Question about Franke Plumbing
How do i remove a spout on a franke professional danube tap?
2 Suggested Answers
Magaiver
  • 707 Answers
SOURCE: lisbon monobloc kitchen taps just installed the
Put some cooking oil around the o-rings to sofen them up so they would seat around all fitting surfaces. Hope this helps.
Posted on Aug 12, 2010
Replacing shower diverter in faucet 2007
You will wind up replacing the spout. I just replaced one that was clogged with mineral deposits.
Sep 09, 2017 | Home
Water is dripping slowly from one spout. How do I access and remove the spout assembly on a Jura Impressa F7?
Open the whole machine and you'll find the spout. Tighten up the nut there, the washer is like a tap thats dripping
Dec 10, 2014 | Jura Capresso Impressa F7 Espresso Machine
How do you get the spout off?
Information on your faucet can be found here:
http://www.moen.com/chateau/chrome-two-handle-low-arc-kitchen-faucet/_/R-CONSUMER%3A7907
The exploded parts view can be helpful is seeing how your faucet is assembled:
http://www.moen.com/shared/pdf/7906pt.pdf
First turn off the hot and cold water supply taps. Then to remove the spout you simply unscrew the spout cap counter-clockwise; you should then be able to lift the spout up and off the supply post.
May 19, 2011 | Moen 7907 Chateau Two-Handle Kitchen...
The swing mixer handle has become very stiff. how do i get it off to clean it/
The first solution is of course correct. However I found it almost impossible to remove the spout assembly. It was very stiff and it was difficult to get any leverage to force it off without damaging the finish to the tap as a whole or damaging the sink.
What I found was that if you poured boiling water over the tap/faucet it eased the stiffness and having done this several times - ie about 5 kettle loads of hot water, I managed to remove the spout. It helps if you reconnect the hose directly to the outlet under the sink (ie not via the faucet). THis allows you to run cold water through the tap whilst pourung boiling water over the outside of the tap. The cold water shrinks the copper/brass components whilst the hot water expands the spout assembly.
Once off, it is possible to clean the inside of the assembly to remove corrosion or calcium deposits to say nothing of old "O" rings.
I also used a kettle descaler between dousing with boiling water in the hope that some of it would seep down within the assembly.
It took me three attempts to do this. I was almost going to spend UK pounds 430 or US dollars 670 and buy a new unit. So do not give up and I hope this helps.
It swings backward and forward now perfectly.
Aug 27, 2010 | Blanco Classic Single Handle Faucet with...
Lisbon monobloc kitchen taps just installed the
Aug 12, 2010 | Home
Moen Tub Filler Can't Remove Spout
It should lift off gently twist as you lift maybe tap spout lightly back and forth with a rubber mallet
Oct 14, 2009 | Moen Kingsley Two Handle Roman Tub Faucet...
There are no visible screws (above or below the
If you mean spout, if there are screws holding it on,then the spout will unscrew.
Sep 28, 2009 | Home
What part do I need to buy to repair a broken axle? It broke at the wheel bearing hub.
if you call a professional junk yard they can help u-if mechanical the librarysec 629 has many tear down manuals
Aug 10, 2009 | 1996 Toyota Corolla
Tap needs new ''O'' ring on swivelling neck
Usually there is a retaining nut at the base of the spout that unscrews. It looks like apart of the faucet. Once you unscrew the nut, you can pull out the spout exposing two washers that can be replaced. If I had a picture of the faucet, I woul know exactly what to tell you. I'm just using an explanation that are for most faucets. Good luck!
Mar 31, 2009 | Franke Plumbing
Plumbing Logo
62 people viewed this question
Top Franke Plumbing Experts
Donni Steen
ray gallant
William Wurtinger
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
