Question about Fisher Price Starlight Papasan Cradle Swing
No sound and light is staying on
I just put the swing together and there is no sound, the mobile is not turning and the light is staying on. It is set to AC power. can someone help me trouble shoot?
2 Suggested Answers
SOURCE: not instructions to put together
Thanks but I just guessed how to put it together and it worked very well
Posted on Mar 23, 2009
Swing stopped working
Had the exact same issue, so I called FP. I had already taken the motor housing off to see if it was something obvious, like a loose connection or broken part. I didn't see anything wrong so I just cleaned it up and put it back together. When I called they offered to sell me a new motor for around $80. Then the lady I was speaking to (who was typing as we talked) said "hey, wait, there's a note in here about this issue..." She said to do what I had done, lightly clean it out with something like a keyboard cleaner, then using the plug (not batteries) set the speed to two/center. It somehow resets it.
That worked for me, and it was free. If that doesn't work then yes, you can get a motor directly from FP. Call the customer service number listed on the back of your manual, if you have it, or 800-432-5437. You'll need to have it nearby so you can give them the model number and year that is listed on the back of the motor housing (open the battery compartment if it isn't on the outside).
You can also get motors online, especially ebay, from any of the papasan swings FP makes. I love this swing so much that I think it's worth it. I've used it for four years now and plan to use it in the future.
Aug 01, 2012 | Fisher Price Starlight Papasan Cradle...
Fisher price oceans wonders cradle swing music doesn't work ; help please
try looking at the stand that holds the swing, when you put it together maybe you missed some cords that would only connect together that do not plug into the wall.
Jul 16, 2012 | Fisher Price Ocean Wonders Cradle Swing
How to change signal front signal bulb for 20092 buick century
Youll have to access it from the inside engine compartment. there is a cover on it remove it, Now if you there here is waht youll have to do your going to need patient for this is on todays car on all of them. Do you see that metal wire band there is a part that you squeeze together as you push in squeezing it together and allow it to swing out. now that clip swings out. (dont screw anything out)when that swings out the bulb comes out and you put the bulb back in. Now you just dont position any way you want to even though it looks like it can be it goes in one set way okay,by the way do you have a mirror? not a tiny one a nice size one to help you see it because most the time youll have to feel your way through. put the bulb in plus the connection and turn on the signal light and you did it, dont forget to put the cover on .
Apr 23, 2011 | 2002 Buick Century
Mobile not turning
Hi, do you have the mobile function turned on? When you're looking at the controls, the mobile is controlled by the dial on the bottom right; if it is set to either mobile (the four arrows chasing each other around in a circle) or mobile and lights (the four arrows below the image of the light) then the mobile should turn on when you turn the main swing dial to either stationary (the circle with another circle inside it) or to any of the "on" settings (any of the filled-in circles after that).
If the mobile isn't turning on but everything else is working, you probably have a bad mobile motor inside the swing that will need to be replaced. Taking it to a repair shop might be expensive -- you can sometimes find used swings on eBay for cheap and harvest the parts you need from one of them.
Dec 11, 2010 | Fisher Price Ocean Wonders Cradle Swing
Cannot put together; don't have manual!
go and talk with who gave the swing
Mar 22, 2009 | Graco Baby Gear
Not instructions to put together
Mar 21, 2009 | Fisher Price Baby Gear
Tachometer swings wildly - door ajar light stays on
check the peed sensor wires. is on top of the tranns o may be on the side this sensor is bolted in the transmision w/ 10mm. imprety sure is los for the second q?? check firts the bulb put a new one. check you fuse(s). if the door ajar istays on check the pin is close to the brake pedal o by the door this is hold it by one nut problably fall of and this pin is inside thechasis area against to the chasis. kepin on you ligth
Jan 13, 2009 | 1997 Nissan Maxima
Fisher Price Starlight Papasan Cradle Swing Logo
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Josh Whitehead
Josh Whitehead
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
