Question about Whirlpool WTW5550S Top Load Washer
What size tub is the whirlpool wtw5550sq0 washer
What is the tub (basket) size?
catriver
  • 878 Answers
SOURCE: Tub and Basket
Fairway, sounds like you have a worn drive block. You are going to have to remove the agitator and inspect the drive block. If it is the drive block you will get some good hammering when the spin cycle stops. I will attach some photos of a worn out drive block. If you want to attempt to handle this yourself, we can walk you through it. Catriver..post back.
Posted on Oct 23, 2006
  • 188 Answers
SOURCE: Inner basket scrapes on bottom of liner tub during spinn cycle
It sounds like the basket drive block is worn. If it looks like the basket drive block has slid down the brake & drive tube (I believe you're calling it the spindle), it's definitely worn out. When this part is in place it sits on top of the brake & drive tube and won't allow the basket to go lower. To replace this, remove the cabinet to gain access to the the inner basket which you will have to remove. On the top of the brake & drive tube you will see 2 small tabs. Align these with the cutouts on the basket drive block. Mount the drum back on top, and tighten the spanner nut. Reassemble the cabinet and you should be good to go.
Let me know if you need more assistance.
Posted on Feb 21, 2009
  • 30 Answers
SOURCE: water dripping into the tub. Whirlpool top loading washer
You just need to replace the water vale.
The valve is not closing all the way when its off.
Posted on Sep 05, 2009
  • 1044 Answers
SOURCE: Water leaks from the basket of my top loading
Remove the back cover. Inspect the basket for any leakages by filling the water in the basket. If located weld it or seal it with ARALDITE adhesive. Also check the outlet valve at the base of the basket.ensure that outlet valve is seated properly. This should be able to fix the problem, if not then you have to call service engineer to heck the functioning of control panel.
Posted on Aug 21, 2010
jumptrout51
  • 3361 Answers
SOURCE: For the Whirlpool GHW9200 washer, can the spindle
Sorry.
You gotta get the whole thing.
Posted on Sep 28, 2010
Testimonial: "Thanks for the prompt response. Looks like a new machine for the wife...bummer."
What is the tub size in cubic feet for maytag washing machine model no. a112
Why do you care??
Seriously...these machines are rated at 18 or 20 pounds but in reality it depends on the type of fabric and the size of the fabric. Think about it a moment.
Small items, say socks can be loaded well over the supposed limit but large heavy items may only wash well at half the rated load, the laundry has to have the ability to slide through the water in the tub. In spite of what most people believe, the laundry is not supposed to swish around going left-right, left-right but is drawn across the surface of the water, pulled down in the center of the wash basket and there the water currents are forced through the fabric, causing much less wear on the fabric and better cleaning results. Overloading the wash basket is The Major Cause of poor laundry results!
Jul 21, 2017 | Maytag Washing Machines
Tip
Replacing a Rear Tub Bearing
Rear Tub Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
(cont’d)
on Jul 07, 2008 | Kenmore Elite 45986 Front Load Washer
How do you remove the rear tub bearings on a whirlpool duet front loader. tub is out of washer but can't get shaft out
you have to buy the whole tub or basket,each part is around 230 dollars.the basket part number is W10250573 and it's around 215 dollars,this is the part with the shaft on it,the rear outer tub part number is 285984 and it's around 225 dollars.
Apr 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Something between the tub
tub has to be removed get quiliedfied service very dificult
Sep 09, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Whirlpool Duet Model #WFW 8300 SW01 (noise in drum on high speed-sounds as if it has a chain or something inside rattling. How do we get a manual or parts book?
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool front load duet washing machine. The white plastic around the drum is cracking and the machine is leaking from the front underside. Can this be repaired?
the rear tub.
and tub assembly.
Jul 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I dropped nails in the washing machine tub and they fell through the holes. Will this damage the washer if I run it, or might the nails just go out the drain? So far, I have been unable to remove the...
The inner basket may be also bolted to the transmission. If left in there, they will end up in the pump. If this is a steel tub machine, you can buy a good sized magnet, and leave it in the wash basket, near the problem area. The nails should collect on the other side, and hopefully keep them from spreading significant harm, until you can get them out of there. You may be able to **** them out with a good strong shop vac.
Jun 21, 2010 | GE Washing Machines
My whirlpool duet sport is going through a wash cycle and sounds like there are hundreds of rocks in it.
the rear tub.
and tub assembly.
May 11, 2010 | Whirlpool AWM8143 Front Load Washer
Kenmore he3
the rear tub.
and tub assembly.
Feb 07, 2010 | Electrolux AWF1235 Front Load Washer
Whirlpool WTW5550S Top Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
