Question about Water Heaters
Powerstar elctric tankless water heater model 45-557701
Water wont stay hot. warms up then gets cold
3 Suggested Answers
  • 37 Answers
SOURCE: i have the bosch
how is heating element ? Wasit on with no water running thru it. Does it have a reset?
Posted on Jan 26, 2011
jamesstenkly
SOURCE: PowerStar. Model 45-557701
I have had no hot water and have fixed it by removing the inlet screen and cleaning it, also make sure the water flow thingy is spinning in the clear inlet side of the heater. If your on a well or have questionable water algae can affect the flow indacater very gently tap the clear plastic while you have the hot water flowing only if it not spinning . It fixed mine. I ended up dumping bleach in my well to fix mine. Hope this helps someone, nothing like getting ready to go to work and having no hot water!
Posted on Feb 19, 2013
I have a Bosch Powerstar Ae115 and the left cutout keeps tripping. It has worked great for 5 years. When i reset it, the water gets warm again(never hot as it was before). What could be causing it to trip?
Water leaking into elements. Bad PC board. Undersized breakers. Undersized main panel.
Bosch Powerstar is a computer that happens to heat water.
If your 5-year-old laptop computer was malfunctioning, you would not be surprised.
But for some reason (false marketing by manufacturers?), folks believe a tankless computer is going to last 20 years.
Moreover folks also believe tankless will provide endless hot water while saving money.
The whole idea of tankless saving money is a load of sales-BS that defies physics and common sense.
There are no service manuals... except bosch website has troubleshoot section in product manual.
Call a bosch-qualified service tech.
Go to Lowes and buy ordinary tank heater, and fix your heater today for only $250.
Tank-type electric water heater can be easily repaired and maintained by homeowner to last forever... that is a fact
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Gene
Jan 12, 2014 | Water Heaters
The thermal cutout pops on tank two after it shuts off. It boils then shuts off. It also turns off when taking a shower, producing cold water. I checked the ohm readings on the thermal cutout and the...
Question posted under Bosch tankless.
Question says 'tank'
Brand, model, and type heater unknown.
Elements mean electric.
'Thermal cutout pops when taking shower produces cold water' indicates tankless, since tank-type would maintain some hot water.
No error code might indicate tank-type.
Add a comment with type, brand and model number of heater for possible assistance.
Sep 24, 2012 | Bosch PowerStar AE125 AE125 Whole House...
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) Before calling service technician, open following link for Bosch troubleshooting steps.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Apr 22, 2011 | Bosch PowerStar AE115 Tankless Water...
I have a Powerstar Electric tankless water heater, 45-551301, installed in a new home less than 3 years ago. We have always had minor problems with the hot water staying hot, fluctuations in hot and tepid...
Tankless heater are a little frustrating sometimes but this is generally an issue of waterflow I believe. The fluctuations are do probably to the amount of water and rate of water going through the heater. If you have a shut off valve on the cold side of the heater, shut it back about half way. This will slow the water going through the heater and allow the heater to heat it up more efficiently. Then go to the shower, turn the hot on all the way (no cold) and allow it to heat up. Once it has heated up, test it by hand for a good temperature that you like. If it is too hot, turn the cold on just a bit until it comes to the temp you like. If it is too cold turn the hot down just a little (still no cold) and it will warm up. Ideally you should be able to turn the hot on full blast and then just turn on a little cold to get the right temp. Once you learn how these work then it makes it easier. You really cant run the water like you do with conventional hot water systems and expect to get the same results. Also, wanted to give you another little tip. Every 6 mos to a year, you should flush you heater with vinegar for about 30-45 minutes using a small cheap submerible pump like for a water feature in a garde. Just put in a bucket of vinegar and and run a hose to the "in" side of the heater and another from the "out' side of the heater and then back into the bucket. This will circulate the vinegar inside the heater and clean all the deposits that will DOA your heater. Funny how the manufacturer wont tell you this but these deposits will ruin the connectiosn on the heating elements. You can make your heater last for a long time if you do this.
Mar 27, 2011 | Bosch PowerStar AE115 Tankless Water...
My Powerstar tankless water heater was installed last April and we have a problem that has become a real issue. We can set the temperature where we want it and get in the shower and the water will go from...
Ok, sounds like a flow sensor issue, is your house water pressure steady or does it fluctuate? The sensors on these seem to be a common issue and this model has many issues with heating. take care
Jan 17, 2011 | Bosch PowerStar AE125 AE125 Whole House...
PowerStar. Model 45-557701 tankless water heater water wont get hot...it slowly quit getting the water hot
Hot Water Hot to Cold And back. I had that problem for 2 years. I had a very large shower head from the time I installed the tank-less hot water heater and the water temp would change from one extreme to another. Over time my shower head had stopped working as well as it did so I bought a smaller shower head and installed it and amazingly my water temperature quit changing temperature. I now turn my water to what temp I want and it stays there. It's been working correctly for 6 months now ... until yesterday and it quit working completely which is the reason I'm on here. lol
Jan 07, 2010 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
35 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
