Question about GE Refrigerators
Ge ziss480drbs how to remove control panel?
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: how do i replace ps
Hi
Remove the trim from around the dispenser area then remove the catches in the top of the electronic board. Lean the electronic board forward and disconnect the electrical connections, then remove the electronic board. Then remove the four screws holding the shield to the door and removed the shield. Remove the funnel from the shield and remove the spring from the old funnel and place it on the new one. Now remove the light and socket from the old shield and installed in the new one, then install the new funnel on the new shield, used the four screws to install the assembly on the door and replace the trim piece. Hope this helps... Please post back if you need more information. Daniel
Posted on Mar 06, 2011
Compressor fan on ZISS480DRBS moving slow
Likely a bad capacitor. Turn off the power and use a stick or long screw driver to spin the blade. If blade spins freely and is not binding up then bearings and motor most likely ok. Capacitor is inside panel, with power off you can at least inspect. If swollen or oily definitely bad.
Feb 11, 2017 | Heating & Cooling
How do I remove the front control panel on a ge profile je2160sf01?
On most over the range ovens, the screws for the control panel are on the top of the control panel. You usually have to remove the air deflector above it to acccess the screws.
Dec 24, 2016 | GE Microwave Ovens
Remove front panel ge spacemaker dryer
Here's the trick: The Spacemaker dryer is the same as many other GE dryers but is upside down!
1. Unplug the dryer.
2. Flip the dryer upside down so the white panel is now on top and the unfinished steel panel is on the bottom.
3. Remove the 2 screws that connect the bottom, white panel from the back and lift up to remove.
4. Pull off the Settings and Fabric knobs on the front of the dryer. Take off the front control panel (remove the 2 screws).
5. Remove the 2 screws that attach the front panel (located behind the control panel you just removed). Hold the dryer drum by the top edge and pull the front panel away (note that the panel will be hooked to the rest of the dryer at the bottom corners). DO NOT PULL AWAY ENTIRELY!
6. Disconnect the wiring that is attached to the front panel (these come apart easily by hand but you might want to mark the wiring so you know where to connect it when reassembling).
Apr 05, 2012 | GE Spacemaker DSKS433EB Electric Dryer
How do i replace ps 652226 ice funnel ge ziss480drbs
carefully removed the trim from around the dispenser area by gently prying the trim off careful not to brake it. then freed the catches in the top of the electronic card. I leaned the card forward and disconnected the electrical connections, then removed the card. I removed the four screws holding the shield to the door and removed the shield. Then I removed the funnel from the shield and removed the spring from the old funnel and placed it on the new one. I removed the light and socket from the old shield and installed the in the new one, then installed the new funnel on the new shield, used the four screws to install the assembly on the door and replaced the trim piece. Here's a DIAGRAM to help.
Mar 05, 2011 | Refrigerators
Ge Washer GSLP1100D0WW keep getting a dr code near the end of the cycle it stops at 28 mins and then when i hit start it counts at 30 gets down to 28 again and does the same dr code again
Your problem lies in the PCB assembly, or pump motor, most likely the PCB assembly.
1. open lid
2. remove control panel screw covers & screws
3.lift control panel
4. remove screws connecting PCB assembly to control panel
5. Remove PCB from control panel by pushing PCB from right to left.
6. Disconnect wire harness connectors from PCB.
Hope this helps!
Jan 04, 2011 | GE Spacemaker WSLP1100D Top Load Washer
How to disassemble a GE DBXR453EV0WW dryer?
Unplug the dryer.
Remove the screws from the control panel top rear.
Lift the control panel aside.
Pull the top lid forward to remove it.
Reach inside the right and left front corners to remove the screws holding the front panel to the cabinet.
Remove the door switch wires and set the front panel aside.
Your model may or may not have 2 screws holding the top lid down located inside the door opening. Open the door,get down on your knees and look up at the door opening for 2 screws.
Jan 03, 2010 | GE Dryers
Replacing Light bulb in a Frige
Open refrig door, look at control panel, on each end of control panel there should be philip screws holding panel, remove screws, drop panel down slowly, replace light. Install in reverse order.
Oct 16, 2009 | GE PTC22MFM Top Freezer Refrigerator
GE WBVH6240FWW control dial broken-how to remove?
The control knob simply pulls off. I just looked at the other side of one..The knob connects to the main control board. To gain access you must remove the top of the washer. There will be screws at the rear of the machine to remove the top. Once removed, the control panel will be exposed for easy removal. Good Luck, Eric
Feb 14, 2009 | GE WBVH6240F Front Load Washer
GE Microwave JVM3660SD001 Control Panel Removal Procedure
Remove the grill, should be screws on the top of the unit. There should be one screw behind the grill at the top of the control panel. Remove it and pop the control panel up to remove it. Make sure the mw is unplugged first. Then you can remove the board.
Oct 02, 2007 | GE JVM3660 Microwave Oven
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
