Question about Husqvarna 125bvx Hand Held Blower Vac
How do you remove the special carb adj. screws
Where do i buy the tool to remove the carb mixture screws
2 Suggested Answers
daneinwv
  • 124 Answers
SOURCE: husky 125B blower, new right
My name is Dane and I am going to assist you in solving your problem.
You will need to adjust the high speed setting on your Carburetor jet. Turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however, yes you do need a special tool that is very hard to get your hands on, in order to adjust the jet screws. They don't make many engines with plain screw heads anymore. The newer Carburetors are factory set lean so they can pass emission standards. Since you just bought yours, a local husky dealer should adjust the mixture for free. I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I
Posted on Dec 09, 2010
Where is the fuel air mixture screw on a shindaiwa backpack blower
Look on the side of the carb. they are there. You will probably need to remove the air cleaner form the carb to see them and then you may need a special tool to adjust them due to the EPA covers on the screws. Hope this helps.
Jun 27, 2014 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
Runs slow
In California the new blowers have sealed mixture adjustments and you need the have your carb. mixture adjusted be a qualified shop. If your carb. HAS mixture adj., turn the high speed mixture so it runs best at high speed, then turn another 1/8 turn counter clockwise to be a little rich. Then at idle adj. the other screw till it idles best.
Apr 21, 2014 | kawasaki Krb300a Backpack Leaf Blower
Can get it to stay running
The carb is running too lean, statrt by replacing the fuel filter in the tank, check for any fuel leaks from the hoses, if this checks out ok, you need to richen the fuel mixture on the L and H screw on the carb, depending on which carb is fitted you may need a special tool to adjust the mixture screws, turn each screw out ( anti clockwise ) 1/4 turn and try again.
Jun 19, 2013 | Garden
My polan saw will start but boggs when given gas if you pump the throttle it will run at full throttle buy once it idles down it stalls
This is fuel starvation, replace the fuel filter in the tank, check the fuel hose up to the carb for signs of leaks, or cracks, if the carb has no anti tamper screws, screw the L screw out 1/4 turn to richen the mixture, if the carb has anti tamper screws you will need to get the special tool to adjust them.
Sep 15, 2011 | Poulan Pro Chain Saw 46cc 20"
Tk carb ? sthil trimmer has 3 adj screws ,how do you adj?
One adjustment screw (probably Phillips-head) is the Idle speed adjustment screw. Turn it in, to increase idle speed (it moves the throttle plate)...turn it out to slow idle speed down. The other 2 screws are the Low mixture screw and the High mixture screw. The L screw is closest to the engine and is used to adjust the engine at IDLE. The H mixture screw is to be adjusted when the engine is at wide-open throttle to get the proper RPM's....not too little and not too much. Here is a tutorial by Zama carburetor reiterating what I have just told you and HOW to go about your adjustment.
http://www.zamacarb.com/tipspage.html
Sep 11, 2011 | Garden
Brand new today Poulan P1500..Started, warmed up. Went to accelerate and it just bogged down and died with no cutting load on it. From what I am reading on forums Poulan is going to give me problems. I...
you have 2 options, return it or use a dremel tool and cut a slot in top of low speed jet screw and turn counterclockwise bout 1/4 turn, keep in mind if you do this it can't be returned, I have seen a lot of good poulans and a lot of bad poulans, flip a coin !
May 04, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
Wont run up to speed without choke partially on. Where are the carb. adjustments? Does it requir a special tool/
Probably uses a Zama Or Walbo carb. The mixture screws are factory preset and may or may not have plastic limiters on them. There are tools for adjusting these type carbs or you can fashion one yourself. Most of the screws are of the "splined" variety.Running partially choked is a result of the carb needing adjustment and/or repair (rebuild kit). Like anything else, they require maintenace and installing diaghram or rebuild kit accomplishes this...you can remove and clean the carb and its internals with non-flammable brake cleaner aerosol spray. Don't use high PSI compressed air on it and never soak the carb.
Aug 20, 2010 | Poulan 25CC Gas BlowerVac
Need to adjust my honda shadow 500 vt carburator's fuel/air mixture
start by synchronizing your throttle plates. Honda calls the next step the "idle drop procedure". u need to know if you have fuel adj. screws or air adj. screws. fuel screws will be on engine side of carb slide, air screws will be on airbox side of carb slide. start leaning out mixture, (turn in fuel screw, turn out air screw. idle will increase so keep adjusting idle back to spec.after each turn if needed. Adjust about 1/4 to 1/2 turn at a time on each carb until there is no change in idle, then richen up mixture by one half turn. If u sync throttle plates first then follow this procedure, there should be no hesitation when you "blip" the throttle, and after revving it should return to idle smooth,
Apr 08, 2010 | 1986 Honda VT 500 C Shadow
I am looking for a tool to adjust the air mixture
yes the EPA has mandated you be trained how to properly adjust the new carbs, Any qualified Husqvarna dealere would be happy to sell you the tool and show you how.
Oct 27, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Cannot take valuable time off to have the fuel mix adjusted. Need the tool !!
those carb adj. screws are very small. I was recently looking at this myself, it was recommended to me to heat a small screwdriver then place agains the plastic screw. This was an ingenious way to now have a tool to adjust the carb mixture. It worked for me, just thought I would advise with that. I hope it helps.
Aug 07, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Husqvarna 125bvx Hand Held Blower Vac Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
