Question about Whirlpool Duet GHW9150P Front Load Washer
Error code RL keeps occuring when washer is in CLEANER MODE
  • Anonymous Mar 18, 2014
    Error code rL
    President:
  • 272 Answers
Rl code is load detected in drum during cleaning washer cycle. Book answer is to remove clothes and start the cycle again. Here's everything that Whirpool doesn't want you to know or do to your machine. Don't blame me if you do anything that damages your product. This is a link to the on-line 'technician' only service manual for your washer.
http://www.scribd.com/doc/7075573/Whirlpool-Kenmore-HE2-Plus-Troubleshooting-Tech-Sheet-8540259
Posted on May 09, 2009
    Problem Solver:
  • 8 Answers
Take machine off clean cycle!
Posted on May 23, 2009
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Error code FL flashes and my calypso washer keeps beeping. Won't start just shows the code.
FL error - Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
You coudl se this manual: Service_Manual_PDF
Hope this helps.
May 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
An error F34 how can i solve this problem
Hi and welcome to FixYa, I am Kelly
Somehow you selected a clean cycle.
http://maytag.custhelp.com/app/answers/detail/a_id/2892/~/display-shows-rl-or-f34---front-load-washer
This error code indicates that items were detected in the washer during the Clean Washer cycle.
The Clean Washer cycle is used to keep the washer fresh and clean. Do not place garments or other items in the washer during the Clean Washer cycle. Use this cycle with an empty washer basket.
If you have a Maytag.... (no model number given so I chose one)
See the Use and Care Guide for details; find it by entering your model number in the search tool below.
Remove the items from the washer.
To remove the error display, press Pause/Off or Pause/Cancel or Power once.
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Washing Machines
I was running the clean cycle on my Kenmore front loading washer and it keeps stopping and reading rL. It wasnt having any probs working on reg cycles, only when I was trying to run the clean cycle. What...
The rl code is displayed when the control detects a load of clothes in the washer during the clean washer cycle.
This code should only come up when you're trying to run a clean cycle.
There can be two causes for this message if there are no clothes in the washer while you're running the clean washer cycle.
The most serious cause of the problem would be the spin bearing. Try and turn the basket by hand and see if you fill any restrictions.
The basket can drab because of the bearing or because there are clothes between the spin basket and outer tub.
Turn the basket by hand and see if you notice anything.
You can also try to remove the belt and run the clean cycle and see if the problem repeats. If the code doesn't repeat with the belt off and there is nothing between the tub and spin basket most likely the spin bearing will have to be replaced. The bearing is part of the rear half of the tub and will require a complete tear down to change.
The rL error code during the clean cycle is likely caused by friction on the spin basket shaft since you indicate that you hear squeaking when the washer is spinning.
The squeaking is normally caused by a bad bearing in the rear tub shell.
I recommend that you have the washer diagnosed and repaired by a Sears service technician.
This type of problem will normally require an extensive tear down of the washer to repair.
It is not a problem that you can normally repair yourself.
Open the door & slowly rotate the spin basket to see if you can feel any kind of drag on the bearings.
If the bearings check good, the control board is sensing a load & will need to be replaced.
If the message rl repeats with the belt off then the most likely cause of this problem is the machine control board.
http://media.fotki.com/1_p,sqfgswqgwssgwfwxgtqsskgwtqkq,vi/ssfqsqssrxkbbdrggfw/1/1303472/5961857/image34400img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!
Sep 15, 2010 | Kenmore HE2 Plus Front Load Washer
My washing machine is a kenmore model W10071750 and it keeps flashing rL. I cannot find this error code in the manual. I tried reloading it and restarting it. That did not work.
It may be a long shot, but it's worth a try before engaging in an expensive service call. Pull the plug - count to 60 - replug. Mine is washing again.
Aug 24, 2010 | Kenmore HE2 Plus Front Load Washer
Got an error code rl. Took the clothes out, now know re-start procedures
Hello, the rl error code means that at the start of the cycle a load is detected inside the drum, and what you have to do is to remove the cloth from the drum and start the cycle again.
Thanks
Jun 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
My kenmore HE2plus washer gives an error code (rL) when we try to do the cleaning cycle.
Oct 19, 2009 | Kenmore HE2 Plus Front Load Washer
My empty washer keeps giving me an rl error while trying to run cleaning cycle
Sep 26, 2009 | Kenmore Elite HE5t Washer
HE2plus. I keep getting rL on clean washer cycle.
Mar 03, 2009 | Kenmore HE2 Plus Front Load Washer
We get an rl error code when attempting to clean washer. Why and what does it mean?
Is there some thing in the washer ?
rl error
If at the start of the CLEANING WASHER cycle a load is
detected inside the drum.
NOTE: Detects by weight.
Possible Causes/Procedure
Remove clothes from drum and start the cycle again.
Aug 15, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
5,278 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
