and flashes error code E91. What is your recommendation for a fix. Thank You, Jim
      Buy a repair manual for the machine after checking the user manual that came with machine. If no manual, then purchase a manual online. Search your machine's name and find it online.
      Apr 26, 2016 | Washing Machines
      AEG L87480 on desplay makers E91 what means
      E90 is family error code visible to the customers. It is necessary to read the error in the service mode so please proceed with the following procedure for rapid reading of alarm codes:
      Press and hold down START/PAUSE and the option button nearest to the START/PAUSE button for at least two seconds!
      After that the display will show one of the following errors that are more precise:
      E91, E92 - Communication incongruence between main board and display board (versions not compatible). Posible causes: wirings, main board or control/disply board.
      E93 - Incorrect configuration of appliance. Posible causes: Incorrect configuration data; electronic board faulty.
      E94 - Incorrect configuration of washing cycle.
      E95 - Communication error between microprocessor and
      EEPROM. Posible causes: Electronic board faulty.
      E97 - Incongruence between programme selector and
      cycle configuration. Posible causes: Faulty electronic board (Wrong configuration data).
      Considering that this is a complicated fault, my advice is to contact an authorized service center.They have special equipment such as an interface that allows them to upgrade software in your appliance. If you are not doing anything on the appliance before the failure, the only thing you can check is the contacts between wiring and electronics.
      Dado
      Jan 11, 2016 | AEG Washing Machines
      What's the meaning of E91,and F47 error codes on
      Use Google to get the answer
      GM/Cadillac OBD1 Codes E91 & F47
      Aug 22, 2013 | Cars & Trucks
      E91
      Nov 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
      Atf6000es error code E91
      Hi Angelia,
      Sep 12, 2012 | Frigidaire ATF6000ES Front Load Washer
      E91 Problem
      The Epson E91 error mean is that your printer's waste ink pad is saturated.
      May 19, 2012 | Epson Stylus RX530 All-In-One InkJet...
      E91````
      E91 Communications error between main PCB and user
      interface
      Apr 25, 2012 | Electrolux Washing Machines
      Prndl switch problem error code e91 and ee 91.92 cadillac deville
      the switch on top of the transmission where the shift cable is . it probly is not anny good. check all wiring . make sure thair is no dirt inside the connector
      Jun 08, 2009 | 1996 Cadillac DeVille
      SONY DSC W 90
      Flash is not working and Getting Error on screen E91:01
      Oct 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
      Sony T5 is flashing Error E91:01 and the pictures are blurry
      My Sony cam was woring fine but suddenly it started giving an error E91:01 which is continuously flashing
      Aug 27, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
      Frigidaire Affinity ATF7000E Front Load Washer Logo
      264 people viewed this question
      Top Frigidaire Washing Machines Experts
      Dan Webster
      Dan Webster
      Gerry Harvey
      Gerry Harvey
      Jason Harris
      Jason Harris
      Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
