Question about Locks & Locksmithing
Ilco unican 700 key card lock
Green and red light can't program
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
  • 47 Answers
SOURCE: Hi, I got my simplex gun safe open. Now i want to
try this link http://www.youtube.com/watch?v=N-QiaS4bZvg
Posted on Feb 25, 2011
  • 963 Answers
SOURCE: I have a Simplex Kaba
I believe you can find this to be relevant:
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Here's the website to continue your search:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: we are trying to change our code for ILCO, Unican
1.) ENSURE THE DOOR IS OPEN! This is totally necessary to reset the combination!
REMOVE THE KEY.
Good Luck!
  • 963 Answers
SOURCE: We are trying to recode
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=14
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Green light on numbers door doesn't open
Aug 18, 2012 | Simplex Kaba Ilco Unican L1000 keyless...
What's your problem?I HAVE A LOCK THAT KEY WILL NOT LOCK ITS ALWAYS OPEN
I urge you to contact Kaba Ilco technical service and talk to a technician.
Here is the contact information:
Oct 08, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Ilco unican- USA We would like to receive the standard code, which it has when you purchase this safe
Jun 27, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Lost combination on the unican 1000! How do i get it back or set a new number in it?
I will give you several sources of information for you to pursue.
First is a link to a chart where you can download PDF files for your lock ( the L1000):
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=l1000
There is a link on that page where you can download and install Adobe Reader in order to open and view PDF files, if you don'ta already have it installed on your computer.
Aditionally, here is a link to a website wherein it is described how to change the combination on the unican lock:
http://www.lilocksmith.com/keyless_Locks/unican1000.htm
May 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Need to know how to re program our kara ilco when i swip the gma card it says card error or wrong card is being used
The Kaba Ilco 1000 lock does not use any sort of card reader for programming--it is strictly a push button lock.
From this link, which you can cut and paste into your web browser:
you can search for your model of Kaba Ilco lock and click on the box with the picture of your lock.
This will take you to the page for that particular lock. On the right side of any given page, you will see the heading "Documentation" an under that, a link that says "click here to visit the literature and support page".
Following that link will lead you to a grid of the various lock models, with links to the manuals, etc.
These will be PDF files and will require you to have Adobe Reader installed on your computer to view them. If you don't have Adobe Reader, : http://get.adobe.com/reader/
You will also find a "Contact Us" link on the first link I gave you, where you can contact Kaba Ilco directly for customer and technical assistance.
I hope I've been able to help. Good luck!
Mar 26, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
When trying to reprogram a room key for entry, the initialization process works, but after you initialize and a green button appears, we connect the kaba to the door, but when we slide the card it says...
Contact Kaba Ilco directly with your problem.
Technical Service Dept.
For further information at (800) 849-8324
or (336) 725-1331.
They are located in North Carolina, so the best time to call is probably during east coast business hours.
Good luck--and please provide feedback if this helps!
Jan 22, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I'm trying to initialize a lock that has had the batteries replaced. the initialization key blinks red/green, then green but the programming key blinks red/green then red
You'll have to supply the brand and model number (if you have that info). Every manufacturer's product programs in a different way. If possible, post a photo of the lock.
Dec 16, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Locks & Locksmithing Logo
93 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
