Question about Maytag MAH6700AWW Neptune Front-Load Washer
Unclog mfw9600sq maytag fron loader
How to remove lower panel so i can see if there is a clog
4 Suggested Answers
SOURCE: Maytag Ensignia Washer Leaks
replace the pump pump is leaking
Posted on Apr 16, 2009
freetek
  • 5568 Answers
SOURCE: how do i remove the front panel of a maytag
Most of the machines I have seen/serviced have the sides, front and sometimes the rim of the top assembled as a unit,not individual pieces. Removing the panels in the rear of the machine will give access to everything although sometimes one needs to be Gumby for working on them.
Posted on Apr 06, 2010
Jahn27
  • 1554 Answers
SOURCE: water pump is clogged on
Unplug the dryer or disconnect power then remove the three screws attaching the bottom of the lower front access panel and pull the panel down and off. Once the panel is off, you'll find the drain filter attached to the drain pump.
Place a container or a piece of towel underneath the filter to catch spillage. You may need to drain the water from the machine by putting the end of the drain hose over a container on the floor. Position the container as low as possible to extract as much water.
Remove the filter by turning the knob counterclockwise and clean it. Also take a moment to inspect the drain pump impeller by reaching it in with your finger and turning it. The impeller should turn freely. Otherwise, replace the drain pump.
This Maytag machine is made by Whirlpool and therefore troubleshooting are basically the same. Click on link below for more detailed drain problem troubleshooting.
Drain Problem Troubleshooting on Whirlpool-made Front Load Washing Machines
Posted on Jul 19, 2011
Is there a filter on this model
Of course. The filter is located in the pump behind 'front' bottom panel. Disconnect power, remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Be prepared for a lot of water, catch it in something to prevent more work. Clean the filter from any debris that prevents water from draining out properly. Front loaders hv filters, top loaders don't. Don't forget to click that you are helped!
Oct 18, 2014 | Maytag EPIC MFW9700S Front Load Washer
I have a maytag quiet series 200 thats only 3 yrs old and now it cleans great it just leaves water in the bottom, it seem its not pumping out the water..
Is this a front loader? If so, there is a panel right below the door. Three screws hold the panel. Remove the screws, and right behind that panel is a filter. have a towel ready, and screw the filter out. it is probably clogged. Remove the debris from the basket, was it out and replace.
If its a top loader, then try running about a galleon of vinager thru it to remove the hard water build up. Good luck
Nov 14, 2012 | Maytag Dishwashers
MFW9600SQ
Remove the bottom kick-plate by removing the 3 screws on the bottom. Clear the the drain pump filter. Post back if this does not fix your issue.
Oct 31, 2012 | Maytag Washing Machines
Water pump is clogged on my maytag front loader how do you unclog it? I washed old tugs that had rubber backing and they fell apart and crumbled
Jul 19, 2011 | Maytag MHWZ400T Front Load Washer
How to unclog drain hose/pump? my front loader
First of start by checking the rubber gasket seals around the door and making sure those are good and clean and dry. Then inspect the barrel itself. My daughter loves to leave scraps of paper in her pockets that then get stuck in my front loader. Clear any debris from the barrel. Does your machine have a small front access panel or back access to get to the filter? Most front loaders have some sort of filter on them apart from the barrel. If you can find this part, it is a common culprit. Mine is a tube shaped basket with a front access panel on this one. On the front loader before this one is was back panel accessable under the drum. when you check these have a bucket and some thing mop up with handy, towels, mop, etc. One other thing to consider is the drain hose from the machine. I have flushed mine using a garden hose in the yard and used a little bleach.
May 12, 2017 | Frigidaire ATF6000ES Front Load Washer
Samsung front loader leaks out the front of detergent door, extremely bad, drain seems plugged how do I get to it? Or remove panel to clear clog?
Withe the power 'OFF' remove the lid then find the black hose leading from the dispenser to the plastic tank.. if clogged with detergent then squeeze carefully breaking up the powder then flush through.. if the hose is behind the front panel then this could also be done by removing the door seal fron the front panel for access.. i have unblocked many a times this way with as little taking apart as possible.. Thanks
Dec 17, 2009 | Samsung Washing Machines
I am getting a nd flashing on my washer
ND means no drain. You can remove the back panel to access the drain pump. Remove the hoses fron the drain pump and remove the clog. Watch out water will drain out when removing the hoses. hope this helps....
Oct 27, 2009 | Maytag MAH8700A Front Load Washer
I have a front loader. Have had it for 3 years always worked just fine never a problem. It stopped when I was washing a front door mat and has yet to work since. It won't let any water in to fill and...
If the problem is just the pump being clogged,,, its very simple. Remove the back panel, or the front bottom panel (if your model has one) and locate the pump. Make sure ALL power is disconnected, and all electrical parts are covered because once you disconnect the tubing from the drum, and pump, all the water will be let out. If there is nothing clogging the tubing, you'll have to remove the drain pump and take a look inside.
Mar 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Clogged or frozen condensate drain.
The rear panel inside of the freezer should have screws in the corners. Remove these screws. You can remove the back panel and the evaporator coil and drain should be accessable now. Do not force the panel out. You should be able to remove it fairly easy if it isn`t iced up badly.. If you have any other quistions, please ask. I will help you as much as I can.
Nov 10, 2008 | Maytag Refrigerators
Removeal of external case below loader door
If you are talking about the lower kick panel, all you have to do is remove the three 7mm (torx) screws under the bottom edge of the panel. HINT: If you prop the front feet of the washer up it makes access much easier. (I use a couple small blocks of wood). Once the screws are removed, the panel should drop down then come off. If the panel sticks, just tap on either side and it should come loose. I hope you find this information helpful. If you need further assistance, please post back and let me know.
May 21, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
19 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
