Question about Microsoft Troubleshooting Your Web Page (0-7356-1164-5) for PC
Pro1iaq T721 thermostat heat not coming on - Microsoft Troubleshooting Your Web Page (0-7356-1164-5) for PC
My electric Asko t 721 dryer is not heating
You may have an open thermostat or burned out heater element. The easiest and safest way to diagnose the problem is to unplug the dryer, open the control panel, and use an ohmmeter to check for resistance between the temperature selector switch and the opposite leg of the 240 V plug. If it's open at both the medium and low heat terminals, check the thermostats. You'll probably need a wiring diagram to identify the connections - they're color-coded to make it easier.
Aug 03, 2015 | Asko T721 Electric Dryer
Our t705 display is frozen with all indicators on the LCD lit up. The AC won't turn on. We replaced the batteries, checked the connections, but no use. Any ideas?
There is no reset button on this unit. The manual is here: http://www.pro1iaq.com/home-owner/homeowner-manuals
You may be able to either put the batteries in backwards for a second or take them out and short the connections inside to see if there is a stray electrical block that happens sometimes. Other than that you may have to replace it.
Jun 05, 2014 | Honeywell Heating & Cooling
Clothes warms up but will not dry
I suggest you check the exhaust system to make sure it is clear. Secondly, is yours a drier that has a sensor that determines when to shut off? If so, clean your sensors according to the manufacturers direction.
Thank you for your question @ FixYa.com
Mar 02, 2011 | Asko T721 Electric Dryer
No heat not drying
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 28, 2010 | Asko T721 Electric Dryer
Not heating runs finer
on most asko dryers you should find a reset button it is found on the back of the unit have a look for it in your user guide u mite find it in there
Oct 29, 2009 | Asko T721 Electric Dryer
Overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Jul 24, 2009 | Asko T721 Electric Dryer
ASCO T721 dryer, the heat temp is too low
Is your model a Condensing dryer or does it have a Vent to the outside?
Jun 11, 2008 | Dryers
ASKO T721 dryer - Squeaking
the dryer needs a service you need to replace the front rollers,jockey pulley and grease the jockey pin,check or replace the belt.remove the lint build up from the front frame and element assy.also check that the felt and rubber seal arond the front frame hasnt come out.you can replace it but its hard to get in and you may have to replace the front frame.i find its any easy repair but i see a lot of asko dryers (not because there bad they just need a service about every 5-7 years).hope this helps.
Mar 17, 2008 | Asko T721 Electric Dryer
Microsoft Troubleshooting Your Web Page (0-7356-1164-5) for PC Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
