Question about Panasonic NRB30FX1XB Bottom Freezer Refrigerator
The fridge has become noisy - Panasonic NRB30FX1XB Bottom Freezer Refrigerator
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
Is the rotor inside the compressor.
Posted on Oct 10, 2017
When we shut the fridge door a loud continuous humming noise comes from the fridge. This seems to be activated by the door light switch at the top. Thank you
There are 2 possibilities I can think of for the hum. When you activate that door switch it activates 2 fans and the compressor. There is one fan located on the compressor and one located in the vent system in the fridge. The second fan is used to circulate cool air evenly through the fridge. I would recommend holding your finger on the door switch and listen carefully whether the noise is coming from inside the back of the fridge or from the lower bottom. Lower bottom could indicate compressor cooling fan or compressor. They would need to be inspected. If it sounds more like the other fan mentioned above it would again need to be inspected. The compressor cooling fans can get stuck or become noisy due to bearing failure. The vent fan can get stuck or noisy but also in some cases if the defrost circuit is not working can chock up with ice and create a buzzing noise as the fan blades strike the ice.
Jan 13, 2017 | Refrigerators
The fans have become very noisy what can I do?
there are 2 places to check....Not sure of the model of your fridge but on the backLook for the compressor fan...make sure it is clean and free of dirt...Alot of times there are located on the back but I have seen a couple older ones where the fan is located on the bottom....They get clogged with dust and dirt/....but for a noisy loud fan I suspect your fan inside the fridge is partially frozen...condensation collects around these fans alot and freezes ...the ice hitting and rubbing against the fan itself...so located the fan on the inside....It is usually towards the bottom and behind the little drawers...and hidden behind a sheild of some sort....defrost with a hairdryer if needed....good luck.
Mar 03, 2015 | Refrigerators
Srs618dp model samsung noisy and lose temperature
I have a Samsung srs618dp side by side fridge. I have just turned it on after 5 months and it seems to be working however every 30 seconds it keeps beeping, very annoying. There is no ice build up.
Apr 06, 2013 | Samsung RS2630SH Side by Side Refrigerator
Noisy compressor on fridge freezer
does it always make that hum noise or just when adjusting temp
Aug 18, 2012 | Kenmore Refrigerators
Hi Fridge side fan was noise for 3 days and now
Hi I have same unit. Problem is the fridge circulator fan gradually ices up, becomes noisy and then stops when frozen up.
To fix quickly you need to remove all shelves drawers etc, then unfasten lower panel fixings and find the whole back is full of ice including the fan.
Remove panel , and de-ice fan etc until fan rotates freely. Replace and all will be OK.
Otherwise empty and defrost normally but be prepared for a long wait
Don't call an engineer he will just do same. Hope this helps
Mar 21, 2011 | Samsung RS2630SH Side by Side Refrigerator
My fridge has become very noisy? Could you advise?
The fault can be the vibration of the compressor motor radiating the noise to the condenser coils. So it may be hitting against the walls of the fridge and you are getting this noise. Also tthe compressor makes tteh vibration that transmits to plastics, trays at the bottom of fridge and the rear mounting. Use good adhesive stickers to soften them.
Aug 30, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
Panasonic NRB30FX1XB Bottom Freezer Refrigerator Logo
Top Panasonic Refrigerators Experts
Lawrence Oravetz
jhnolson
Are you a Panasonic Refrigerator Expert? Answer questions, earn points and help others
