Question about DCS FSF-40 Deep Fryer
Manual combination valve - DCS FSF-40 Deep Fryer
Manual for honeywell natural gas valve. Vr8204c 1084
Google for "Vr8204c 1084 manual" ... 1st item says:
http://www.warming-trends.com/manuals/HoneywellTroubleshootingGuide.pdf
68-0047 - VR8204; VR4204 Intermittent Pilot Dual Automatic Valve Combination Gas Controls
Pretty much chapter and verse - you don't usually get any more.XV66OI
This is an industrial valve. Are you safe to meddle with it?
Dec 29, 2016 | Honeywell Water Heaters
I have a 2002 yukon xl 1500 slt 5.3.I'm having problems with my abs control module and also a code of p1810.Do u have any suggestions as to what I can do?Help I'm low on cash
Melisssketer,
The P 1810 code is usually the transmission, here are some possible causes;
- Faulty automatic Transmission Fluid Pressure (TFP) Manual Valve Position Switch
- TFP Valve Position Switch harness is open or shorted
- TFP Valve Position Switch circuit poor electrical connection
The automatic Transmission Fluid Pressure (TFP) manual valve position switch consists of five pressure switches (two normally-closed and three normally-open) and a Transmission Fluid Temperature (TFT) sensor combined into one unit. The combined unit mounts on the valve body. You could have a problem with any one of these switches. If this is the problem with your car, parts will not be cheap but it can be done without pulling the transmission. I hope this helps, Ray
Feb 15, 2015 | 2002 GMC Yukon XL
American range fryer will not light...the knob you turn to light the pilot light will not turn.you can push it in but won't turn.please help
From the Owners' manual:
LIGHTING
1. Before attempting to light this appliance, the door if so equipped, shall be open.
2. Turn the appliance manual gas shut-off valve to the OFF position.
3. Turn the combination gas control knob to the OFF position.
4. Turn the thermostat control to the OFF position.
5. Wait 5 minutes.
6. Turn the appliance manual gas shut-off valve to the ON position.
7. Turn the combination gas control knob to the PILOT position.
8. Light the pilot with a match while depressing and holding the combination gas control knob until the pilot remains
lit upon releasing the gas control knob.
9. Turn the combination gas control knob to the ON position.
10. Turn the thermostat control knob to the desired temperature to turn burners ON.
11. Ensure that the door is closed during operation.
12. For complete shut-down, repeat steps 2, 3, and 4.
It won't turn any further until the pilot is lit and stays lit.
Jun 14, 2014 | Kitchen Appliances - Others
4runner v8 what is dis code p0412 and how do i fix it.with pix pls.
I'm going to post the description from engine-codes.com since it is a big paragraph. You will need a shop manual or else take it to a repair shop that has the equipment and book to check it out.
P0412 TOYOTA Description
An air pump is used on the vehicle to lower tail pipe emissions on start-up. The Powertrain Control Module (PCM) grounds the Air pump relay control circuit which energizes the Air pump. The PCM also grounds the Air combination valve vacuum control solenoid circuit, which energizes the Air vacuum control solenoid. Vacuum is then applied to both Air combination valve diaphragms which opens the shut off valves. The PCM enables both circuits simultaneously when Air system operations id desired. When the AIR system is active, then Air pump forces fresh air into the exhaust stream in order to accelerate catalyst operation. The AIR combination valves replace the conventional check valves. When the AIR system is inactive the shut off valves prevent air flow in either direction.
The DTC P0412 is detected the the AIR vacuum control solenoid circuit not operating as desired by the PCM.
Read more: http://engine-codes.com/p0412_toyota.html#ixzz2Y7OQTCbb
Jul 04, 2013 | Cars & Trucks
WHERE IS THE COMBO INTENRNAL SWITCH ON A 2003 MONTANA for rear breaks how to replace
The combination valve,You have a proportional valve,this adjust pressure to the front and rear,as for the combination valve it uses the ABS modulator.
Mar 31, 2012 | 2003 Pontiac Montana
Transmission pressure switch manifold fault explanation p1810
Hi there:
The automatic Transmission Fluid Pressure (TFP) manual valve position switch consists of five pressure switches (two normally-closed and three normally-open), and a transmission Fluid Temperature (TFT) sensor combined into one unit. The combined unit mounts on the valve body.
The Powertrain Control Module (PCM) supplies ignition voltage for each range signal. By grounding one or more of these circuits through various combinations of the pressure switches, the PCM detects which manual valve position you select. The PCM compares the actual voltage combination of the switches to a TFP manual valve position switch combination chart stored in memory.
The TFP manual valve position switch cannot distinguish between PARK and NEUTRAL because the monitored valve body pressures are identical. With the engine OFF and the ignition switch in the ON position, the TFP manual valve position switch indicates PARK/NEUTRAL. Disconnecting the AT inline 20-way connector removes the ground potential for the three range signals to the PCM. In this case, with the engine OFF, and the ignition switch in the ON position, D2 will be indicated.
When the PCM detects an invalid state of the TFP manual valve position switch circuit by deciphering the TFP manual valve position switch inputs, then DTC P1810 sets.Action Taken When the DTC SetsThe PCM illuminates the Malfunction Indicator Lamp (MIL) during the second consecutive trip in, which the Conditions for Setting the DTC are met.The PCM commands D2 line pressure.The PCM commands a D4 shift pattern.The PCM freezes transmission adapt functions.The PCM records the operating conditions when the Conditions for Setting the DTC are met. The PCM stores this information as Freeze Frame and Failure Records.The PCM stores DTC P1810 in PCM history during the second consecutive trip in, which the Conditions for Setting the DTC are met.Since the computer does not know what gear range the transmission is shifted into, it defaults to a higher line pressure to protect the transmission. It also commands the transmission as if it were in the D4 position. The transmission will still shift normally through all the gears, shifts may be more firm than normal. No damage will occur to the transmission if driven even for prolonged periods with this dtc set. It is far more likely that the loss of transmission fluid damaged the transmission.
Hope helps.
Mar 21, 2012 | 2002 Pontiac Grand Am
Where is the combination valve?
The combination valve is located at the brake master cylinder, it is what sends fluid to the brake cylinders. See picture of typical valve below.
Feb 22, 2012 | Cars & Trucks
How to change bad thermocouple on reliance gas hot waterheater reliance 606
it is important to turn off
the gas supply to the water heater at the manual gas shut-off
valve. This valve is typically located beside the water heater.
Note the position of the shut-off valve in the open/on position
then proceed to turn it off.
2. On the lower front of the water heater locate the combination
gas control valve/thermostat. Depress and hold
the lock tab located under the gas control knob on the right.
Rotate the gas control knob on the combination gas control
valve/thermostat clockwise until "OFF" aligns with the mark on
the front of the gas valve. Once the gas supply has been shutoff,
remove outer door. 3. Using a 1/4" nut driver or socket loosen the two screws securing
the manifold door assembly until they are free. Do not
totally remove the screws and plastic retainer washers from
the manifold door. The screws and retainer washers will be
needed to reattach the manifold door. 4. In this step, the thermocouple, manifold tube, pilot tube and
igniter wire will be disconnected from the combination gas
control valve/thermostat. Using a 7/16" wrench
disconnect the thermocouple (left-hand thread) and pilot tube
(right-hand thread). Using a 3/4" wrench disconnect the manifold
tube (right-hand thread). Carefully pull the igniter wire from
the igniter button.
5. Grasp the manifold tube and push down slightly to free the
manifold tube, pilot tube, and thermocouple from the combination
gas control valve/thermostat. when installation is complete and gas is back on, You should be able to relight the pilot and the functionality of your gas hot water heater should be restored.
Nov 27, 2010 | Reliance Natural Gas Water Heater Control
We have a gas wall heater product number 4690011 and we do not know how to start it;
Remember if you smell gas, turn unit manual gas valve off and open a near by window, wait until smell is gone then proceed with these directions,turn manual gas valve back on, turn thermostat down.1.) turn combination gas valve knob to the pilot position and press down knob, if unit has a striker button, push striker while holding down knob until pilot lights, keep knob held down in the pilot position for 20 seconds then let up on knob and turn to the on position, turn thermostat up, main burners should light.
Mar 04, 2010 | Heating & Cooling
1996 Chevy Suburban rear brake fluid does not bleed out when bleed valve is open
if rear wheel drive the combination valve has be held open.you have to have a combination valve depressor tool .you need a scanner to do abs brake functional test.
Mar 15, 2009 | 1996 GMC Suburban
DCS FSF-40 Deep Fryer Logo
Top DCS Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a DCS Kitchen Appliances - Other Expert? Answer questions, earn points and help others
