Question about Olukai Moloa Shoes
Resole olukai Moloa shoes sole worn out - Olukai Moloa Shoes
Why is the sole sticky and crumbling?
This sounds like these shoes have been kept in humid areas that is causing the PU to deteriorate.
May 06, 2014 | Spira Wave Walker DX3 Shoes for Men
The soles of all my dr scholl exercise sandals (wooden) have worn down to the wood. getting them repaired cost more than they cost new here in maui. is there any kind of quick fix, or not-so-quick, for...
I resoled mine this morning with some soling material that happened to be kicking around the house. They are expensive here and it is cheaper to resole. If it is expensive to resole there, why not send them off the island?
Jan 23, 2014 | DR Scholl's Wood Exercise Shoes Shoes
Shoes resoled
it is possible to get these resoled. I have seen hush puppies resoled several times.
Jan 10, 2014 | Hush Puppies Clothing Accessories
Between us, we own dozens of Ferragamo shoes. My wife liked her Ferragamo Greatly loafers very much. But unfortunately, without warning, both soles broke at about the same time, cracked across the width of...
The first pair of shoes can not be bixed. Once the sole splits, the shoes are done. There is an increasing amount of TPR soles these days.
The second pair can be replaced with Vibram soles.
Sep 20, 2011 | Salvatore Ferragamo Vara Shoes
Sole has worn off. Can it be repaired?
There are two possibilities, if the upper is in good condition and you really like the shoes. One is to find a shoe repair shop, the repairer will tell you if it is possible and what the cost will be.
The other option is to find a general store which sells stick on soles for shoes. With a little luck, you may find some which resemble the soles on your Nikes. If so, it is an easy enough cheap repair and should last for a while, but it will never be as good as the original. or a professional repair.
Aug 24, 2011 | Nike Clothing Accessories
Can you get fitflops re-soled?
You can get them resoled. A shoe repair shop can help you with this unlesss you have some shoe findings at your house. In that case, a Helmitin glue might be the best and a vibram full outsole. Grind the old outser sole off with your finisher and make sure that it is even. Put the glue on both sides and then put the sole on and put it in the press at 1-1.5 torr
Jul 26, 2011 | FITFLOP Gogh Shoes for Men
Olukai Moloa Shoes Logo
877 people viewed this question
Top Olukai Clothing Accessories Experts
Da Doc
ray gallant
Are you an Olukai Clothing Accessory Expert? Answer questions, earn points and help others
